Solving a Projectile's Flight: Help with Work and Energy Problem
  • Thread starter Thread starter rocky811
The discussion revolves around a physics problem involving a projectile's flight, specifically focusing on work and energy principles. The original poster presents a scenario where a projectile is launched vertically, and participants explore concepts related to kinetic and potential energy, as well as the effects of air resistance on the projectile's maximum height.
  • Participants discuss the application of the conservation of mechanical energy to determine the maximum height of the projectile. Questions arise regarding the calculations for kinetic and potential energy, and the impact of air resistance on the results. There is also exploration of the work-energy principle and how to incorporate air resistance into the calculations.
The discussion is active, with participants sharing their calculations and questioning each other's reasoning. Some guidance has been offered regarding the application of energy conservation and the relationship between work done by air resistance and changes in energy. Multiple interpretations of the equations and concepts are being explored, indicating a collaborative effort to deepen understanding.
Participants are navigating the complexities of incorporating air resistance into their calculations, with some expressing uncertainty about the correct approach to take. There is mention of specific values and equations, but no consensus has been reached on the final calculations or methods.
rocky811
Hi guys! I need some help :)
A projectile of mass 0.709 kg is shot straight up with an initial speed of 18.7 m/s. (a) How high would it go if there were no air resistance? (b) If the projectile rises to a maximum height of only 7.58 m, determine the magnitude of the average force due to air resistance.
So I figured out how to do part a) by setting KE=PE and solving for h. I just don't know what to do to solve for part b. I have been trying to find the work and the plug the work into the W=FdCos (theta) equation, but I can't seem to get the right answer.
THANKS!
let me see your second part, show the work.
I have a question first, for part a I set KE=PE...so I did (.5*.709*(18.7^2)) and I got 123.965. I took that value and divided that by (.709*9.8) and I got 17.84m...which is close to what the real answer should be (17.66111 m)...do you know why it's off or is it because I am using an equation that I shouldn't?
Okay, for part b:
I know what W=FdCos (theta) and also that W=mgh (PE)...So I was thinking of just plugging in (.709*9.8*7.58) which equals 52.667J. Should I plug that into the W=Fdcos (theta) or not??
The first part is right
Applying Law of Conservation of Mechanical Energy
[tex]K_{o} = \Omega_{maxHeight}[/tex]
For the second part
Conservative Systems Work:
[tex]W_{conservative} = -\Delta \Omega[/tex]
Because the work done by air resistance forms an angle of 0 degrees with the displacement vector, it will be positive.
[tex]Fd = -\Delta \Omega[/tex]
[tex]F = -\frac{\Delta \Omega}{d}[/tex]
Also because the initial Yo is 0, it will be mgY.
Is your equation F=delta omega/d...is the delta omega the addition of the change in potential and kinetic energy? And are you trying to say that because the object starts from the ground, that the initial PE is O...so you only use the final?
[tex]\Delta \Omega[/tex] is the way i was taugh to represent Potential Energy, and it's the change of Potential Energy, mgy - 0, in this case. Btw y = d, i forgot to use the same variable :smile:
Okay so I can say that the change in potential energy is (.709*9.8*7.58) which gives me 52.66 J...I just don't know what distance to divide by though...grr...i guess i better search my book again :/ thanks for all of your help though :) I appreciate it.
I got it! I didn't realize that I had to factor in air resistance and I found a similar problem which dealt with air resistance...so yay! thanks again! :)
  • · Replies 38 ·
