Equation of a plane orthogonal to a vector
The discussion revolves around the equation of a plane that is orthogonal to a given vector, specifically focusing on the relationship between the vectors involved and the geometric implications of their interactions. The original poster presents a mathematical expression involving dot products and seeks clarification on its meaning and implications.
  • Participants explore the equation involving the dot product of vectors and question the meaning of the terms involved, particularly the interpretation of B^2. There are attempts to manipulate the equation to derive further insights, with some participants suggesting substitutions and simplifications.
The discussion is active, with participants providing suggestions and engaging in back-and-forth exchanges to clarify concepts. Some participants express confusion about the relationships between the equations and the geometric interpretations, while others confirm their understanding of the mathematical principles involved.
Participants note the importance of understanding the geometric implications of the equations, particularly regarding the orthogonality of vectors and the nature of the solution set representing a plane. There is an emphasis on the need for clarity in the definitions and relationships between the vectors involved.
starbaj12
Let vectorB be a vector from the origin to a point D fixed in space. Let vectorW be a vector from the origin to a variable point Q(x,y,z). Show that vectorW (dot) vectorB = B^2 is the equation of a plane perpendicular to vectorB and passing through D.
Thank you for any help
how do you think you should start? one of the biggest things to remember is that starting a problem down the wrong path is not detrimental to anyone's heath, so guessing will not hurt.
What do you think that I just looked at the problem and then came here. I have been working on this problem if I typed everything I tried on this forum it would take a lot of time and space.
Write W=(W-B)+B, and see how your equation simplifies.
there is no reason to get an attitude. you posted a question without even giving anyone any idea of the work you have put into i so far. besides that, if we know where you are with this we can help to steer you toward the answer without just giving it to you and you learn a lot more. you are doing this work to learn it right? if not then why do it?
Could someone tell me the relationship between vectorW (dot)vectorB = B^2. I'm really baffled with B^2 is this a scalar or the magnitude or what
Did you try out my suggestion at all?
Yes I have been working off your suggestion arildno and thank you for it, but I'm coming up short. I do not have the complete understanding of the equation that I just posted.
We have:
[tex]\vec{W}\cdot{B}=\vec{B}^{2}[/tex]
Set
[tex]\vec{F}=\vec{W}-\vec{B}[/tex]
Then:
[tex]\vec{W}=\vec{F}+\vec{B}[/tex]
(Agreed?)
Now, put that expression for [tex]\vec{W}[/tex] into
the first equation; what do you get then?
arildno the first equation you have did you mean vectorw (dot) vectorb = b^2
Thank you for all your help
Yes, that is the equation I meant.
Remember:
[tex]\vec{B}^{2}=\vec{B}\cdot\vec{B}=||\vec{B}||^{2}[/tex]
So your saying that my equation vectorw (dot) vectorb = b^2 is the same as your equation vectorw (dot) b = vectorb^2
What else?
* means vector (easier for me to type)
I did what you said and I end up with *F + *b dot b = *b^2
Then *f + *b^2 = b^2
Is this right
After this the plane needs to be orthogonal to *b so do I just take the dot product of *f*bcos(theta) = 0 so *f = 0
What about it needing to pass through D
Thank you for your patience
[tex](\vec{F}+\vec{B})\cdot\vec{B}=\vec{F}\cdot\vec{B}+\vec{B}^{2}[/tex]
Hence, using this as your left-hand-side in your original equation, you have:
[tex]\vec{F}\cdot\vec{B}+\vec{B}^{2}=\vec{B}^{2}[/tex]
You should be able to figure out the rest,.
Sorry to push for the help so much arildno but I was up until four in the morning trying to figure the rest out but I seem to be lacking the education to see the relationship between the equations.
Sorry for keeping you awake!
Let's finish this in a couple of posts.
1. Do you accept that your original equation may be rewritten as:
[tex]\vec{F}\cdot\vec{B}+\vec{B}^{2}=\vec{B}^{2} (eq.1)[/tex]
where [tex]\vec{F}=\vec{W}-\vec{B} (eq.2)[/tex] ?
2. Do you also accept that (eq.1) can be rewritten as:
[tex]\vec{F}\cdot\vec{B}=0 (eq.3)[/tex] ?
Question:
What does (eq.3) tell us about the geometrical relationship of [tex]\vec{F},\vec{B}[/tex] ?
3. Do you agree that, using (eq.2), (eq.3) can be rewritten as:
[tex](\vec{W}-\vec{B})\cdot\vec{B}=0[/tex] (eq.4)?
Sorry for the delay reply I had classes, Yes I except eq.1 and eq4. Eq3 tells me that f is orthogonal to b
So, you don't get eq.1?
I cannot see what you are saying I thought eq3 was just the dot product and the answer is zero so it is orthogonal
You're ABSOLUTELY RIGHT about eq.3!
However, I asked you:
Do you understand how eq.1 is really the same equation as:
[tex]\vec{W}\cdot\vec{B}=\vec{B}^{2}[/tex]
(Given relationship eq.2 between F and W)
no is it where you plug f into the first equation and after using one of the dot product rules you end up with a negative b^2 and cancels the positive vectorb^2
Let's start with YOUR equation:
[tex]\vec{W}\cdot\vec{B}=\vec{B}^{2} (eq.0)[/tex]
Now, clearly, from eq.2, we have:
Agreed?
Hence, let's substitute this expression for [tex]\vec{W}[/tex] into (eq.0)
(You agree that I am allowed to do that?)
[tex](\vec{F}+\vec{B})\cdot\vec{B}=\vec{B}^{2} (eq.5)[/tex]
Now, let's rewrite the left-hand side of (eq.5):
[tex](\vec{F}+\vec{B})\cdot\vec{B}=\vec{F}\cdot\vec{B}+\vec{B}\cdot\vec{B} (eq.6)[/tex]
Do you agree that the right-hand side of (eq.6) is equal to the left-hand side of (eq.6)?
Now, we also have:
[tex]\vec{B}\cdot\vec{B}=\vec{B}^{2}[/tex]
(That's what we MEAN with [tex]\vec{B}^{2}[/tex])
But this means, that we may rewrite (eq.6) as:
[tex](\vec{F}+\vec{B})\cdot\vec{B}=\vec{F}\cdot\vec{B}+\vec{B}^{2} (eq.7)[/tex]
But this means, that the right-hand side of (eq.5) must equal the right-hand side of (eq.7)! (Since their left-hand sides are identical!)
Hence,
Agreed?
Could you clear something up for me how is it vectorb^2 is the same as just b^2 (on the right hand side). which is the first equation
Just a question:
Given "vectorb" do you then regard "b" as the magnitude of "vectorb"?
it is square root vectorb^2
Yes, so b^2=(square root vectorb^2)^2=vectorb^2
Will you agree to this?
yes I agree
All right, then!
Go back to post "23" and see if you understand it now!
Yes! yes! I follow now and I went back to post 17 and followed all the way through to equation 4. (I hope this was the way to go)
