What is the geometric interpretation of matrices A^{T}A and AA^{T}?
  • Context: Graduate
  • Thread starter Thread starter monea83
The discussion revolves around the geometric interpretation of the matrices A^{T}A and AA^{T}. Participants explore various contexts in which these matrices arise, including linear transformations, bilinear forms, and their roles in singular value decomposition and differential geometry.
  • Some participants suggest that while A^{T}A and AA^{T} appear in various contexts, a clear geometric interpretation is not readily apparent, although rotation matrices are noted for preserving length and area.
  • One participant proposes that A^{T}A can be viewed as a convex bilinear transformation that relates to the scalar product of transformed vectors, particularly emphasizing its positive definiteness.
  • Another participant mentions that the eigenvalues of A^{T}A correspond to the singular values of A, hinting at geometric implications through singular value decomposition, though they do not provide a direct geometric explanation.
  • A later reply introduces a perspective from differential geometry, stating that A^{T}A represents the metric induced on a manifold by its embedding in a higher-dimensional space, linking it to the inner products of the columns of A.
Participants express a range of views on the geometric interpretation of A^{T}A and AA^{T}, with no consensus reached. Some provide specific interpretations while others remain uncertain or suggest that interpretations may vary based on context.
Limitations include the absence of a unified geometric interpretation and the reliance on specific mathematical properties that may not apply universally across all types of matrices.
monea83
The matrices [tex]A^{T}A[/tex] and [tex]AA^{T}[/tex] come up in a variety of contexts. How should one think about them - is there a way to understand them intuitively, e.g. do they have a geometric interpretation?
In general there is no real interpretation that comes to mind. With some specific groups the transpose matrix is actually the inverse matrix. Matrices that have this property include the rotation matrices that have a determinant of one.
Geometrically rotation matrices conserve length. So if you had a vector with the tail at the origin (in other words a point), then when you apply a rotation it preserves length of that vector: if you apply it to a set of points it preserves area/volume etc.
There are of course other uses for transpose matrices like least squares, but off the top of my head I can't give you geometric descriptions or interpretations for those.
Lots of practice. :smile:
One thing I intuit about them is that it is often the "right" thing to use when you might have used x2 in an analogous situation with real numbers, or used a norm with an analogous situation with a vector.
Also, you can think of them as being a way to turn a matrix into a symmetric, square matrix that does the "least damage" in some sense.
Of course, these are all algebraic ways to intuit them, rather than the geometric one you asked about. :frown:
I think about it that way:
For n=3 for exemple,
Think at A as a linear transformation on R3: then you can think at A^T A as a convex bilinear transformation on R3xR3 giving you the scalar product of two vectors A(x1) and A(x2)
In particular, when x1 = x2 = x, I think at it as a "lengh" fonction on A(x) (hence positive defiinte)
Its eigenvalues are the singular values of A. In the basis of the eigenvectors of A*A and AA*, the matrix A is 'almost' diagonal. This is the Singular value decomposition.
The Singular value decomposition has some geometric implications, but I don't know whether this qualifies as a geometric explanation of A*A itself.
One thing from differential geometry comes to mind: If [tex]\gamma : \mathbb{R}^k \to \mathbb{R}^N[/tex] is a parametrization of a [tex]k[/tex]-manifold [tex]M \in \mathbb{R}^N[/tex], and [tex]A = [D\gamma][/tex] is its Jacobian, then the matrix [tex]A^T A[/tex] is the metric induced on [tex]M[/tex] by the embedding in [tex]\mathbb{R}^N[/tex], which is a _very_ geometric object. This is just a reflection of the fact that [tex]A^T A[/tex] is the matrix of inner products of the columns of [tex]A[/tex] (which is a nice geometric interpretation in and of itself), and in our particular case, the columns of [tex]A[/tex] are the basis vectors of the tangent space to [tex]M[/tex] in the coordinates we've chosen. This fact sometimes comes up in slightly disguised form in the context of multivariable calculus, in the formula for the volume element of a manifold with parametrization [tex]\gamma[/tex]: [tex]dV_M = \sqrt{ [D\gamma]^T [D\gamma] } dV_k[/tex], where "[tex]dV_k[/tex]" is the volume element in [tex]\mathbb{R}^k[/tex]. Since [tex]A^T A[/tex] is the metric, this is just a version of the usual formula [tex]dV_M = \sqrt{g} dV_k[/tex], where [tex]g[/tex] is the determinant of the metric.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 19 ·
