Simple ftl setup using Stern-Gerlach
  • Context: Graduate
  • Thread starter Thread starter bruce2g
    Ftl Stern-gerlach
The discussion revolves around a proposed setup using Stern-Gerlach measurements on entangled electron and positron pairs to explore the possibility of transmitting a statistical signal faster than light. Participants examine the implications of the setup, including the behavior of the particles and the outcomes observed by Bob and Alice, while questioning the validity of the proposed communication method.
  • One participant suggests using entangled electron and positron beams to communicate a bit of information based on the outcomes of Stern-Gerlach measurements, proposing that Bob could see different numbers of spots depending on Alice's actions.
  • Another participant argues that Bob will always see two spots after his first measurement, regardless of Alice's actions, asserting that the state of the electrons becomes definite after measurement.
  • A different participant questions whether Bob's measurements could yield negatively correlated results with Alice's, suggesting that the state of the electrons may remain indeterminate until Bob measures them.
  • Some participants clarify the setup, indicating that Bob is positioned at a distance D from the source and Alice at an equal but opposite distance, which raises questions about the interpretation of Bob's measurements.
  • One participant emphasizes that if an intermediate measurement is made on a different axis, it could affect the subsequent measurements, challenging the idea that Bob's results would remain unchanged.
Participants express disagreement regarding the outcomes of Bob's measurements based on Alice's actions. There is no consensus on whether the proposed setup could allow for faster-than-light communication, as differing interpretations of quantum measurement and entanglement are presented.
Participants highlight the complexity of quantum states and measurements, noting that assumptions about the independence of measurements and the nature of entanglement may not hold in this scenario. The discussion remains open-ended with unresolved mathematical implications.
bruce2g
Hi,
I've been reading David Albert's book "Quantum Mechanics and Experience," and it got me thinking about how one could use Stern-Gerlach sorts of measurements on entangled electron pairs (or electron-positron pairs) to transmit a statistical signal from one to the other.
Let's say you have two entangled beams, one of electrons, and the other of positrons, and their spins are negatively correlated. The two beams travel in opposite directions at the same velocity through a vacuum. Bob is receiving the electrons, and Alice gets the positrons.
To keep it simple, they're at rest with respect to each other, and each is at an equal but opposite distance, D, from the source.
(1) Bob uses a Stern-Gerlach magnet to split his electron beam by spin along the Y axis at a distance D from the source. It is always on, and it creates two beams.
(2) Alice has a Stern-Gerlach magnet oriented on the X axis at a distance D+delta from the source. She examines the next bit to be sent, and if it is a '1', she turns on her magnet and she splits her positrons by spin along the X axis for five seconds. If it's a zero, she turns off the magnet.
(3) Bob has another two magnets around his two electron beams at a distance of D+2*delta from the source, once again aligned on the Y axis, and a screen that displays the beams.
It seems to me that if Alice has not turned on her magnet, then Bob will see two spots on his detector, which is the normal outcome of a Stern-Gerlach experiment.
However, if Alice has turned on her magnet, then the state vectors of her positrons (and thus Bob's electrons) will have moved to the X axis, so Bob's second detector will split the beam again, and Bob will see four spots. If this is true, and if D is great enough (> 6 light-seconds), then a bit will have been communicated faster than the speed of light, which is indicated by whether Bob sees two spots or four spots.
This setup is different from most of the FTL ideas I've seen since an individual electron will only show a diffent spin on the Y axis half the time when Alice turns on her magnet. However, if you have enough particles for each bit, you can get the error to be arbitrarily small, so that's why I specified 5 seconds for Alice to power her magnet.
I'm studying this stuff on my own, so I've probably overlooked some simple or subtle principle that would keep it from working, but I can't figure out what it is, so I'd appreciate it if someone could point out the flaw in this setup.
No, because after Bob's first magnet, we know with certainty what is the state of the electron in each beam, so Bob will always see two spots (one up-up and one down-down).
If the initial state is 1/sqrt(2) { |y+>|y-> - |y->|y+> } (first = electron, second is positron), then after the first magnet of Bob, an electron that goes into the upper beam has a state |y+>|y-> and an electron that goes in the lower beam has a state |y->|y+>. Whatever Alice measures in the X direction (or not) doesn't affect this ; she will measure the state |y-> = 1/sqrt(2) (|x+> + |x->) in the first case, and |y+>=1/sqrt(2) (|x+> - |x->) in the second case (or vice versa, I didn't do the calculation). But Bob will measure always a |y+> in the first case, and a |y-> in the second case.
cheers,
Patrick.
