Unit tangent and normal vectors
The discussion revolves around the calculation of various vector quantities related to the parametric curve defined by r(t) = ti + t^2j. Participants are tasked with finding the velocity, speed, acceleration, unit tangent, and unit normal vectors, which involves understanding vector calculus concepts.
  • Mixed
  • The original poster attempts to compute the unit normal vector but expresses confusion regarding the algebra involved in simplifying the derivative of the unit tangent vector. Other participants question the directionality of the unit normal vector and suggest methods for finding its magnitude.
Participants are exploring different interpretations of the unit normal vector, with some suggesting that it should be perpendicular to the unit tangent. There is a mix of attempts to clarify definitions and methods, with no explicit consensus reached on the best approach yet.
Some participants reference external resources and techniques for simplification, indicating a shared struggle with the algebraic complexity of the problem. The discussion highlights the importance of understanding the geometric interpretation of the vectors involved.
cdotter
r(t)=ti+t^2j
Find the velocity, speed, acceleration, unit tangent, and unit normal vectors.
Velocity=r'(t)
Speed=magnitude of r'(t)
Acceleration=r''(t)
Unit tangent=r'(t)/magnitude of r'(t)
Unit normal=d/dt[unit tangent]/magnitude of d/dt[unit tangent]
Velocity=i+2tj
Speed=[itex]\sqrt{1^2+(2t)^2} = \sqrt{1+4t^2}[/itex]
Acceleration=2j
Unit tangent=[tex]\frac{i+2tj}{\sqrt{1+4t^2}}[/tex]
I'm pretty sure that's all right so far. I get mixed up in the algebra at the unit normal.
For d/dt[unit tangent] I have [tex]\frac{2j\sqrt{1+4t^2}-\frac{1}{2}(1+4t^2)^{-1/2}(8t)}{1+4t^2}[/tex].
Is that correct? How do I take the magnitude of that mess? I can't really see a way to simplify it.
your unit normal still has to have a direction doesn't it? if you find the i and j components, then you can find the magnitude the same way you found the magnitude of r'(t)
That's the problem, I have no idea how to simplify it to something where I can square the components, add them, and take the square root. :cry:
hi cdotter! :wink:
nooo!
the unit normal is simply the unit vector perpendicular to the unit tangent! :smile:
tiny-tim said:
hi cdotter! :wink:
nooo!
Maybe I called it the wrong thing...the principal unit normal vector?
http://www.ltcconline.net/greenl/courses/202/vectorFunctions/tannorm.htm
I just found this trick to simplify it so maybe that will work:
"Since the unit vector in the direction of a given vector will be the same after multiplying the vector by a positive scalar, we can simplify by multiplying by the factor"
haha funny thing is I was literally just reading that link. I wasn't going to send it to you because it is the exact question that you are given.
:smile: I didn't realize the exact same problem was there until you said it, I just saw the trick/technique.
ah!
as you can see, my definition also works (and is much quicker) …
the only difference is that my method comes up with two unit normal vectors (oppsotie each other),
the one you need is "is the unique vector that points into the curve", ie the one towards the centre of curvature (the concave side)
for a 3D curve, you do need the book's method, to decide which one is the principal vector
but for a 2D curve like this, just choosing the concave side is enough! :wink:
  • · Replies 22 ·
