Thread Closed
WIKI and Time Dilation
Share Thread Thread Tools
Jan2-11, 11:27 PM   #69
Mentor
Quote by chinglu1998 View Post
So where is the third frame to apply the velocity add equations?
Why would you need a third frame?
Jan2-11, 11:27 PM   #70
Recognitions:
I never took him to mean all. So, I agree with you. But, I specifically focused on the Euclidian measurements of the stationary frame and that part is not refutable.
But you never explained why you think we can't also assume the same Euclidean laws hold in the moving frame, or why doing so would mean that "complete and total breakdown of SR occurs."
Even if you choose to label one frame as "stationary" and another as "moving", it is still true in the moving frame that the light postulate holds true in the coordinates of that frame (light has a coordinate velocity of c in all directions in the moving frame), and that in the coordinates of that frame the position of the light at any specific time T' satisfies x'2 + y'2 + z'2 = c2 T'2. So you still haven't given any non-confused explanation of what you meant in post #23 when you said "When you take a frame as stationary, you assume the Euclidian Geometry.
When you assume another frame is the moving frame, you apply the Minkowsky Geometry.
This is a vital distinction such that if the distinction is not clear, complete and total breakdown of SR occurs."[/QUOTE
In my post and statement "I assume the Euclidian Geometry" in the stationary system. Do you prove otherwise?
No, because I was talking about the moving frame, as I think was pretty clear from the bolded statements above. Do you disagree that in the moving frame, "the position of the light at any specific time T' satisfies x'2 + y'2 + z'2 = c2 T'2"? Isn't this "Euclidean geometry"?
This is not Minkowsky. If you attempy to apply Minkowsky to stationary system, you get failure.
You have never given any mathematical illustration of what you mean by "apply Minkowsky to stationary system" (and as I told you, the name is "Minkowski" with an i) or why this leads to "failure". As I said in post #25, this is what most physicists mean by "Minkowski geometry":
And can you give a numerical example of "apply the Minkowski geometry"? Normally I would say that Minkowski geometry is defined in terms of the metric, which says that the proper time between two events with coordinate separations [tex]\Delta t, \Delta x, \Delta y, \Delta z[/tex] is given by the formula [tex]\sqrt{\Delta t^2 - (1/c^2)*(\Delta x^2) - (1/c^2)*(\Delta y^2) - (1/c^2)*(\Delta z^2)}[/tex]. But this is true in all frames, even if we choose to label one of the frames as "stationary" like Einstein does. So I have no idea why you think Minkowski geometry doesn't apply in what you call the "stationary frame".
Do you disagree that the metric [tex]d\tau^2 = dt^2 - (1/c^2)dx^2 - (1/c^2)dy^2 - (1/c^2)dz^2[/tex] is what physicists normally mean by "Minkowski geometry", or that this equation still holds if we are dealing with the t,x,y,z coordinates of the "stationary" frame?
By the way, I notice you skipped my post #52 to reply to post #55. Hopefully you will go back to #52 and address it, particularly my request for an explanation of the precise step in my mathematical derivation that you think contains an error.
Jan2-11, 11:34 PM   #71
Quote by chinglu1988 View Post
So, t' = tγ.
This means when the unprimed frame is at rest and observering the to clock, it is moving and beating faster than it rest clock.
As with the calculation in my previous post, [tex]$\Delta{}t'=\gamma{}\Delta{}t\Rightarrow{}\Delta{}n'=\frac{\Delta{}n}{\ gamma}$[/tex], so in each frame clocks in motion tick slower than clocks at rest (no matter which frame is taken to be at rest).
Jan2-11, 11:36 PM   #72
Quote by JesseM View Post
I see you point. We did not communicate.
I meant when calculating the moving frame it is Minkowsky. In the moving frame, the relativity postulate holds. So, the equation for the light sphere holds in all frames, but when calculating those framea, it does not, the calculation is Minkowsky.
My intention was to understand what is moving coordinates and what is stationary. I made clear the word distinction.
If you apply Minkowsky to your own coordinates for you, that is failure. I made this clear. That is called frame mixing.
No, I do not. That is simply one componant of a space, it metric.
How exactly are you going to make this equation true exclusively within a stationary fame?
Thanks to poiint this out. I will look.
Jan2-11, 11:39 PM   #73
Quote by IsometricPion View Post
OK, how do you explain the WIKI article.
Would you please use the experiment in the article to prove reciprocal time dilation?