Thanks for your reply, Patick. The equations make this easier to discuss.
Note: I'm going to change the ascii notations a little for clarity, so that Ye+ means "the electron's spin on the Y axis is +" and eUP1 means the electron is deflected up by the first magnet).
Well, since Bob hasn't actually measured the electron yet, its spin state has not yet assumed a deterministic value. So, it's still in the initial state [though Ye is now entangled with the position of the electron as deflected by the magnet, so the full state is 1/sqrt(2) (|Ye+>|eUP1>|Yp-> - |Ye->|eDOWN1>|Yp+). To keep things manageable, I'm going to assume that this will not affect the argument that follows].
So, after the electron goes through the first Y magnet, Alice measures X on the positron, and macroscopically observes the result.
Since Bob did not physically measure anything, Alice will measure 1/sqrt(2) (|Xe+>|Xp-> - |Xe->|Xp+).
So, after she observes the result, the state will be either |Xe->|Xp+> or else |Xe+>|Xp->.
Doesn't this mean that if Bob were to measure Xe in his two beams his results would negatively correlate with Alice's? (not that this would not give him any information, of course.)
If so, it should follow that Ye has become indeterminate once again even if Bob does not measure the Xe's, and so this would yield four spots after the second set of magnets was applied to the beams.
It looks to me like Bob has two detectors in two different places, one on each side of Alice. If I'm reading this right, then Bob is not really one person, but two.
- Warren
bruce2g said:
Hi,
No. Bob will always see two spots. A cascade of two detectors will always produce the same result as one detector. If you think of the first detector as measuring the state of the spin, once you measure the spin, the state vector changes to have a definite value, the value that was measured. You can re-measure it as many times as you like (along the same axis) and you'll always get the original value.
- Warren
Sorry if I was unclear, but the idea is that Bob is distance D to the left of the source, and Alice is distance D to the right of the source.
Thanks for your reply. While it is true that a cascade of two detectors on the same axis will always produce the same results if the state vector does not change between the two detectors, if an intermediate detector measures a property that is incompatible with the first, then this no longer holds.
For example, if the first detector measures the spin on the Y axis, you get two beams, one moving upwards and one downwards.
If you place magnets around each of those beams, aligned this time on the X axis, you get two more splits, two to the left and two to the right, yielding four in all. These second magnets have changed the state vector of all particles to an eigenstate of the X axis spin operator (although we won't really know which one until we let them illuminate the screen).
If you then, for each of those four beams, again placed magnets measuring the spin on the Y axis, each of those beams would split again in the upwards and downwards directions, giving you eight dots on your screen.
At least, that's how I understand it. This is because by measuring the spin on the X axis, you make the spin on the Y axis no longer determinate.
In my FTL setup, Alice performs the X axis measurement on the entangled positron, and what I'm proposing is that this also measures the X axis spin of the electron, and thus makes both of their Y axis spins indeterminate.
I think may have problems to understand what does a measurement on a quantum state.
A local measurement, for example the spin of Alice, only changes the state local of Alice but not the one of bob.
The only thing you can say is: the state of bob is |+> or |-> if the result of measurement of Alice is |-> or |+> that's all. You have no action on the Bob state as Bob’s state also includes particles where a measurement on alice would give the result |->.
I see what you mean. Let us consider standard measurement theory, using collapse and all that.
Let us consider the initial state 1/sqrt(2) (|y+>|y->-|y->|y+>)
Bob's first splitter: Y (because we do not undo this, we can track back afterwards through which branch the electron went, so this is a real measurement).
A) Upper beam -> the state is now |y+>|y-> with probability 1/2.
We rewrite this for Alice: |y+> ( 1/sqrt(2) [|x+>+|x->])
A1) Alice finds X+ -> the state is now |y+>|x+> with probability 1/2.
Bob measures Y again: he finds Y+ with certainty (eigenstate).
A2) Alice finds X- -> the state is now |y+>|x-> with probability 1/2
B) Lower beam -> the state is now |y->|y+> with probability 1/2
B1) Alice finds X+... etc...
