Why Are Absorption Lines Observed Only in the Lyman Series for Hydrogen?
The discussion revolves around the observation of absorption lines in the Lyman series for hydrogen when white radiation is passed through a hydrogen gas sample. Participants are examining the energy levels and transitions of electrons in relation to the photon energy range of visible light and its implications for the absorption spectrum.
  • Participants are questioning why absorption lines are only observed in the Lyman series rather than the Balmer series, considering the energy levels required for electron transitions. There is also a discussion about the initial energy level needed for a hydrogen atom to absorb a photon in the Balmer series.
The discussion is active, with participants exploring the implications of the energy levels of hydrogen atoms and the conditions under which absorption occurs. Some guidance has been offered regarding the assumptions about the state of the hydrogen atoms and the energy required for transitions.
There is a noted assumption regarding the distribution of hydrogen atoms in energy states, as well as the lack of explicit information about the energy of the photons interacting with the hydrogen gas sample.
aim1732
When white radiation is passed through a sample of hydrogen gas(atoms assumed actually) why are absorption lines observed in Lyman series only?
The corresponding photon energy range for visible light(380-780nm) are 1.59-3.27eV which should cause transitions of electrons in the first excited state(n=2) only.This should give absorption spectrum lines in Balmer series.Am I wrong?
Please,I am studying Bohr's model and any explanation involving quantum physics(except of course the very basics) will not be clear to me.
In what energy level should a hydrogen atom in the sample be in order to absorb a photon in the Balmer series? That is, what should the initial value of n be?
Second,of course(n=2).
But it is not mentioned in the question that the atoms are in ground state hence I assumed a random distribution. Anyways it takes a minimum of 10.2eV to excite an electron from n=1 shell which is clearly not available for photons of visible light.
Correct. Although the question does not mention it, you are supposed to figure it out and you have. The question also doesn't mention that the sample of hydrogen is bathed in 10.2 eV photons, therefore it is a good assumption that it is not.
It exactly depends on the state of the atom .For Lyman Series the shortest wave length is 91.2 nm correspond to 13.6 ev and the longest is 121.5 nm correspond to 10.2 ev and all other wavelength in this series are between these 2 limits.So it is clear that this series contains only ultra violate waves.
