Why Cant I Figure this stuff out
  • Thread starter Thread starter derekbeau
    Figure
The discussion revolves around a physics problem involving a father and son in a boat, where various actions are taken that may affect the water level. The subject area includes concepts of buoyancy, displacement, and weight in fluid mechanics.
  • Participants explore the effects of different actions on water level, such as popping a helium balloon, drinking water, and displacing water by entering or exiting the boat. There are attempts to reason through the implications of weight and displacement, with some participants expressing confusion over their conclusions.
Several participants have revised their answers based on feedback but continue to seek clarification on specific scenarios. Some guidance has been offered regarding the relationship between weight and water displacement, yet multiple interpretations of the problem remain under discussion.
Participants note the importance of defining what is meant by "water level" and how it is measured, indicating potential confusion stemming from different reference points in the problem.
derekbeau
I need to tell wether the water level rises, falls, is unchanged, or cat tell. The father and son are in a boat wearing lifejackets.
The son pops a helium filled balloon that he is holding by a string.
(Id say unchanged since the balloon is floating in the air right)
The fisherman fills a glass with water from the pond and drinks it.
(No idea, but i would guess that it stays the same since the weight is being put back into the fisherman)
The fisherman lowers himself in the water and floats on his back.
(Raises because more water is being displaced now?)
The son gets in the water and pops the floating helium ballon
(Raises because the son is displacing water?)
The fisherman knocks the tackle box overboard and it sinks to the bottom.
(Falls because the tacklebox was floating in the boat, now it is skinking to the bottom and displacing less water)
The fisherman lowers the anchor and it hangs one foot above the bottom of the pond
(Falls, same reason as above)
but my answer is wrong and I dontknow where, please help
Thankyou
Thankyou
you are confusing the concepts of weight and volume.
i don't understand, the only area where i mentioned weight was in the glass of water, i tried all possible answers for that one, but there are other ones wrong
could you tell me a set of rules or explain it more so that i can understand it better?
thanks
Ok i have revised my answer but it is still wrong, could you please tell me which ones are wrong
im confused on this one
unchanged because the displacing bodies are still the boat + the fisher
unchanged because the displacing bodies are still the boat + the son
(Falls because the tacklebox was floating in the boat, now it is sinking to the bottom and displacing less water)
unchanged because the anchor is still pulling the boat down
this is the only problem i am still having trouble with, I've been reading as much as i can on the internet and can't seem to get the correct answer, if anyone could explain each situation to me, that would be great
can anyone help?
well this question is due in 8 hours and I still can't figure it out. This will be the last time i bump it up to try and get an answer. Can i please get some help here?
OK:
If the amount of weight that's being floated increases, the water level rises. If the amount of weight being floated decreases, the water level drops. If the amount of weight being floated doesn't change, then the water level stays the same as well.
All you have to figure out is if more weight, less weight, or the same amount of weight is being floated.
Can someone please check my answers? There are the choices Rise Falls Stays the same and Cannot Tell.
A) The fisherman fills a glass with water from the pond and drinks it.
Water level is Same?
B) The fisherman lowers the anchor and it hangs vertically, one foot above the bottom of the pond.
C) The fisherman lowers himself in the water and floats on his back
D) The nephew pops the balloon.
E) The nephew gets in the water and loses his grip on the string, letting the balloon escape upwards.
F) The fisherman knocks the tackle box overboard and it sinks to the bottom
Water level Falls?
These are essentially identical. Imagine the balloon being very large, to the point it's almost lifting the boat out of the water. In that case, it becomes obvious that the balloon is reducing the weight of the boat and thereby the water displaced, so when popped, the boat sinks a bit into the water and the level rises. Same holds true of the smaller balloon. Pop the balloon and the level rises.
Your other answers are good Hotmail.
Thankyou
You need to define what you mean by water level. It has to be measured relative to something. If it is the level of water relative to the boat it is a completely different problem than if it is being measured relative to something independent of the boat.
9K
11K
11K