Bob measures Y again: he finds Y- with certainty (eigenstate).
The reason for this is, again, because the measurement occurs already in the first Y apparatus of Bob. If Bob would do a quantum erasure measurement (that is, letting the two separated beams interfere again, such that we will not be able to find out through which channel of the first Y apparatus the electron went), then this should not be considered as a measurement, and the superposition remains. If Alice then measures an |x+> state, say, then we could better have written the original superposition as 1/sqrt(2) [|x+>|x->-|x->|x+>] (which is the same as the y state I wrote earlier) ; now after Alice's measurement the state will be |-x>|+x>. But Bob's Y measurement doesn't exist anymore...
cheers,
Patrick.
Patrick,
Thanks for the insights. It is very interesting that splitting the beam creates a measurement, and that recombining the beam can erase its effect.
As I understand it, if Bob split the electron beam on the y axis, the entanglement would no longer apply. But if Bob then recombined the two y beams and split the reconstituted beam on the x axis, he would restore the entanglement and observe a perfect -1 correlation with Alice's positrons' x-axis measurements. This is pretty cool!
Thanks again.
Bruce
Hi again,
That's the way I also understand it. It gives some people so much trouble that they prefer to go back to more classical models. One cannot deny that quantum theory has some trouble in defining what exactly is a measurement and what not, except by going to some extreme views.
Indeed, the "realist" objection to what we just described is: yeah, but when the electron gets into the first magnet, IS IT OR ISN'T IT measured ?? If it is, and we apply the projection literally, how are we going to reconstitute the entanglement afterwards then ? If we don't project at that moment, what stops us from having Alice doing her projection, in the way you proposed, changing the pure Y state at Bob's into a pure X state. If Bob can then track back what must have happened at Y, we have contradictory measurements. So what gives ?
I'll tell you mine. It is probably not universally accepted, but I think it works in all cases. I think that to use quantum theory consistently, there can be only one true measurement, in one place, at one moment, namely at the end of the experiment. All the rest are entanglements.
In fact, if it weren't for this single final measurement, I'd be talking about many-worlds interpretations. But they have difficulties reproducing the right probabilities if never ever any measurement is done.
Let's look at the situation you described, and let's say that it is Bob who measures, at the end of the entire experiment. He also measures Alice's state. I leave out all normalization factors like 1/sqrt(2).
First, we have |y+>|y->-|y->|y+>
Next, entanglement with first magnet at Bob's:
|Y+>|y+>|y-> - |Y->|y->|y+>
Next, entanglement with Alice's X magnet, and her piece of paper:
|Y+>|y+>(|x+>|X+>+|x->|X->) - |Y->|y->(|x+>|X+>-|x->|X->)
=|Y+>|y+>|x+>|X+>+|Y+>|y+>|x->|X-> - |Y->|y->|x+>|X+>
+ |Y->|y->|x->|X->
Finally, entanglement with Bob's second Y magnet:
|Y2+>|Y+>|y+>|x+>|X+>+|Y2+>|Y+>|y+>|x->|X-> - |Y2->|Y->|y->|x+>|X+>
+ |Y2->|Y->|y->|x->|X->
And now Bob measures:
1/4 a chance to have Y2+, Y+, X+
1/4 a chance to have Y2+, Y+, X-
1/4 a chance to have Y2-, Y-, X+
and 1/4 a chance to have Y2-,Y-,X-.
The measurement also implies the collapse of the state of Alice's paper with her measurement on. You see that no case Y2+ Y- occurs.
It is when you consider multiple measurements at different times and places that strange things seem to occur. It is my way out of the "faster than light collapse without information transfer". The thing I sacrifice is the "universality of measurement": there can be only one, at one moment (the last one), and one place (where *I* am).
