| New Reply |
An absolute time clock! |
Share Thread | Thread Tools |
| Dec28-10, 11:09 PM | #69 |
An absolute time clock!The pulse arrives at B at Bu + B1 where B1 is the TOF of the pulse from A to B and Bu + B1 is a recorded value. The pulse returns to A at A2 at which time the B clock is Bu + A2 = x1 (recorded). At A2 another pulse is emitted arriving at B at Bu + A2 + B1 = x2 (recorded) Subtracting x2 - x1 = Bu + A2 + B1 - A2 - Bu = B1 the TOF of the pulse from A to B. and where this time is the used to synchronize both clocks, perfectly. Now the outbound and inbound trajectories are B1 - A0 and A2 - B1 respectively with C = 1 the unit SOL. The difference in the distances are B1 - A0 - (A2 - B1) = 2B1 - A2 + A0 which is the distance of travel of the two transponders which remain a constant distance D apart. D = Vab(A2 - A0) = 2B1 - A2 - A0 Hence Vab = [2B1 - (A2 + A0)]/(A2 - A0); or for A0 = 0 , Vab = 2B1/A2 -1 AE had never had the opportunity to consider transponders which are standard air traffic control devices used world wide and where the emission and receipt/reflection times are imbeded in the pulse signal. |
| Dec29-10, 04:32 AM | #70 |
Ymyk, it is very difficult to understand your scenario. It appears that you are using some of your nomenclature to refer to absolute times (A0, Bu, A2?) and others for delta times (B1). But whatever you are doing, it is not legitimate. You cannot measure the one-way speed of light. You cannot tell how long it takes for light to go from A to B or B to A without some previously defined answer to the question. I'm sure that transponders are relying on a previously defined timing conventions and so cannot be used to measure the times of receipt/reflection as you are proposing. You should be able to figure out what is wrong with your idea if you understand Special Relativity. In fact, you wouldn't even attempt to find a way around the problem. You do realize that if what you are proposing is legitimate, that you have just dethroned Einstein and you will be able to take his seat. Is that what you really believe?
| Dec29-10, 04:34 AM | #71 |
You're going to have to be patient with me. I'm working on some animations to illustrate the ideas I'm presenting so it will take me some time but I think in the long run this will be much more effective. |
| Dec29-10, 07:28 AM | #72 |
The transponders are identical in all respects. My argument is straightgforward. A0 is the time imbeded in the outbound pulse in the direction of the B transponder. At A0 the B clock is unknown, or Bu, a recordwed vcalue. When the pulse arrives at B the B clock registers Bu + B1 , where both Bu and B1 are unbknown but their total clock value is recorded when the pulse arrives. In other words the pulse simple tells the clock to give out the current clock time, he Bu + B1. When the pulse returns to A at A2, the B clock now reads Bu + A2, again recorded as x1. Immediately emitting a pulse from A where the clock now is A2, arrives at B at Bu + A2 + B1 = x2 subtracting thye two x's x2 - x1 = Bu + A2 + B1 - Bu - A2 = B1, which is the time of flight of the pulse from A to B. There is no measure of the SOL which is presumed to be constant at unit SOL C = 1. The two clock are ticking at the same rate and even thoughn there was initially no information of what the clock time on B happened to be when the A clock reas A0. There is also the presumption that the motion of the [pulse is independent of the motion of the source of the light - I already knew what the SOL was before the pulse motions began. The repeat of the round tripm trajectory was intended for the purpose of determining what the instantaneous clock time difference of the two transponders happened to be. The transponders work as I have indicatedbut I am sure that the system disrfegards any relativity effects for the reason thagt the velocities are soi slow. Look at it as two clocks separated by a constant distance. On clock emits a pulse at A0 when the B clock time is inknown or Bu, a time recorded when triggered by the arriving pulse. We don't even need to imbed the time of arrival in the reflected pulse. As long as the A transponder has the A0 and A2 times recorded and the B clock has the Bu + B1 time recorded. Calculating the trajectory distances is then trivial and can be accomplished at the observer's pleasure. You made a great deal claiming that I couldn't measure the one way sol. I didn't try to measure the sol. I already knew the sol as approximately 3x 10^8 km/sec which IO copied out of AE's book "relativity". AE didn't know about transponders in 1905. I didn't violate any relativity concept. In fact I claim that determining the velocity of the transponder is determined soley from the three time-of -day events A0, A2, and B1. Which is NOT a measurement of the velocity NOR detection of motion. The three event times are carefully recorded. |
