Help with resolving along a plane
  • Thread starter Thread starter horseman
    Plane
This discussion focuses on resolving forces along an inclined plane, specifically for a pipe inclined at an angle theta to the horizontal. The user seeks assistance in determining the necessary distances to include in their equations, having already calculated the normal reaction force. Key steps include drawing a free body diagram, identifying forces acting on the pipe, and resolving these forces into components parallel and perpendicular to the inclined plane. Understanding these concepts is crucial for accurately solving the problem.
  • Understanding of inclined planes and angles (theta degrees)
  • Knowledge of free body diagrams and force resolution
  • Familiarity with normal reaction forces and their components
  • Basic principles of static equilibrium in mechanics
  • Study the principles of force resolution in mechanics
  • Learn how to draw and analyze free body diagrams
  • Explore static equilibrium conditions for inclined planes
  • Investigate the effects of friction on inclined surfaces
Students in physics or engineering, mechanics enthusiasts, and anyone involved in solving problems related to forces on inclined planes.
horseman
Hi i have a problem withresolving along a plane, i have a pipe inclined at theta degrees to the horizontal thet is being held in position by two pipes, one that is positioned a from its weight under the pipe and one that is positioned b from the weight on top of the pipe. i have taken moments about the pipe that is located over the pipe and found an expression for its normal reaction force but no i need to resolve along the plane and have no mass moving along the plane so i don't know what kind of distances i need to include in my equation? If anyone could advise me on this the help would be greatly apprieciated
This question, as stated, makes no sense at all. How about copying the problem exactly as it was given?
Resolving along a plane involves breaking down forces into components that are parallel and perpendicular to the plane. In this case, the plane is the inclined pipe. To resolve forces along the plane, you will need to consider the weight of the pipe and the normal reaction force from the supporting pipes.
First, draw a free body diagram of the inclined pipe and label all the forces acting on it. This will include the weight of the pipe, the normal reaction force from the supporting pipe at a distance a, and the normal reaction force from the supporting pipe at a distance b.
Next, you will need to resolve these forces into components that are parallel and perpendicular to the inclined pipe. The weight of the pipe will have a component parallel to the plane, which will contribute to the force that is causing the pipe to slide down the plane. The normal reaction forces from the supporting pipes will also have components that are parallel and perpendicular to the plane. The perpendicular component of these forces will balance out the weight of the pipe, while the parallel component will contribute to the force that is keeping the pipe in place.
To find the distance that needs to be included in your equation, you will need to consider the distance between the point of application of the forces and the point where you are resolving the forces along the plane. For example, if you are resolving forces at the top of the pipe, then the distance between the point of application of the normal reaction force from the supporting pipe at a distance b and the top of the pipe will need to be included in your equation.
I hope this helps you understand how to resolve forces along a plane. It is important to carefully consider all the forces and their components in order to accurately solve the problem. If you are still having trouble, I would suggest seeking the guidance of a tutor or your instructor for further assistance. Good luck!
