New Reply
Spring system inside an accelerating box
Share Thread Thread Tools
Dec29-10, 06:14 PM   #1
A mass m is resting at equilibrium suspended from a vertical spring of natural length L and spring constant K inside a box.
The box begins accelerating upward with acceleration a. How much closer does the equilibrium position of the mass move to the bottom of the box?
2. Relevant equations
f=kx
f=ma
3. The attempt at a solution
so this is my f=ma statement
kx-mg=ma
then i solved for x to get x= m(a+g) / k
but this answer is wrong and the correct answer is
ma / k
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec29-10, 07:28 PM   #2
Recognitions:
Homework Helper Homework Help
You are looking for the change in the mass' position from the initial equilibrium position, after the box has begun accelerating. What was its initial position?
Dec29-10, 07:32 PM   #3
Mentor
Quote by gneill View Post
In other words, what was the equilibrium position of the mass before the box was accelerated?
Dec29-10, 09:47 PM   #4
hmm the problem doesnt specify that location.
Cant we just assume it to be at location 0
Dec29-10, 10:04 PM   #5
Recognitions:
Quote by physics517 View Post
Sure. You can assign your zero position to that location. Just keep in mind that it isn't the same location as the end of the relaxed, unloaded spring.
Recapping what's happening:
1. Box at rest. Spring unloaded, natural length L.
2. Box at rest. Spring loaded with mass M, settles at equilibrium.
3. Box accelerating. Spring stretches more, assumes new equilibrium.
The question is (essentially) asking for the amount of stretching that takes place between items 2 and 3.
Dec29-10, 10:15 PM   #6
I think my problem was that i assumed L to be the spring's length when it was loaded. But what you stated makes sense now and it leads to the right answer.
excellent help. you gave me info but just enough to make me think and understand it
thank you
New Reply
Thread Tools
Similar Threads for: Spring system inside an accelerating box
Thread Forum Replies
Spring scale holding accelerating pulley system. Introductory Physics Homework 3
Accelerating blocks connected by a spring Introductory Physics Homework 4
what happens in acompletely reversing mass-spring system? (spring turns inside out) Introductory Physics Homework 2
inclined ramp inside an accelerating train Introductory Physics Homework 5
Spaceship accelerating inside a Black Hole Special & General Relativity 7
