Mathematical Proof That a 45 Degree Angle Launch is Best for Displacement
The discussion focuses on the mathematical proof regarding the optimal launch angle for achieving maximum horizontal displacement of a projectile, specifically examining the case of a 45 degree launch angle. The scope includes mathematical reasoning and technical explanations related to projectile motion.
  • Some participants inquire about the mathematical proof that a 45 degree angle yields the largest displacement for a projectile.
  • One participant suggests deriving the range in terms of the initial velocity and angle, proposing to take a derivative with respect to the horizontal component.
  • Another participant mentions writing the expression for the range in terms of 2θ to clarify the proof.
  • A participant provides the formula for maximum distance covered, stating that for maximum displacement, sin(2θ) must be maximized, which occurs at 90 degrees, implying an angle of 45 degrees.
  • One participant emphasizes that the 45 degree angle is valid only if the object lands at the same level from which it was launched, discussing the symmetry of the parabolic trajectory and deriving the maximum horizontal displacement formula.
  • Another participant notes that while range is important, other factors like hang time are also relevant for practical applications, such as punting in football.
Participants express varying degrees of certainty about the conditions under which a 45 degree angle maximizes displacement, with some emphasizing the need for the launch and landing heights to be the same. There is no consensus on the broader implications of the findings for practical applications.
Participants mention assumptions regarding the launch and landing heights, as well as the dependence on initial velocity and angle, which may affect the validity of the conclusions drawn.
BasketDaN
Does anybody know how to mathematically prove that an object launched at a 45 degree angle will have the largest possible displacement?
Do the 2d solution to the free falling body problem, Obtain a solution for the range in terms of the initial velocity, this will include the initial angle, take a derivative with respect to x (the horizontal component), set equal to zero and solve for the angle.
Write down the expression for the range, in terms of [itex]2\theta[/itex]. That will make it obvious.
MAximum distance covered, d = (u^2sin[itex]2\theta[/itex])/g
u= velocity at time of projection
for d to be maximum (u^2sin[itex]2\theta[/itex]) must have its maximum value for given speed, this implies that sin[itex]2\theta[/itex] must have maximum possible value that is 1, whem angle is 90 degrees so angle is obviously 45 degrees
I assume the object is landing at the same level as it is launched. Otherwise, it is not correct that a 45 degree angle gives the largest horizontal displacement.
Use the symmetry of the parabolic trajectory to double the horizontal (x) distance at the position of maximum height (y).
The maximum height occurs when the vertical speed [itex]V_{y}[/itex] = 0.
[tex]V_{0y} = V_0 sin\theta[/tex]
As a function of time, t:
[tex]V_{y} = V_0 sin\theta - gt[/tex]
When [itex]V_{y} = 0[/itex]:
[tex](1): V_0 sin\theta = gt[/tex]
Now horizontal displacment:
[tex]x = V_{0x}t<br /> = V_0 cos\theta t[/tex]
[tex](2): t = \frac{x}{V_0 cos\theta}[/tex]
Substituting for t from (2) in (1):
[tex]V_0 sin\theta = \frac{gx}{V_0 cos\theta}[/tex]
[tex]x = \frac{V_0^2 cos\theta sin\theta}{g}[/tex]
The range is twice this distance so:
[tex]x_{max} = \frac{2V_0^2 cos\theta sin\theta}{g}[/tex]
Substituting the trigonometric identity:[itex]2sin\theta cos\theta = sin2\theta[/itex] gives:
[tex]x_{max} = \frac{V_0^2 sin2\theta}{g}[/tex]
Since [itex]sin2\theta[/itex] is maximum at [itex]2\theta = \frac{\pi}{2}[/itex] then maximum horizontal displacement occurs at [itex]\theta = \frac{\pi}{4}[/itex]
Now that you know this, you can give coaching tips to the punter on your college football team: kick the ball so that it has a 45 degree angle on take-off. It also explains why my 5 wood goes farther than my drive (that and my slice).
Calculex
Calculex
But range is not the only thing a punter worries about. There's hang time too, especially if you have a short punt and don't want a touch back. :wink:
10K
  • · Replies 21 ·
  • · Replies 18 ·