Now let us treat the case of a quantum erasure. After Bob's first Y magnet, and Alice's X magnet we have the state:
+ |Y->|y->|x->|X->
When Bob now introduces an inverse Y-field that mixes perfectly again the |Y+> and |Y-> states back into |Ymix> (let us assume that no extra phase shifts are introduced in the procedure), we find:
=|Ymix>|y+>|x+>|X+>+|Ymix>|y+>|x->|X-> - |Ymix>|y->|x+>|X+>
+ |Ymix>|y->|x->|X->
= |Ymix> (|y+>|x+>|X+>+|y+>|x->|X->-|y->|x+>|X+>+|y->|x->|X->)
and we can neglect this factor:
Let us rewrite the y-state of the electron in x basis:
(|x+>-|x->)|x+>|X+> + (|x+>-|x->)|x->|X-> - (|x+>+|x->)|x+>|X+>
+(|x+>+|x->)|x->|X->
= -|x->|x+>|X+> + |x+>|x->|X-> (times 2 which we neglect)
Now Bob passes the electron through his X magnet, and finds:
-|X->|x->|x+>|X+> + |X+>|x+>|x->|X->
He now MEASURES his result on the X magnet and Alice's paper:
1/2 chance to find X- X+
1/2 chance to find X+ X-
Perfect anticorrelation!
cheers,
Patrick.
I would like to add something. Let us assume that it is Alice who measures. Of course, if we wait until Alice has all the information, she'll do exactly the same thing as Bob. But what happens if Alice considers 2 consecutive measurements: one is her X measurement, and the second one is Bob's paper which arrives in the mail ?
I repeat the common part:
Now Alice MEASURES:
1/2 chance to find X+ and the state of Bob's part is then:
(|Y+>|y+>-|Y->|y->)
1/2 chance to find X- and the state of Bob's part is then:
(|Y+>|y+>+|Y->|y->)
We don't need to track down the state of the positron or Alice's magnet.
If Bob now puts in his second Y magnet, in the first case (Alice X+),
the state will be:
|Y2+>|Y+>|y+> - |Y2->|Y->|y->
and upon reception of the paper, Alice will find 1/2 probability that Bob had:
Y2+ Y+
and 1/2 probability that Bob had:
Y2- Y-.
Again, she'll not see any Y2+ Y- on Bob's paper.
The case when Alice first measured X- is similar.
If Bob erased his state, then in the case Alice had X+, Bob had:
|Ymix>(|y+>+|y->) = |x->
and if he now put in an X magnet, the state would be:
|X->|x->
So Alice would find with certainty that bob had X- (perfect anticorrelation).
Similar for the case that Alice had X+.
So I can relax a bit my condition: measurements can be applied successively, as long as they are made by one single conscious observer.
Is this to be taken seriously ? Honestly I don't know. But as an algorithm, it solves all ambiguity of what is and what is not a measurement in standard quantum theory.
cheers,
Patrick.
vanesch said:
Hi again,
cheers,
Patrick.
Here is an other interpretation of quantum measurement. Always separate the “quantum measurement” in 2 blocks:
-- the local interaction on the Particles: what they become after their interaction with the apparatus: we can stay at the quantum level. We can describe this interaction with a hamiltonian or with projectors.
-- the statistical event (the apparatus): what a human see or what gives a quantum computation.
The description of the local interaction given by the apparatus allows getting a description of the system evolution that always stays at the quantum level while the statistical events are always calculated/viewed separately (like probability, it is always a conditional probability: I get that if I’ve measured that and that etc …, example “the last measurement” of Patrick).
What does not explain this point of view, is why a measure gives only a single value. However, this is not very important, if we “accept” that quantum physics deals with (special) statistics. : )
For example, the quantum eraser at bob side:
The first magnet changes the spatial move of particles at bob side: the particles with spin + goes left while the particles with spin – goes right: the “magnet” has introduced in fact a change in the spatial part of the wave function of the particles at bob side (momentum update). We still keep spin correlations with the other particles (we have, in this case a unitary update of the global state):
Initial state |psi>=|sp_alice>|sp_bob>(|y+>|y->-|y->|y+>) --->
|psi>=|sp_alice>|right_bob> (|y+>|y->-|sp_alice>|left_bob>|y->|y+>)
Now if we introduce a new apparatus that recombines the left (spin +) and right particles (-), The spatial extension state part of the spin + spin – particles of bob side (moving left and right) will be updated into a common spatial extension (the initial spatial extension): we get back the same state of spins:
|psi>=|sp_alice>|right_bob> (|y+>|y->-|sp_alice>|left_bob>|y->|y+>) --->
The main advantage is that we keep thinking on “classical” view of interactions: the magnet changes the spatial direction of the particle using the spin interaction (i.e. what does a stern gerlach apparatus).