| Dec29-10, 07:35 AM | #73 |
Mentor
If you set up the equations without that assumption then you will find that you always have more unknowns than equations. |
| Dec29-10, 10:37 AM | #74 |
ghwellsjr,
No problem, I am here and waiting. Roi. |
| Dec29-10, 11:11 AM | #75 |
| Dec29-10, 10:55 PM | #76 |
Hello,
All we are trying to build is an Absolute time clock, lets follow the rules of Physics and see if it works, We all know that light beam acts like a wave too, and it has some frequency. And this frequency changes with the motion of the light source, (red shift or blue shift depending on the direction) So let us place a light source and a frequency detector on both ends of a stationary train, and claculate the frequency of the light beam emitted from the light source, What ever this frequency is, Set the speed to zero. (Reletive to the Earth, of cource) Now if the train starts to accelerate/travel to any direction the shift in frequency of the light beam should be detected and claculated to determine the speed of train. Hence these calculated values can be added to a conventional clock onboard which is loosing time because of motion. And we get an Absolute clock for the Earth. (For the Universe it will be a whole new story) I'm not sure, but this is my two cents. |
| Dec30-10, 01:04 AM | #77 |
No, there might be a momentary shift in the color of the light (frequency) during the acceleration but as soon as the effect of that is over, the detected light and the unboard clock behave just like they did before the acceleration. But you could use this or any number of other means to measure/calculate the speed of the train.
Now you have a situation where there are two clocks in relative motion. Each clock sees the other one as running slower than its own. Neither clock can be considered Absolute. In fact, you can view both clocks from any frame of reference, including one that is the "average" speed of the two clocks in such a way that they both appear to run at the same rate (both slow in that reference frame). An Absolute clock is considered one that is stationary in the so-called, presumed, universal, at-rest ether which no one knows how to identify if it were to exist and so there is no hope to have an Absolute clock. |
| Dec30-10, 04:34 AM | #78 |
I have uploaded some animations to illustrate the scenarios in my previous post:
| Dec30-10, 05:57 AM | #79 |
Now it's really not practical to build a solid sphere of mirrors but all we really need is four mirrors that are placed 90 degrees apart and all equidistant from the observer. In this animation, I have used circular mirrors so that when the light strikes them, they create a new expanding circle of light.
http://www.youtube.com/watch?v=ygvY4AjwPmE I represent the stationary observer in green and I call him Homer (think green, green grass of home). I represent the original expanding circle of light in blue as well as a blue dot to represent its source, the mirrors in brown, the collapsing circles of light in green when they reflect off stationary mirrors. Please note that just as in the previous post when the collapsing circle of light arrived simultaneously from all directions on the observer, the four reflections from the four mirrors all arrive simultaneously on the observer. Although this is not actually how the MMX was configured, it still represents conceptually exactly what the experiment was doing. The MMX experimenters assumed that the previous animation would represent only what would happen if they were stationary with respect to the ether which they believed they never were. They believed that they were constantly moving with respect to the ether and also constantly changing their velocity through the ether as the earth rotated on its axis and as it revolved around the sun. This constant acceleration was very small so for all practical purposes, they could assume that they were moving at a constant speed through the ether. This is how they thought the light would behave: http://www.youtube.com/watch?v=U625Pjm9M-I I represent the moving observer in red and I call him Rover (think Red Rover). The light that reflects off the moving mirrors is shown in red and a red dot is placed at the origin of each expanding reflection. Note that when the light from the four mirrors arrives at Rover, it is not simultaneous, it first arrives from the top and bottom mirrors and then later arrives from the left and right mirrors. This is what the MMX experimenters expected to measure but instead, they got the same result as if they were stationary in the ether, the same result the Homer would have gotten. So now the question is how can this happen? Well, Lorentz and others came up with an explanation and