Understanding Pressure Drop in Parallel Piping Systems
The discussion revolves around understanding the pressure drop in parallel piping systems, specifically whether the pressure drop across a supply and return header is equal to the pressure drop across one of the components or if it follows a different calculation method. The context includes theoretical considerations and analogies to electrical circuits.
  • One participant questions whether the pressure drop across the supply and return header is equal to the pressure drop across one component (15 psi) or if it should be calculated as the inverse of the sum of the inverses (5 psi).
  • Another participant requests additional details about the dimensions and orientations of the pipes involved in the system.
  • A participant asserts that the pressure difference would be 15 psi, arguing that pressure between any two points remains the same regardless of parallel paths or varying cross sections.
  • Another participant agrees that the pressure drop would be 15 psi and clarifies that pressure drop is analogous to voltage drop in electrical circuits, not resistance.
There is a disagreement regarding the calculation of pressure drop in parallel piping systems. Some participants argue for a pressure drop of 15 psi, while others suggest a different approach based on circuit analogies.
The discussion lacks specific details about the dimensions and orientations of the pipes, which may influence the pressure drop calculations. There are also unresolved assumptions regarding the applicability of electrical circuit analogies to fluid dynamics in this context.
Individuals interested in fluid dynamics, engineering principles related to piping systems, and those exploring analogies between electrical circuits and fluid flow may find this discussion relevant.
abiehl
I have a question about network flow pressure drop. In a piping system with several identical components in parallel, is the pressure drop across the supply and return header equal to the pressure drop across one of the components? Or is it the inverse of the sum of the inverses? To use numbers for clarity, if you have a supply pipe, A, which feeds pipes B, C, and D, which have components each with a pressure drop of 15 psi, and which feed pipe E, is the pressure difference from pipe A to pipe E 15 psi or 1/(1/15+1/15+1/15) = 5psi? A pressure drop of 15 psi makes more sense to me, but I thought that pipe networks were analogous to electrical circuits such that pressure drop is analogous to resistance.
Please mention the dimensions of the pipes and their orientations in relation to one another.
Hey according to me the pressure difference would be 15 psi and not as electrical circuits.Pressure between any two points is always same irrespective of how many parallel paths or any different cross sections it has got in between those two points
Yes the pressure drop would be 15 psi as you suspected. Your analogy is slightly off. Pressure drop is analogous to voltage drop and not resistance.
:approve:
Yeah.Thanks for correcting me.
  • · Replies 38 ·
  • · Replies 31 ·
