Periodicity & Chemical Bonding Homework Help General Chem
The discussion revolves around various questions related to periodicity and chemical bonding, as part of a general chemistry homework assignment. Topics include ionization energy trends, atomic and ionic radii, properties of metals and non-metals, types of chemical bonds, molecular geometry, hybridization, and the physical states of hydrocarbons.
  • Homework-related
  • Participants discuss how ionization energy changes across a period and down a group, suggesting trends can be found in chemistry textbooks.
  • There is a mention that atomic and ionic sizes increase with atomic number, and that positive ions lose electrons, affecting their size.
  • Electronegativity is highlighted as a factor in determining bond polarity, with the suggestion that the largest difference in electronegativity indicates the most polar bond.
  • The concept of octet structure is introduced, with the assertion that noble gases have full octets, contributing to their stability.
  • Participants describe two types of covalent bonds, distinguishing between coordinate covalent bonds and regular covalent bonds.
  • There is a suggestion to use Lewis dot structures to understand molecular geometry, particularly for BeF2 and SF2.
  • Polarity and crystal structure are mentioned as factors influencing the physical state of hydrocarbons at room temperature.
  • A participant expresses a desire to proof-check their work, indicating they are upgrading their chemistry knowledge.
Participants do not reach a consensus on the answers to the homework questions, and multiple viewpoints and approaches are presented without resolution.
Some responses lack detailed explanations or specific examples, and there are assumptions made about the reader's prior knowledge of chemistry concepts.
This discussion may be useful for students seeking help with general chemistry concepts, particularly those related to periodicity and chemical bonding.
afroman
Periodicity & Chemical Bonding "Homework Help" General Chem
30. How does ionization energy change as one proceeds
a) across the periodic table in a horizontal row
b) down the periodic table in a vertical group
Give an explantion for each answer.
31. Arrange the following atoms or ions in order of increasing radius: Cl,S2-,K,K+,O
Give an explanation for the position S2- in relation to the atom or ion that comes just before and just after it.
32. What is the relationship between first ionization energies and metallic and non-metallic properties?
33. Identify two repulsive forces and two attrative forces that influences the formation of chemical bonds between two atoms.
34. Which of these bonds is most polart and which is least: S--O, Cl--Cl, or Cl--O? Justify your arrangement.
35.
a) What is meant by octet structure?
b) What evidence indicates that octet structures might be more stable than others?
36. What is meant by co-ordinate covalent bond?
37. Explain why you would expect a BeF2 molecule to be linear but an SF2 molecule to be an angular.
38.
a) How would you designate the hybrid orbitals formed by "mixing" one d one s and two p orbitals?
b) How many of the hybrid prbitals would be formed by the mixing?
39. Explain why C20H40 os a solid at 25degreesC, while C4H8 is a gas at 25degreesC.
Chemistry news on Phys.org
30) you should be able to find trends of the periodic table in your chem book.
31) The elements get larger as their number gets higher that should help. Also, if you have a positive then you must loose an electron since more protons would indicate a different element
34) To find this you need to look at the electronegativity, which increases as you go up and across the periodic table. The molecules which have the biggest difference in electronegativity will be the most polar.
35) The octet is what most elements desire of their outer most shell. The last column in the peroidic table has a full octet
b) the previous statement should answer that question, since those are the noble gases and the most stable
36) There are two types of covalent bonds. One in which one molecule brings both electrons and one where each molecule brings an electron to share. It will be easy to find the difference
37) Do the Lewis dot structure and see what happens
38) Set up energy levels
39) This will have to do with the polarity and the ability to form a crystal structure, but you will have to give more info than this.
btw, in the future it might help for you to try these problems and then we can help you or check your answers. It will do you no good if we do your homework for you.
Good Luck
Nautica
btw just was making sure that everything was the way i have stated things, sometimes I like to proof check my work; that is done... I'm doing a Chemistry Upgrade been a few years lol :bugeye:
Thanks for you help and support bud... :smile:
11K
