Solving for the dependant variable in sinusoidal functions .
The discussion revolves around solving for the dependent variable in a sinusoidal function, specifically using the equation h=1.55cos[360/12(t-10.75)]+2.7. Participants explore how to isolate the variable t when h is set to 3.2, addressing various steps and considerations in the process.
  • Homework-related
  • One participant initiates the discussion by asking how to solve for t when h=3.2, noting the first step of subtracting 2.7 from both sides.
  • Another participant outlines the subsequent steps, including dividing by 1.55 and applying the arccosine function, while questioning whether the angle is in degrees or radians.
  • There is a clarification regarding the expression (t-10.75) being in the second option of the equation format.
  • Further questions arise about the next steps, specifically whether to divide by 30 and how to isolate t, with a conditional note on the angle being in degrees.
Participants express uncertainty regarding the interpretation of the angle (degrees vs. radians) and the correct format of the equation, indicating that multiple views remain on these points. The discussion does not reach a consensus on the best approach to isolate t.
Participants highlight the periodic nature of the cosine function and the implications for finding multiple solutions, but do not resolve the specific mathematical steps or assumptions regarding angle measurement.
Students or individuals working on problems involving sinusoidal functions, particularly in the context of isolating variables in trigonometric equations.
hannahsiao
I have a word problem with the equation being:
Then it says let h=3.2, how do I solve this?! All I can do is take away the 2.7 and put it on the other side, but then what?
Mathematics news on Phys.org
Yes, setting h= 3.2 and subtracting 2.7 from both sides give
.5= 1.55 cos(360/12(t- 10.75))
Now, divide both sides by 1.55 to get
0.3226= cos(360/12(t- 10.75))
You could probably see that for yourself. Now, to get rid of any function on one side of an equation, use its "inverse" function. For cosine, that is the "arccosine" or [itex]cos^{-1}(x)[/itex] (NOT reciprocal!)
cos^{-1}(.3226)= 360/12(t- 10.75)
Now, I have some questions my self. Is that "angle" in degrees or radians? Normally in equations involving sine or cosine, it is radians but that "360" makes me wonder. Also is that (t- 10.75) in the denominator of numerator? Is it
[tex]\frac{360}{12(t- 10.75)}[/tex]
or
[tex]\frac{360}{12}(t- 10.75)[/tex]?
(In either case 360/12= 30.)
Finally, are you looking for a single solution, solutions in a given range, or all solutions?
Cosine is periodic with period [itex]2\pi[/itex] (or 360 degrees) so adding any multiple of [itex]2\pi[/itex] gives another solution. Also [itex]cos(2\pi- x)= cos(x)[/itex] so we have two solutions within each [itex]2\pi[/tex] interval.[/itex]
(t-10.75) is the second option beside 360/12 or 30.
so no 71(rounded)=[30(t-10.75)]
do i now divide by 30 ? and then add 10.75 to find t?
IF the argument lf cosine is in degrees and IF your angle is between 0 and 90 degrees, then yes.
