Temperature and Kinetic Energy
The discussion revolves around the relationship between temperature and kinetic energy in fluids, particularly addressing whether the temperature of a fluid increases when it is set in motion. Participants explore concepts from thermodynamics and reference frames, examining how motion affects the measurement of temperature.
  • One participant questions why the temperature of a fluid does not increase when it is set in motion, suggesting that the molecules gain additional kinetic energy relative to an external standard.
  • Another participant explains that the temperature defined as the average kinetic energy of molecules does not account for translational motion relative to an external frame, emphasizing the distinction between static and total temperature.
  • A later reply reiterates the initial question about the effect of motion on temperature and introduces the idea that temperature is related to the squared deviation of molecular velocities, suggesting that simple motion does not affect this mean squared deviation.
Participants express differing views on the relationship between motion and temperature, with no consensus reached on whether motion affects the temperature measurement in the context discussed.
The discussion involves complex concepts from thermodynamics and reference frames, with participants highlighting the need for careful consideration of definitions and conditions under which temperature is measured.
tomtraxler
If temperature is defined as the average kinetic energy of molecules in a fluid (or gas), then why isn't the temperature of a fluid increased when that fluid is set in motion? Or is it?
For example, if a stationary fluid is set into motion, do the molecules not have additional kinetic energy, like taking a cup of water and moving it or by making it swirl with a spoon? The energy relative to each other molecule might be the same, but relative to some external standard, it has increased.
Science news on Phys.org
Very good question. It is the kind of question I ask to my pillow every night. You are mixing the relativity of reference frames with thermodynamics.
I'm not going to answer you quantitatively but qualitatively. In classical thermodynamics, the velocity is referred to an inertial frame that is attached with the center of mass of the gas. Any other external velocity, such a traslative velocity you mentioned does not increase the internal energy, but the kinetic energy of the whole system. The static Temperature, as we call to that Temperature obtained by the average kinetic energy of the molecules. That is the real temperature of the gas, because despites it is moving globally with some velocity, if you want to measure experimentally the Temperature you will obtain the average of the molecular kinetic energy, without the velocity of your external reference frame.
On the other hand, the apparent Temperature of the system is what we call the Total Temperature. In fact, if the acceleration process of the reservoir is made isentropically:
[tex]c_pT_o=c_pT+\frac{1}{2}*v^2[/tex] is yielded by the energy conservation:
[tex]T_o=T+\frac{v^2}{2c_p}[/tex]
where To=Total Temperature (external, apparent, depending on the reference frame);
T=Static Temperature (internal, the experimental temperature, it is obtained from the equation of State).
v=velocity of the whole mass of gas.
When you put a thermometer inside the reservoir, you are measuring the Static Temperature (v=0).
Temperature is a measure of the squared deviation of velocity about the mean. Simply moving an object has no effect on the mean squared deviation.
Excellent responses. Thanks for explaining it to me.
  • · Replies 16 ·
  • · Replies 23 ·
21K
