What is the Coefficient of Friction Between Two Blocks on a Horizontal Surface?
The problem involves two blocks on a horizontal surface, where one block is stacked on top of the other. The blocks are subjected to a force and are required to move together without sliding. The question focuses on determining the frictional force between the blocks.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the forces acting on each block and attempt to set up equations based on free body diagrams. There is a focus on the relationship between the frictional force and the applied force, as well as the acceleration of the blocks. Some participants express confusion regarding the number of unknowns and the interpretation of the question.
Some participants have provided insights into forming equations based on the forces acting on the blocks. There is an ongoing exploration of the relationships between the forces and the masses involved. A few participants have indicated a shift in understanding regarding what the question is asking, particularly about the frictional force versus the coefficient of friction.
One participant notes the absence of a diagram, which may affect the clarity of the discussion. There is also mention of multiple unknowns in the equations, which could complicate the problem-solving process.
PinkDaisy
The question is:
"Two blocks are accelerated across a horizontal frictionless surface as shown. Frictional forces keep the two blocks from sliding relative to each other, and the two move with the same acceleration. What is the magnitude of the horizontal component (frictional force) of the force exerted on the small block by the large block?"
The mass of the small block on top is: M ,the mass of the bottom block is: 2M , and the force, P is: 3 N.
I drew the FBD's, block M has three forces: n1 (up), Mg (down), and f (right). Block 2M has 5 forces? P (right), 2Mg (down), n1 (down), n2 (up), and f (left).
I can't seem to get it, there appears to be too many unknowns to me.
I appreciate any help. Thanks!
No picture for us to see?
[itex]\sum \vec F=m\vec a[/itex]
You know the acceleration. Without a picture its hard to determin if your assessments are correct. The force of friction will act in the same direction as the motion of the lower block. You know the masses of the blocke. you can form two equation--one f=ma for each block and you have two unknowns. You should be able to get an answer.
Of those 5 forces can't you relate them so that they are all in terms of M and f? Give it a try and see. Remember the top block's M is the same as the bottom block M--there's just two of them on the bottom though. The frictional force on the top block is the same as on the bottom block too.
Anyway, hope this helped. Show what you've done if you need more help. From what I can see your assessment of the forces is correct but without a picture I can't be 100% sure.
Sorry about no picture. It is a surface with two boxes stacked on each other with the smaller one on top. The force P pulls the bottom box to the right.
These are my equations but then I don't know where to go.
\sum Fy (M) = n1 - mg so n1=mg
\sum Fx (M) = f1 = ma so \mu mg = ma
\sum Fy (2M) = n2 - n1 - 2Mg = 0 so n2=3Mg
\sum Fx (2M) = P - f2 = 2Ma so P-\mu(3Mg)=2Ma
OHH! I think I finally got it!
I took both of the \sum Fx equations and solved them for ma then set them equal to each other and then solved for f.
f=ma and (P-f)/2=ma
f=(P-f)/2
P=f/3
I was confused by the question, I thought that it wanted me to solve for \mu, but it was really asking about f.
Right?
PinkDaisy said:
f=ma and (P-f)/2=ma
f=(P-f)/2
P=f/3
That last equation should be P = 3f so f = P/3.
Oops, you are exactly right. The excitement from finally conquering the problem caused my fingers to malfunction! Thanks for the help!