Seratend.
But that's exactly what I said ; replace |right_bob> with my |Y+> and we're done. Indeed, this |Y+> represents the position wavefunction with a blob in the upper path. I didn't mean to say that it was a global measurement apparatus state, if that is what was understood.
I admit having been sloppy by not introducing "initial states" and explicit evolutions, but I think we're talking about the same things.
The point I was trying to make is "when do we apply the Born rule of probabilities and the projection of the states".
cheers,
Patrick.
:smile:
cheers,
Patrick.
Sorry, I should have taken more time reading your post :biggrin:
(I confused your “y” with a simple label and thus do not make the association to the position, I assumed implicit in the state itself:-p).
So let's go on a call for other propositions in the quantum measurement interpretation.
Seratend.
vanesch said:
I think that to use quantum theory consistently, there can be only one true measurement, in one place, at one moment, namely at the end of the experiment. All the rest are entanglements..
Seratend.
Another way to put it would be to say that when Bob sends the electron through the first magnet he "marks" the electron as having a specific spin, even though he doesn't "measure" it yet. (I borrowed this term from the delayed choice interferometry experiments, where they "mark" the idler photon with which-path information.) To "mark" a particle just means to entangle its state with a macroscopically measurable property, but it might be easier for people working at an introductory level to understand.
This is a subtle point, but actually I think this distinction between "marking" the particle's state and "measuring" it lies very close to the heart of these matters.
Bruce
What comes to mind here is E-P-R ?
http://math.ucr.edu/home/baez/physics/Quantum/bells_inequality.html
One has to determine all probable outcomes, from an experiment that you cannot know TOTALLY!
There are a number of factors needed to be addressed, one question is that what is to be determined as an Observation?..and does the initial setup interfere with the outcome/results?..are the spatial events of the Atom-Detector-Observer intermingled in a Time dependent manner?
For instance, one can ask this:Does the Electron Know of the Experimental set-up prior to its initial state, if so then the Electron can just as well be classed as Observer dependent. Observers measure end results?..as pointed out earlier, then Electron "observation" has a forward projection of its oncoming events that lay directly in it path!
Electrons were given a special status by Feynman,(aftera conversation with Wienberg I believe?), in that they can go forwards and backwards in Time(not to be confused with faster than light transportations), this can be an assertion that Human observation will never know enough about an observed system, because we are dynamically locked within Spacetime,(Time dependent) locations at all times, even if we try and construct experiments wherby we assume a prior "knowledge" of determination.
I should state that David Alberts book:Q M and Experience, touches upon some deep philosophical implications, and if you continue with the book I am sure you will benefit the authors amazing angles he gives in the later chapters, areally amazing read.
Bruce
Can you develop your view concerning the marking?
More precisely what do you intend by the "entanglement with a macroscopically measurable property"?
I understand your marking, formally, as the result of a measurement on the particle giving a particular result - the eigenvaue of a particular observable -(and after, I may proceed after with conditional probabilities for further measurement results).
Seratend.
Seratend.
Well, the important point is that marking does not collapse the wave function -- it puts the particle into a superposition of eigenstates. Later measurement will reveal, when the wavefunction collapses, what the state was when the particle was marked.
This assumes, of course, that the wave function actually does eventually collapse (though Albert is not so sure that this ever happens...).
Bruce
This is not possible. If you interact with the wave function, with the extended entangled state, then you collapse it. This is what inhibits many schemes for turning entanglement into FTL.
I don't know exactly what is meant with "marking", but it could be something like saying, hey, if we wanted to, we could easily measure (the position say) of the particle ; only, we won't. But I don't think it has any operational meaning.
I think that the (unobserved) position of the particle after Y, or the passage through one of the 2 slits in a Young experiment, is such a marked state.
Is this what is meant ?
cheers,
Patrick.
Bruce
So, I think I may understand your view:
In fact, marking is really like using conditional probabilities only between two steps: the preparation (marking) and the measurement (the result).
The preparation leads to a general superposition state |psi>=|psi_ent> that can lead to different measurement results |psi_mes1>, |psi_mes2>, etc ... (the marking) .
The measurement gives a value (eigenvalue) thus a known state |psi_mesi> (normally the projection of |psi_ent> into that state).
