Electric field, mathematical problem
The discussion revolves around a mathematical problem related to the derivation of the electric field formula, specifically focusing on the transition from the expression involving the magnitude of the vector r to its application in the electric field equation. The context includes mathematical reasoning and clarification of concepts related to electric fields.
  • One participant expresses confusion regarding the derivation of the electric field from the formula presented in a linked image, specifically questioning the treatment of the vector r.
  • Another participant explains that the vector r represents the distance from the point charge to the observation point and describes how to derive the unit vector from r.
  • A participant questions the transition from r^2 to r^3 in the electric field equation.
  • Further clarification is provided that multiplying the magnitude of the electric field by the unit vector results in the r^3 term appearing in the denominator of the equation.
The discussion contains multiple viewpoints regarding the mathematical derivation, with participants seeking clarification and providing explanations without reaching a consensus on the initial participant's confusion.
The discussion does not resolve the initial participant's confusion about the derivation steps, and assumptions regarding the treatment of constants and variables are not explicitly stated.
agolkar
hi :) it's me again. This is my second question in a few days, w/o being able to help anyone else, hope to be not too much pretentious :biggrin:
my doubt this time regards the mathematical passage underneath the formula (23) of this speech:
http://scarface.ngi.it/elet.jpg
disregard the text part because i don't think it's helpful in an english forum :biggrin: it just introduces the electric field and its properties.
The fact is I cannot understand the derivation done from the E formula, i thought that the thing to do was just derivating r (that, considering an orthogonal system with the origin in the (x0,y0,z0) point, is (x^2+y^2+z^2)^1/2) because i had to consider the rest as costant so out of the derivation but it isn't it.. any help? thanks :smile:
alex
Could you explain your problem a little more? The vector r goes from the co-ordinates of the point charge to the the point (x,y,z) where you want to find the electric field. It has magnitude [tex]|r| = \sqrt{\left( x - x_0 \right) + \left( y - y_0 \right) + \left( z - z_0 \right)}[/tex]. So if we divide r by this number, we have the vector of unit length pointing from the point charge to (x,y,z). We multiply this by the magnitude of the field, [tex]\frac{q}{4 \pi \epsilon_0 r^2}[/tex] so that the field intensity is [tex]\frac{q \vec{r}}{4 \pi \epsilon_0 \r^2 \r } = \frac{q \vec{r}}{4 \pi \epsilon_0 r^3} = \frac{q \vec{r}}{4 \pi \epsilon_0} \frac{1}{\left[ \left( x - x_0 \right)^2 + \left( y - y_0 \right)^2 + \left( z - z_0 \right) \right]^{ \frac{3}{2} }}[/tex].
why you pass from r^2 to r^3 ? :rolleyes:
Multiply the magnitude of the field by the vector per unit length, which is [tex]\frac{\vec{r}}{r}[/tex]. You get a [tex]r^3[/tex] at the bottom and the [tex]\vec{r}[/tex] at the top.
So, you get [tex]E = \frac{q \vec{r}}{4 \pi \epsilon_0 r^3}[/tex]
Then, you just substitute in for r :smile:
  • · Replies 22 ·
