Register to reply
Energy required to boil water
by northh
Tags: boiling, heat capacity, mollier, water
Share this thread:
northh
#1
Dec15-10, 08:42 PM
P: 2
1. Problem, data and attempt at a solution
How much energy is required to boil off 3 litres of water from 20*C?
This is not really homework, but I still thought this would be the best place to post:
To get something to compare to in terms of energy (joule/watt), I would like to know approximately how much energy it takes to boil all the water in a standard kettle (3 litres).
I tried doing this with data from log p H (mollier) diagrams for water:
Enthalpy of water at 20 *C and athmospheric pressure from mollier: 86,6 kJ/kg
Enthalpy of saturated steam (100*C): 2676,1 kJ/kg
DeltaH= 2676,1 - 86,6 = 2589,5 kJ/kg
3 litres of water = 3kg so: 2589,5 kJ/kg * 3 kg = 7768,5 kJ required to boil 3 litres of water.
However when searching for this on google i only found another solution to the problem that did not match my answer using constant specific heat capacity and heat of vaporization:
http://wiki.answers.com/Q/How_much_e...#ixzz18El72mGe
However according to wikipedia: "The specific heat capacities of substances comprising molecules (as distinct from monatomic gases) are not fixed constants and vary somewhat depending on temperature."
So using a constant heat capacity value from 20 *C to 100 *C would be wrong, no?
Are any of these methods viable? Which is better? They don't match up when i use his equation for my case (although I know it's partly because we have different values for heat of vaporization and it seems like he has mixed up some units in his description).
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
gneill
#2
Dec15-10, 10:16 PM
Mentor
P: 11,683
The specific heat of liquid water changes with temperature, but not by too much. At 20C it's 4.183 (kJ/kg/K), while at the boiling point it's 4.219. If you need great accuracy you could fit a curve and run the numbers step by step (computers are handy things).
northh
#3
Dec16-10, 10:54 PM
P: 2
Ok, I've been looking at some tables to find a constant to use. They vary greatly. Here is even one from wikipedia where the specific hc is constant but the volumetric varies with temperature:
Water at 25 C liquid: 4.1813 J/g*K - 4.1796 J/cm3*K
Water at 100 C liquid: 4.1813 J/g*K - 4.2160 J/cm3*K
source: http://en.wikipedia.org/wiki/Specific_heat
Surely this must be wrong, as 1 cm3 = 1 g for water (density 1000 kg/m3)?
gneill
#4
Dec16-10, 11:09 PM
Mentor
P: 11,683
Quote Quote by northh View Post
Water changes density with temperature. In fact, it's got an 'abnormal' density versus temperature curve compared to other substances, particularly near the freezing point.
Register to reply
Related Discussions
Salt to help water to boil General Physics 30
Boil Water At Low Temparatures General Physics 11
How can we boil water without heating it? General Physics 4
Boil water at higher pressure vs. energy consumption Classical Physics 11
At what temp does water boil? Atomic, Solid State, Comp. Physics 9