So you can say that, for this measurement result, the particle was marked into the state |psi_mesi> before this measurement.
The marking "carries" the unkonw information prior to the measurement result.
Is this, what you mean by marking? Looking backwards for a given measurement result?
Seratend.
temporal nonlocality
seratend said:
The marking "carries" the unkown information prior to the measurement result.
Seratend.
Yes, this is what I meant. There's a second part to it, that might seem a little far out, but here it goes:
I'm starting to think that the nonlocality of entangled particles is not just a spatial nonlocality, but a temporal one as well. That is, the entanglement manifests itself when both particles are measured, even if they are measured at different times.
After all, why should nonlocality be confined to the three spatial dimensions?
So if you have Bob doing some things to his particle, and Alice doing some things to her particle, it doesn't really matter who does what first because Bob's manipulations will have no effect on Alice's particle until the particles are measured. That's why you can never say that one particle "caused" something to happen to the other particle, or vice versa. Everything happens when both particles are measured, even if they're measured at different times.
Apparently the idea of temporal nonlocality has been around since the 70's, though I haven't found any really good descriptions of the concept so I'm not sure I've described as it has been generally used. It does answer my question about the FTL possibilities that started this whole thing, though, which is nice. I think that as I've described it it's a defensible position, and I'd welcome any comment anyone might wish to make.
Bruce
Well, if they are space-like separated, it is observer dependent what is "first"!
That's exactly the paradox if you consider that something "causes" something else (collapse or so). I think your view is right that you cannot talk about anything "causing" anything else until the entire measurement is over, and the results are compared.
cheers,
Patrick.
cheers,
Patrick.
Well, in my opinion, it is an almost equivalent view when we remove the collapse interpretation artefacts (that are person dependent).
It is a simple matter of logic: othodox view: In => out, therefore knowing the "out" state, you can know "in" state, if between all possible inputs (~the marking information), "In" is the only state that may causes (=>) state "out". Thus you can say, in mathematics logic, that out => in assuming the right hypothesis (~the marking): it is a kind of induced causality.
But it brings nothing more or less than the in => out (it is an analogue view to the antiparticles moving backwards in time).
The problem with this “backward logic” rises when we have no simple one to one correspondence between the in and out state (e.g. space-like separated events, where the before and after may be defined within the context and thus participate to the marking or to the measurement).
But indeed, this backward logic is very close to the every day experiments.
I really think that the EPR state has nothing magic “like a faster than light”, or like “an incredible hidden rigid arm joining the two particles”. For me (attention, it is my personal view), EPR state is just a simple static state that just defines the “global probability law” of the 2 particles and thus the possible outcomes when one tries to look at them (note that an quantum outcome is a set of possibilities rather than a point, “the classical state”).
Therefore, a measure (local) on one particle just shows the event (the state) on this measured particle. This measure may, or may not, modify the local probability law of the measured particle (it depends on the measure action) and thus it also induces a modification of the “global probability law” of the 2 particles but it does not change anything of the other particle (before, during and after the measurement). It is just the “global probability law” and the “local probability law” of the measured particle that are changed.
It is quite analogue to 2 classical particles with a kinetic energy E= E1+E2, if you change the kinetic energy of particle 2, you thus induce instantaneously a change on the kinetic energy of the 2 particles E, but you don’t change the kinetic energy of particle 1. You may also define the kinetic energy of particle 1 respectively to the total kinetic energy E: E1’=E-E1, thus a change on kinetic energy of particle 2 induces a change on E1’, but you still not have changed particle 1. This example is very basic, but it underlines some possibilities and difficulties with global states.
For me again, the main problem with the EPR state is really to understand its probability law: why does a basic local hidden variable model seems not to comply with the statistical result of EPR state.
Remind that a spin EPR state is very close to a probabilistic law where the 2 particles have the same spin z axis thus inducing a global variable: the common spin z axis of the 2 particles. This common axis is distributed randomly with a probability law such that a spin measurement for each particle gives 50% chance for spin + event, and 50% chance for spin – event whatever the z axis chosen for the measurement.
Seratend.
Seratend.