Jan2-11, 11:40 PM   #74
Recognitions:
Tes, I start to think WIKI is correct. The absolute light abberation causes a longer path for the light travel for the primed framer vs the unprimed frame in an absolute sense.
Let me take the unprimed frame as stationary. This promed frame light beam still longer.
cēt'ē = vēt'ē + cētē
cēt'ē - vēt'ē = cētē
t'ē( cē - vē) = cētē
t' = tγ
Wow, when taking the unprimed frame as stationary with absolute light abberation, the moving clock beats faster just like WIKI said.
No, any clock in the moving (primed) frame must be running slow as measured in the stationary (unprimed) frame. I showed why this is not incompatible with the wiki's time dilation equation in post #62.
You have to define the precise meanings of t and t' in your equations. t' doesn't deal with any single "moving clock", rather it is the time in the primed frame between the event of the light being emitted from the bottom of the light clock (which is at rest in the unprimed frame and therefore moving relative to the primed frame) and the event of it hitting the top of the light clock (this event will occur at a different position in the primed frame). To measure the time of these two events in the primed frame using clocks, you would need a pair of clocks at different positions in the primed frame. As I explained in #62, each of these primed clocks is individually running slow as measured in the unprimed frame, but the unprimed frame nevertheless agrees that t' is greater than t because of the way the two primed clocks are out-of-sync in the unprimed frame.
Jan2-11, 11:41 PM   #75
I did. Are they starting at (0,0,0,0) for both?
It was a very simple question, you don't have to do any math. Just read the question. If you have a space ship moving away from earth at .6c. From the ship's frame of reference which clock is moving slower the one of the ship or the one on earth?
Jan2-11, 11:41 PM   #76
If you do the math on WIKI, you will find if you take the unprimed frame as rest with respect to the primed frame, then t' = t γ.
If you take the primed frame as rest with respect to the unprimed frame, then t' = t γ.
So either way, it is absolute that t' = t γ. Why is this? This light beam path for the primed frame is absolutly longer than that of the unprimed frame because of light abberation. This is not a relative issue.
From the perspective of the primed frame, we have t = t' y. From the perspective of the unprimed frame, we have t' = t y. The unprimed frame is comparing the period for the light pulse to travel between the mirrors in the primed frame to the period that the primed frame measures for the same pulse to travel to the same mirrors in the primed frame also. The primed frame, however, is comparing the period for a different pulse to travel between the mirrors in the unprimed frame to the period the unprimed frame measure for that same pulse in the unprimed frame. These are two completely different sets of circumstances.
Jan2-11, 11:45 PM   #77
There is no single "moving clock". 25s is the time measured in the primed ('moving') frame between two events on the worldline of the clock at rest in the unprimed ('stationary') frame. But these events occur at two different positions in the primed frame, so you'd need a pair of clocks at rest and synchronized in the primed frame to assign time-coordinates to both events in a local way, after which you could figure out their difference in time-coordinates. That's how position and time coordinates are supposed to be assigned in SR, using a lattice of rulers and clocks at rest relative to one another and synchronized using the Einstein synchronization convention, as illustrated here:
Einstein also discusses the idea that coordinate times and coordinate positions should be defined using local measurements on a set of rulers and synchronized clocks in sections 1 and 2 of the 1905 paper you linked to.
As always, "moving" and "stationary" are arbitrary labels. Changing the labels does not magically change any facts about the amount of coordinate time between two specific events in different frames. Instead of playing these silly word-games, why don't you go through my analysis using the Lorentz transformation and figure out specifically where you think I made an error? Do you disagree that if a clock is at rest at x=0 in the unprimed frame, then the coordinates of it showing a time of 0 would be x=0,t=0 while the coordinates of it showing a time of 20 would be x=0,t=20? Do you disagree that when we transform x=0,t=0 into the primed frame we get t'=0, and when we transform x=0,t=20 into the primed frame we get t'=25? Please address these quantitative specifics instead of retreating into vague word-games.
Your conclusions are correct. Do you understand them?
Since LT matrix invertible, then t' = 25 and t = 20 regardless of which frame is at rest.
So if unprimed at rest, t' > t.
If primed frame at rest, then t' > t.
Have you figured this out yet?
Jan2-11, 11:46 PM   #78
Quote by darkhorror View Post
I am discussing this same subject with Jesse right now.
