Is the flow of my logic flawed?
  • Context: High School
  • Thread starter Thread starter TylerH
    Flow Logic
The discussion revolves around the logical reasoning concerning the nature of numbers, particularly focusing on the implications of equality and the existence of numbers between two values. Participants explore concepts related to real numbers, naming conventions, and the implications of decimal expansions.
  • Some participants propose that if two numbers are not equal, there are infinitely many numbers between them, leading to the conclusion that equal numbers have zero numbers between them.
  • Others argue that the middle statement in the original reasoning may not be necessary and that the first implication does not logically support the conclusion drawn.
  • One participant expresses a concern about the implications of considering .999... and 1 as equal, questioning the existence of numbers that cannot be named.
  • Another participant suggests that the definition of "naming" a number is crucial, noting that many real numbers cannot be represented by decimal expansions.
  • Some participants discuss the validity of using logical notation to clarify the reasoning process, suggesting that the original logic may be sound when expressed in formal terms.
  • There is a mention of the existence of uncountably many real numbers in set theory that cannot be defined or computed, challenging the notion that numbers must be named to exist.
  • Participants also explore the idea that naming a number can extend beyond decimal expansions to include properties or definitions, such as those used for irrational numbers like pi.
Participants do not reach a consensus on the implications of the original logic or the nature of naming numbers. There are multiple competing views regarding the definitions and existence of numbers, particularly in relation to decimal expansions and set theory.
Limitations include varying definitions of what it means to "name" a number, the dependence on interpretations of decimal expansions, and unresolved questions about the implications of equality between .999... and 1.
TylerH
If two numbers are not equal, there is infinitely many numbers between them. Therefore, numbers that are equal have a finite amount of numbers between them, 0. Therefore, numbers with a finite amount of numbers between them are equal.
Mathematics news on Phys.org
Assuming you mean real numbers with the usual order relation (without entering into a debate about whether this needs to be said, please)... this sounds correct. It's the contrapositive of a true statement, after all.
... Also, I guess if you're concerned about the flow of your logic, then I could say that you don't need the middle statement here, for the reason I pointed out above.
Thanks. I know it sounds like a "duh!" question, but it has implications. I was considering 1 = or != .999..., and the thought about there being infinitely many [real] numbers between two numbers came to me. One can name no numbers between .999... and 1.
My understanding of numbers is that they do not exist until named, and cannot exist if they cannot be named. The argument would rely on this being true, which it is, isn't it?
Also the middle statement doesn't follow from the first statement (even if it's true) so the first use of "Therefore" is wrong.
Well, first of all, what does it mean to "name" a number? By that, do you mean "I can write it down"? Then it seems you would have to decide whether you are accepting formulas that stand for numbers that have an endless string of digits after the decimal--e.g., Pi, e, and your example of .999... In that case, then there are proofs that .999... = 1 with any desired level of rigor--just see http://en.wikipedia.org/wiki/0.999...
If you are not accepting formulas, then you can't "name" .999..., anyway--in fact, you can't "name" most of the real numbers (we know how to write only a handful of transcendental numbers, yet we know that most real numbers are transcendentals). Yet, they're still there.
EDIT: Well, really, you can "name" .999... since you'll always know the next number. But still most of the reals cannot be represented this way; there are numbers whose approximation by rationals will display no pattern at all, in fact.
Hi, TylerH!
It will be useful for you to develop logacial notation skills, so that you more easily see whether your implication is valid.
Let "A": Two numbers are not equal.
"B": There is an infinity of numbers between two numbers.
Thus, your premise is: If A, then B.
This is logically equivalent to its contrapositive form:
If Not-B, then Not-A
Not-B: Not infinitely many numbers netween two others (meaning there exists a finite amount of such, regarding NO numbers between them as 0)
Not-A: Two numbers are not not equal (meaning they are equal).
Thus, your logic is fine. :smile:
Actually, in set theory there are uncountably (even co-countably) many real numbers that cannot be defined, and even more that cannot be computed. So there definitely does exists a lot of "unnamed" real numbers in set theory.
arildno said:
Hi, TylerH!
Actually that sounds much more native to me than you would think. I'm a CS nerd with a very good understanding of that sort of boolean logic. It's just that your approach at reasoning, and turning English into boolean logic, for some reason, didn't occur to me as a possibility. I wasn't in the words to logic mindset I guess.
It's hard to say anything about that, unless we know what YOUR definition of the meaning of ".999..." is.
If you think ".999..." means "the limit of the sequence .9, .99, .999, ..." , then (since the terms in the sequence is the sum of a geometric progression) ".999..." is just another name for "1".
On the other hand, if your definition is different (or if you haven't yet really nailed down WHAT your own definition is) then all bets are off until after you have defined it.
Once again, it depends what YOU mean by "named", and you haven't told us that.
But you are on a slippery logical slope here. I suppose you probably accept that "the ratio of the circumference to the diameter of a circle" is the name of a number - otherwise usually called "pi".
If so, you accept that numbers can be "named" in other ways than by a sequence of digits. Nobody knows the complete (infinite and non-repeating) sequence of decimal digits of pi, so nobody can "name" it except by stating some property that it has, like my definition above.
So if you agree with that general idea about "naming" then what about "The smallest positive number that cannot be named". Is that the name of a number, or not?
If you think not, how do you propose to define what "naming" means, so you can always tell whether "names" like that are valid or invalid?