we will go through a process that will arrive at the same explanation. First, we want to learn how we know where to put the mirrors so that the expanding circle of light can create a reflection that results in a collapsing circle of light in just the right place at just the right time. For Homer, it's easy: http://www.youtube.com/watch?v=Y0XWb6Il92A Just note the intersection of the blue expanding circle and the green collapsing circle and in this animation, we draw a black dashed line to show where that intersection occurs: http://www.youtube.com/watch?v=7VftpL1KL6o Now for Rover, it's a little more complicated because his collapsing circle of light is not centered on the expanding circle of light but rather the location of where he will be later on, shown as a red dot. Try to visualize in this animation where the blue and red circles intersect: http://www.youtube.com/watch?v=dHO6jtkDXM8 And here we have the black dashed line to show the points of reflection: http://www.youtube.com/watch?v=q9qJhCaHotI Now this black dashed line shows the points of relection relative to the ether but we really want them relative to Rover, so here we show both for comparison: http://www.youtube.com/watch?v=sE0G1wcvrRI Also, note that Lorentz realizes that everything contracts in the direction of motion so we now show Rover as being length contracted as well as his circular arrangement of mirrors. In addition, the time it takes for the light to traverse from Rover to the mirrors and back to Rover is longer than it was for Homer which illustrates time dilation. We can also see the issue of Relativity of Simultaneity because the reflections for Rover do not all occur at the same time whereas they do for Homer. http://www.youtube.com/watch?v=S7r5GeIfZas This illustrates how Lorentz believed MMX produced the null result. He believed that the experiment was moving through the ether and experienced length contraction, time dilation and relativity of simultaneity. He also believed that Rover would measure the speed of light to be the same as Homer because even though time was going slower and stretching out (time dilation), it is the actual length that the light has to travel relative to the ether that is used to calculate the speed (length divided by time), so we need to use the lengths defined by the black dashed line, not the moving brown line representing the length contracted mirror. This length is dilated to the same extent that time is dilated and so the two dilations cancel each other out and give the same calculation for the speed of light. However, Einstein put a new spin on the interpretation. He said that we could assume that MMX was actually stationary in the ether and everything else that was moving with respect to MMX was experiencing length contraction, time dilation and relativity of simultaneity. |
| Dec30-10, 06:31 AM | #80 |
Quick question... what's the point of trying to design a clock (I realize you're arguing against it, not for it) to measure something that modern physics tells us is NOT absolute and universal? I must be missing something critical... I thought that one of the central tenants of relativity was the inability to define the passage of time in absolute terms for anything other than an ether? This thread seems like a backwards argument to get to that absolute frame of reference, but using time as the hook instead of relative motion. |
| Dec30-10, 09:43 AM | #81 |
I have more animations to show how Homer and Rover both think they are in the center of the expanding circle of light and how they each see that the other one also thinks he is in the center, but I want to let this one sink in first. |
| Dec30-10, 10:22 AM | #82 |
| Dec30-10, 10:23 AM | #83 |
ghwellsjr,
I need some time now to learn the text and animations. If you have more, please let me know. Thanks, Roi. |
| Dec30-10, 10:31 AM | #84 |
So do you agree with me that this arrangement will work only while acceleration, but not in constent velocity situation? If yes, I can put another experiment to show that it is possible to build a clock that will not loose its time because of motion, In simple words, A clock that will keep time with my home clock, no matter what, even if you put it on a jet, a rocket, or any thing faster than that. It should keep its time. I'll give it a try, may be I'm missing something? |
| Dec30-10, 10:47 AM | #85 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: An absolute time clock!
| Time Dilation Light Clock Example | Special & General Relativity | 16 | ||
| Preception of time on a Clock. | General Physics | 3 | ||
| How Does a Clock Measure Time? | Special & General Relativity | 4 | ||
| The light clock and time dilation. | Special & General Relativity | 3 | ||
| a photonic clock - absolute time | General Physics | 23 | ||
