Can Rank Two Tensors Be Formed Using Dot Products?
  • Context: Graduate
  • Thread starter Thread starter xGAME-OVERx
    Algebra
The discussion revolves around the formation of rank two tensors using dot products, particularly in the context of Cartesian tensors. Participants explore the foundational aspects of rank two tensors, their properties, and the implications of using different bases for defining dot products.
  • Scott Smith inquires whether dot products can be formed from rank two tensors expressed as \( T = T_{ij} ( e_{i} \otimes e_{j} ) \).
  • One participant confirms that dot products can indeed be formed and notes that antisymmetric rank two tensors can have two directions, but this applies only to "pure" ones.
  • Scott proposes that for an orthonormal basis, the dot product of two tensor products results in \( \delta_{ij} \delta_{kl} \).
  • Another participant suggests an alternative definition of the dot product using a non-orthonormal basis, involving the magnitudes and angles between the basis vectors.
  • A later reply corrects Scott's index notation in the proposed formula for the dot product, indicating the correct relationships between the indices.
Participants express differing views on the properties of rank two tensors and the specifics of forming dot products, indicating that the discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made about the bases used for the tensors and the definitions of dot products, which may affect the interpretations of the participants.
xGAME-OVERx
Hi All,
I'm currently doing undergraduate research involving a lot of work with rank two Cartesian tensors, and I'm having trouble finding much information or good references on the foundations of such things.
It's my understanding that a rank two tensor can be written [tex]T = T_{ij} \left( e_{i} \otimes e_{j} )[/tex]. Can dot products be formed something like [tex]( e_i \otimes e_j ) \cdot ( e_k \otimes e_l )[/tex] ?
I've seen some references that say that much as a vector has a (single) direction, a rank two tensors has two directions. Is this always true?
Thanks in Advance
Scott Smith
Yes, you can make dot products.
Two directions are ok for antisymmetric rank 2 tensors - but exactly speaking only "pure" ones. One day you will learn about "wedge product" - it is important.
Thanks for the reply! I think I am aware of the wedge product, [tex]{\bf{a}} \wedge {{\bf{b}} = - {\bf{b}} \wedge {\bf{a}}[/tex], similar to the vector cross product?
So presumably [tex]( e_i \otimes e_j ) \cdot ( e_k \otimes e_l ) = \delta_{ij} \delta_{kl}[/tex] for an orthonormal basis?
It is possible to use a basis that isn't orthonormal, say [tex]u_i[/tex], and define the dot product as [tex]( u_i \otimes u_j ) \cdot ( u_k \otimes u_l ) = |u_i| |u_j| \cos \theta_{ij} |u_k| |u_l| \cos \theta_{kl}[/tex] ?
I think you got mixed with the indices, it should be:
[tex]( u_i \otimes u_j ) \cdot ( u_k \otimes u_l ) = |u_i| |u_k| \cos \theta_{ik} |u_j| |u_l| \cos \theta_{jl}[/tex]
As in [tex]( u_i \otimes u_j ) \cdot ( u_k \otimes u_l ) = <u_i , u_k> <u_j, u_l>[/tex]
Or so I remeber it that way.
Oops, sorry! Got the j and l indices backwards. Thanks!
  • · Replies 17 ·
  • · Replies 33 ·