Here be (probably an uncountably infinite number of) dragons ... :devil:
When I say name a number, I mean a decimal expansion. Anything that can be decimally expanded is valid. The reason for decimally expanding is to make it more clear in what interval a number lies. Like sqrt 2 or 1.41...[the ellipsis in this case means more digits, not repeating digits], so we know that it must be between 1.41 and 1.419.
I've seen the Wikipedia article, but I prefer my way for its simplicity. But sometimes simplicity leaves a residue of ambiguity. That's why I come here to consult those smarter and better educated than myself.
If that is what you mean by "naming" a number, then all real numbers can be named.
I included the link to the Wikipedia article not to suggest a method of proof, but to show that as long as you're allowed to "name" a number by writing a series for it, there is nothing wrong with the argument.
Also let me point out that no one has ever actually written down the decimal expansion of most numbers, and that there would be no rule by which to write them all down (so you couldn't name them all even if allowed an infinite amount of time). They exist in spite of this.
I agree with that, but the OP's idea of "naming" has the strange property that there are numbers (in fact, almost all real numbers) which can be named, but it is impossible to actually say what their names are, because there is no method of computing the digits that make up the name.
No one seems to have commented on this, so I will. Two numbers that are equal have no numbers between them. The distance between the two numbers is zero. The interval containing the two (equal) numbers consists of a single point.
I don't see the advantage in distinguishing between an infinite number of numbers between two given numbers, and a finite number (i.e., zero) of numbers.
I doesn't matter that you can't write or compute the whole decimal expansion of a number. The numbers can be named that they can be named to the point necessary. The point is to name the bounded region they exist in. You can name sqrt 2 as 1.4... and you know it is more than .999..., that's all the info I need to accomplish my ends, the rest is extraneous.
Mark44: I completely see your argument. The problem is that when I argued 1-.999...=0, my friend said 1-.999...=1/∞, which is right, but he refuses to admit that limits are the constant value that is approached(0, in this case), rather than the never ending sequence. He's stuck on "it will approach, but never equal" which forces me to have to try to come up with some contrived real number theory method of proving I'm right. I know that his interpretation of a limit as an infinite process of approaching is wrong, but I have no way to argue it. Suggestions?
ask him what he means by .999... Mathematicians define it to be a limit. The limit by definition of limit equals 1. Once he understands that .9999… is just a short hand notation for a limit it’s hard to argue it doens't equal one. For him to say .9999… doesn’t equal one is like arguing the limit as x goes to infinity of (x+1)/(x-1) isn’t equal to 1.
No, he knows it's a limit. He's just got a messed up understanding of limits. He says they "approach" as if approaching is an infinite process of almost equaling.
It's hard to explain his views. Here's a short excerpt:
Me:
In short, given that .999... = lim{.9, .99, .999, ...}, and as you just admitted, lim{.9, .99, .999, ...} = 1, we can use the transitive property of equalities to say .999... = lim{.9, .99, .999, ...} = 1, therefore .999... = 1.
Him:
In the sense of a limit, it does equal one. However, it is nonetheless a limit.
Me:
What other sense can a limit have, other than that of a limit?
Him:
No matter what view you take this problem from, it will always have to have a limit. Whenever you deal with infinite numbers, you have to have a limit meaning that the answer you get will only ever approach.
Then he needs to define what he means by limit, because the word limit in this context for math means:
Limx →pf(x)=L if and only if for any given ε > 0 there exists a δ > 0 such that 0 < | x − p | < δ implies | f(x) − L | < ε
Notice the limit is equal to L with the "=" symbol by definition, nowhere is the "≈" in this definition.
I've pretty much tried that:
Me:
It is incorrect to say that a limit approaches but does not equal. The value a limit approaches defines the value of the limit itself, thus approaches implies equals.
Him:
You are correct in saying that mathematical notation and pragmatism enforce the use of "equals" when evaluating limits. However, when you deal with infinity, it is a touchy subject. You can never actually plug in infinity, so the limit you take will always only be moving toward the value in theory.
Is there any good reference that explicitly states that limits equal a value? Wikipedia won't work.
Any calculus textbook should state the formal definition of a limit I’ve given you.
And infinity is not a touchy subject. It has a precise mathematical definition in this context:
Limx →∞ f(x)=L if and only if for every ε>0 there exists N > 0 such that |f(x) – L| < ε whenever x > N.
Limits have nothing to do with plugging stuff in. A limit is a precise mathematical concept. The words “plug in” don’t appear anywhere in the definition. Your friend is trying to redefine terms to make himself right.
I don't think it's contrived at all! In fact it's my favorite way of saying that .999...=1. You only need a basic fact about the real numbers and waam! It's done.
And if he refuses to agree with a formal definition, then you are wasting your time. He is not talking about the same mathematics you are talking about.
No, it isn't. 1/∞ is not a number, so it can't be the answer to a subtraction problem. The correct answer to 1 - .999... is 0.
Perhaps you might ask him what he "means" by a real number.
For example, how do you construct them?
By Dedekind cuts, perhaps, or as equivalence classes of bounded, increasing sequences?
No, you cannot write a decimal expansion for any real number constructible in set theory. Chaitin
s constant, the probability that a randomly chosen program will halt, is definable in set theory (thus a unique number), but is not computable. You cannot be guaranteed that any attempt of yours to compute it will converge to the constant.
  • · Replies 17 ·
  • · Replies 40 ·
