| New Reply |
Work done by a non-reversible heat engine |
Share Thread | Thread Tools |
| Dec15-10, 09:00 PM | #1 |
Hello. I have a question about a theoretical heat engine I recently encountered in my coursework:
The setup is two chambers, one with more moles of a gas than the other, separated by a heat-conducting barrier. The right chamber has a small piston attached to it and is at a lower temperature. The right chamber also has less moles of gas than the other. Presumably, heat would flow from the isochoric left chamber into the right chamber, causing the gas to expand isobarically and do the work of raising the piston. I am certain that the transformation is isobaric, and my teacher has confirmed this in class notes. My question is whether the final temperature of the two gases will be the same as it would have been if the piston were not there and the systems were attached and the right one was isochoric. I know that the right chamber does work, but for some reason I feel as if this does not affect the final temperature. Can anyone confirm? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec16-10, 09:15 AM | #2 |
If work is done, the final temperature has to be lower. The energy transferred as work has to come from somewhere.
| New Reply |
| Tags |
| heat engine, isobaric, transformation |
| Thread Tools | |
Similar Threads for: Work done by a non-reversible heat engine
| heat engine, maximum work | Introductory Physics Homework | 6 | ||
| Reversible Composite Heat Engine 3 Reservoirs | Advanced Physics Homework | 5 | ||
| Work Done By Engine/Heat Engine | Mechanical Engineering | 3 | ||
| work of a heat engine | Introductory Physics Homework | 3 | ||
| reversible heat engine | Advanced Physics Homework | 11 | ||
