Prove by Mathematical induction ,
The discussion revolves around proving that the product of n consecutive positive integers is divisible by n! using mathematical induction. Participants explore various approaches and methods to tackle the problem, including different starting points for induction and the implications of certain mathematical properties.
  • One participant asks how to prove that the product of n consecutive positive integers is divisible by n! using mathematical induction.
  • Another participant claims the statement is not true, providing a counter-example involving the sum of integers instead of the product.
  • Several participants clarify that the original claim pertains to the product of integers, not their sum.
  • One participant suggests two approaches for the induction proof, indicating a preference for the second method involving starting with the product of the first n integers.
  • A participant proposes a lemma regarding divisibility that could aid in the proof.
  • Another participant notes that in a sequence of n consecutive integers, at least one number must be divisible by any integer j where j ≤ n.
  • One participant describes their attempt to apply the second method of induction, detailing their progress and challenges in expanding the product.
  • Another participant discusses the combinatorial aspect of choosing n numbers from a sequence and relates it to the divisibility by n!.
  • Some participants express uncertainty about completing the proof by mathematical induction, indicating that the problem is more complex than initially thought.
  • One participant shares a two-dimensional approach to the problem, suggesting that induction on both variables simultaneously may be necessary.
Participants do not reach a consensus on the validity of the original claim, with some asserting it is false while others attempt to prove it through various methods. The discussion remains unresolved regarding the proof's completion and the correctness of the initial statement.
Participants express limitations in their understanding and execution of mathematical induction, with some steps in their proposed proofs remaining unresolved or unclear.
3.14lwy
how to prove :
by using Mathematical induction , you can assume nCk is an integer ??
it is in urgent , please help , thank you! :smile:
You can't prove it because it's not true. You can disprove it with one counter-example
10+11+12=33
33 is not divisable by 3!
But 3! is 6.
but 33 isn't divisble by 3!, however, since 33 isn't the *product* of 3 consecutive integers, that's neither here nor there.
Doh silly mistake, I read it as sum instead of product.
Don't be ashamed, uart; I made a much sillier mistake..
Hehe, well after that mistake I thought I should at least solve it, which I just did. :)
Here's a clue for 3.14lwy :
There are two approaches you could take.
- One would be to start with a (a+1) is divisible by 2! and then try to show the a (a+1) ... (a+n-1) divisible by n! implies that a (a+1) ... (a+n) is divisible by (n+1)! That is, induction on n.
- The other approach is to start with 1 * 2 * 3 ... n is divisible by n! (a=1) and then try to prove that a (a+1) .. (a+n-1) divisible by n! implies that (a+1) (a+2) ... (a+n) is divisible by n!. That is, induction on a.
I found the latter approach to be easier.
Not sure if "you can assume nCk is an integer ??" is a question or a statement?, but ...
If I had to do this exercise I would want to prove the following lemma. Then, I think the induction step of the proof would follow easily from it.
For integers p and q, if p > q > 0 and p isn't evenly divisible by q then there exists an integer r such that p - q < r < p AND q evenly divides r.
In a sequence of n consecutive integers, there must be at least one number divisible by j where j <= n.
thanks you for all your replies , I will try uart's methods , thank you again :smile:
I have try the 2nd method for some time ,
I stop at there :
let P(a) be the prosition ' (a+1)(a+2)...(a+n) is divisible by n! '
when a = 0 , it is true ,
P(0) is true ,
assume P(a) is true for a = 1 , 2 , 3 ... k , where k is some non-negative integers
ie.
1*2*3*...*n = n!(N1)
2*3*4*...*(n+1) = n!(N2)
(a+1)(a+2)...(a+n) = n!(Na)
when a = k+1
(a+2)(a+3)...(a+n+1)
I try to expand it
= a^n
+ [1+2+...+(n+1)]a^(n-1)
+ [1*2 + 2*3 + ... + n(n+1)]a^(n-2)
+ [1*2*3 + 2*3*4 + (n-1)(n)(n+1)]a^(n-3)
+ 1*2*3*...*(n+1)
then i don't know how to do ...
Suppose the numbers in question are
(a+1)(a+2)...(a+n)
in how many ways can u choose n numbers out of (a+n) numbers?
this is C(a+n,n) = (a+n)!/a!n! =(a+1)(a+2)...(a+n)/n!
[/Color]::
TenaliRaman you are right ,
but the problem ask me to do it by M.I.
I can't finish it by M.I. :frown:
Hmmm, this problem is harder to do using MI than I thought. When I posted before I started scratching out a rough MI proof using the two starting points I mentioned above. The second one looked like it would just fall into place but when I just went to post the complete solution I realized that I just counldn't make one of the steps work. Sorry if I misled anyone :o
BTW. I know I've solved this problem before based on the method that Tilde posted above, it's not mathematical induction though.
This is a couple days late, but I think it works :
To prove : [itex](m)_n = m(m+1)(m+2)...(m+n-1)~||~n!~[/itex] (a||b means a is divisible by b)
Clearly, this is true for all m with n=1, and also for all n with m=1 (since n! || n!).
Assume the above statement is true for (i) n = N-1 and all m, as well as for (ii) n = N and m = M.
Now, [itex](M+1)..(M+N-1)(M+N) - M(M+1)..(M+N-1)[/itex]
[tex]= (M+N)[(M+1)..(M+N-1)] - M[(M+1)..(M+N-1)] = N[(M+1)..(M+N-1)][/tex]
Using the notation developed in the first line, above, this may be written as [itex](M+1)_N - M_N = N(M+1)_{N-1}[/itex]
Now, from assumption #(i), [itex](M+1)_{N-1}~||~(N-1)![/itex] so the RHS of the previous equation may be written as [itex]Nk(N-1)! = k(N!)[/itex]
So that gives [itex](M+1)_N = M_N + k(N!)[/itex]
But by assumption #(ii), [itex]M_N~||~N![/itex].
So that gives [itex](M+1)_N~||~N![/itex], or the statement is true for n = N and m = M+1.
It follows that the statement is true for n = N and all m.
Good work Gokul43201. I think that's the key, you need to do it two dimensionally, with induction on both variables at the same time. When I tried to do induction on just one variable I came to an impass but I could see a way that used both variable would work.
BTW this is the 2D solution I came up with,
Let the proposition P(a,n) denote that a (a+1) ... (a+n-1) || n!
You can show that assuming P(a+1,n) together with P(a,n+1) implies P(a+1,n+1).
P(a,n+1) : a (a+1) ... (a+n) = r (n+1)! {for some integer r}
P(a+1,n) : (a+1) (a+2) ... (a+n) = s n! {for some integer s}
Now consider P(a+1,n+1),
We need to show that (a+1)(a+2) ... (a+n+1) = t (n+1)! {for some integer t}
LHS = a (a+1) .. (a+n) + (n+1) (a+1) ... (a+n) : {after expanding by the (a+n+1) term}
= r (n+1)! + s (n+1)n! : {after substituting P(a,n+1) and P(a+1,n) respectively}
= (r+s)(n+1)!
Since it's easy to show that P(1,n) is true for all n and that P(a,1) is true for all a then the proof inductively follows for all a,n from P(a+1,n) and P(a,n+1) implies P(a+1,n+1).
eg,
P(2,1) and P(1,2) implies P(2,2)
P(2,2) and P(1,3) implies P(2,3)
P(2,3) and P(1,4) implies P(2,4)
... etc to build up the second row P(2,n) and then repeat for P(3,n), P(4,n) etc.
thank you :smile: :smile: :smile: :smile:
I will try the method. :smile:
  • · Replies 19 ·
