| New Reply |
effect of air pressure on temperature |
Share Thread | Thread Tools |
| Dec27-10, 01:00 PM | #1 |
Hello,
I'm posting here in an attempt to solve a practical problem involving air temperature and pressure in a home, but I'll pose the problem in a simple, hypothetical model. Take a large, closed box with a certain quantity of air contained within. A source of heat is placed on the bottom half of the box. It heats up the air temperature, the air pressure increases, and warm air rises towards the top of the box. My question is this: If you placed a second heat source in the upper half of the box, and made that heat source equal to or warmer than the heat source at the bottom of the box, would the increased pressure of the air in the upper half of the box prevent the warm air at the bottom of the box from rising, thereby increasing air temperature and pressure in the bottom of the box? Thanks for any help on this basic question. Regards, Charlie Cavanaugh |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec27-10, 01:11 PM | #2 |
Mentor
Welcome to PF.
No, nothing constrains the pressure from equalizing throughout the box, so it equalizes throughout the box. The warm air rises not because of the pressure difference (which is negligible) but because of the density difference. |
| Dec27-10, 01:13 PM | #3 |
Clue: air pressure/temperature and temperature and its relation to pressure. |
| Dec27-10, 02:07 PM | #4 |
Thanks for your quick replies.
russ: If the pressure equalizes throughout the box, would that mean that the temperature would equalize also? I'm a little puzzled by your comment about density difference being the key factor in making warm air rise. From my understanding, cold air is denser than warm air because of decreased molecular motion. Wouldn't a substance of greater density actually prevent a substance of lesser density from moving into the space it occupies? So if density was the key factor, wouldn't cold air in the upper layers of the box actually prevent warm air from rising into its space? Charlie |
| Dec27-10, 02:13 PM | #5 |
I Think you are thinking in terms of absolutes, or that air is a homogeneous entity. |
| Dec27-10, 02:14 PM | #6 |
The pressure would go up due to the increased temperature. The higher temperature the higher the pressure, it is a direct correlation (correct me if I'm inaccurate).
The increased temperature would be because of you putting another heat source on the limited volume of the box. Thus an increased pressure in the box. What is not going to happen is an increased pressure on a certain area of the box; but an increased AVERAGE pressure in the whole box. |
| Dec27-10, 02:43 PM | #7 |
Mentor
| Dec27-10, 02:45 PM | #8 |
Mentor
| Dec27-10, 02:47 PM | #9 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: effect of air pressure on temperature
| Work While Temperature Change and Heat while pressure and/or temperature change | Classical Physics | 0 | ||
| Effect of Temperature on enzymes | Biology, Chemistry & Other Homework | 1 | ||
| Photoelectric Effect and Temperature. | General Physics | 5 | ||
| Effect of temperature on voltage | Electrical Engineering | 3 | ||
| Temperature effect on magnetism. | General Physics | 1 | ||