Seratend,
It sounds like you don't really believe Bell's theorem. Remember that if the particles are measured on the same axis (which can be chosen randomly, ie., it does not have to be the common z axis of your proposal), they always give opposite spins. Further, if measured 180 degrees apart, they always give the same result. And, most interestingly, if measured 120 degrees apart, they agree 75% of the time, and disagree 25% of the time. It is this last property that cannot be obtained by a hidden variable model, though it takes a little work to show it.
Bruce
bruce2g said:
Seratend,
It sounds like you don't really believe Bell's theorem. Bruce
No, I believe the formal results of Bell’s Theorem (not the many interpretations we can found all around the world). I also believe the koshen-specker theorem and the gleason’s theorem : ). I believe in the mathematics but I always question the "physical" interpretations :smile: .
So What I’ve said in the previous post is that an hypothetic statistical quantum state (we stay at the quantum level) mixture may give the results of individual measurements on particle 1 and 2 with a kind of global quantum variable (the common spin axis). I just try to use a statistical mixture of pure quantum states to show where this global correlation of the global state is. So beware, I’m not trying to use a hidden variable theory (for me a quantum state is not a point in a probabilistic space, but rather closer to a set points).
Note, that I don’t really check if this mixture is possible or 100% any-measurement true because you have to sum over all common z-axis direction with the correct coefficients to get it. However, it really gives the 50%/50% measurement result whatever local axis is chosen for measuring particle 1 or 2 and I think It also gives you the 75%, 25% correlations when you take only the samples |+> exclusive or |–> of one of the 2 particles.
I must admit that I’ve not checked this result :).
So if it is wrong, I’m dreadfully sorry, but this example aim is to underline what I think is closer to the global quantum property of the quantum global state. Like the kinetic energy example: there is no “magic”, just a state coupling that is generated locally (when the 2 particles are in the same space location) at the creation of the EPR state,.
bruce2g said:
Seratend,
Bruce
I agree with this result (I believe in QM born rules), but you forget to say all the conditions to get the 75%/25% result:
Take the entangled spin state |psi>= (|+>|-> - |->|+>) of your two particles.
This state may be re written as |psi>= (|a,+>|a,-> - |a,->|a,+>) = (|b,+>|b,-> - |b,->|b,+>) where a and b are the z axis direction when we explain formally the spin basis of the entangled state (I’ve removed the normalisations). We can change the common z axis direction: it does not change the global state of the entangled particles.
This states shows that a local measure, on a given z-axis, on one particle always gives you a 50/50%result whatever axis is chosen for the measurement of this particle.
Now, when you write “measurement 120 degrees apart with 75% and 25%” you are doing in fact conditional probabilities/measurements: you only take, for example, the spin |+> samples of particles 1 to get the 75% times and 25% times the particles 2 results. But you forget the other particles 2 associated to spin |-> particles 1 samples.
So, if you add the measurement of particles 2 associated to the spin |-> samples of particles 1 you will recover 50% particles 2 spin |+>, 50% particles spin |->.
The measurement of particles 2 does not need to know that we have measured the particles 1: Local measurement on particle 1 does not have any impact on measurement of particle 2 (unless there is an interaction).
But, yes, you are free to correlate the measurements results: and yes for all the subset of measurements of particle 1 with spin |+> results , we have 75% of particles 2 with spin |-> and 25% particles with |+> (or |+> then |-> :). And with this formal filtering I do not consider the other measurement events of particles 2 that corresponds to particles 1 with spin |->.
Seratend.
Seratend,
Thanks for starting up a new thread (simulating entanglement) on the general issue of nonlocality, and maybe we can address your issues there.
Meanwhile, to wrap up this thread (I hope), I was reading the book "Einstein's Moon" by F.David Peat (interesting book with some confusing parts), and on p.145 he paraphrases Roger Penrose: "A combined measurement of both photons, at A, and at B, is necessary to effect the creation of a space-time structure that connects the two quantum events... Finally, when the measurements are completed, this nonlocal space fixes itself."
So I think I was echoing his idea when I said above that "it doesn't really matter who does what first because Bob's manipulations will have no effect on Alice's particle until the particles are measured."
I still like this notion of "temporal nonlocality," and after I read a little bit more I'll try and start another thread on it.
Bruce
  • · Replies 43 ·
  • · Replies 24 ·
  • · Replies 32 ·
  • · Replies 17 ·