Jan2-11, 11:49 PM   #79
Recognitions:
I don't understand what "calculation" you refer to. If you mean we must use the Lorentz transformation to go from stationary coordinates to moving coordinates I agree, but it is equally true that we must use the Lorentz transformation to go from moving coordinates to stationary coordinates. So again I don't see why you think "Minkowski" applies to the moving frame but not to the stationary frame.
I don't know what you mean by "apply Minkowski to your own coordinates for you", but whatever it means, presumably it would be equally a mistake for the stationary observer to "apply Minkowski to his own coordinates for himself" and a mistake for the moving observer to "apply Minkowski to his own coordinates for himself"? As always the situation is completely symmetrical, there's no sense in which it is correct to "apply Minkowski" in the moving frame but not to do something equivalent in the stationary frame.
Huh? I never said anything about it being exclusive to the stationary frame, I said 'this equation still holds if we are dealing with the t,x,y,z coordinates of the "stationary" frame?'--that "still" was to indicate that although it's true this Minkowski equation holds in the moving frame, it also holds in the stationary frame. It holds in all inertial frames, so again I don't see how it makes sense to say that Minkowski geometry should only be used in the moving frame and Euclidean geometry should only be used in the stationary frame. For any equation (Euclidean or Minkowski) which applies to a situation in one frame, you can find an equivalent situation in any other frame where the same equation applies.
Jan2-11, 11:49 PM   #80
Quote by grav-universe View Post
How do you make this hsppen with the WIKI article give the fact light abberation is absolute?
That means, the clock at rest with the light source will measure t=d/c and the frame that views that clock as moving will also conclude it calculates t=d/c and it will view a light beam at an angle with a longer distance to travel. Light abberation is not reciprocal. It is only true for observers moving relative to the light source.
Jan2-11, 11:57 PM   #81
Oh, you are not familiar with topological spaces. You have a space and then a mapping to another space. That mapped space if not isomorphic is not the same as the original space.
So, in my mind, I see the two as two different objects.
There is the stationary space which has Euclidian properties.
There is the Minkowsky space which has odd properties. The light sphere in Minkowsky is off center and not spherical.
It is my view these are different. If you have your view fine. This is simply my view.
We agree.
Good, can you apply the Minkowski metric only to the stationary frame and none other?
Jan2-11, 11:59 PM   #82
Recognitions:
I still don't understand the significance of calling one frame "at rest" other than it just being a totally arbitrary label like "frame A" or "the friendly frame". Switching such arbitrary labels has no mathematical significance whatsoever, so if you switch the labels but change nothing else about the problem the mathematical analysis will be exactly the same, you don't have to "invert" the LT matrix or any other such mathematical change in your calculations.
Since I think "at rest" is a totally arbitrary verbal label of course I agree that changing the label won't change any mathematical fact like t' > t. But this is assuming that aside from changing the labels we are leaving the physical facts of the problem unchanged--specifically, we are still dealing with a problem where we have two events on the worldline of a clock in the unprimed frame and want to know the time between these events in both frames. If on the other hand we had two events on the worldline of a clock in the primed frame, then in this case t > t' (and again this would be true regardless of which frame we called 'stationary'). As I said back in post #25, all that matters is which frame the clock we're analyzing is in (i.e. the clock whose worldline the two events are on), once you know that the time dilation equation always has the following form:
(time interval in frame of observer who sees clock in motion) = (time elapsed on clock)*gamma
Do you agree that this always works, regardless of what frame the clock is in or which frame we choose to label "stationary"?
Jan3-11, 12:01 AM   #83
They are two different light pulses. Light pulse 1 bounces back and forth between the mirrors in the unprimed frame, so t1 = 2 d / c. A clock in the primed frame measures t1' = (2 d / c) / sqrt(1 - (v / c)^2) for light pulse 1 to travel between the mirrors of the unprimed frame, so t1' = t1 y. Vice versely, a light pulse 2 that bounces between the mirrors in the primed frame will give t2 = t2' y. Each sees the other's clock time dilating.
Jan3-11, 12:07 AM   #84
Recognitions:
A change in coordinates cannot take you into a different "topological space" if the geometry (given by the metric) is unchanged.
I have only seen physicists refer to Minkowski spacetime, not "Minkowski space" in the sense of a 3D space containing only a light sphere rather than a full 4D light cone. Is this a term you have made up? Can you give any precise mathematical definition of what you mean by "Minkowski space"?
Quote by JesseM
Uh, did you read anything I wrote above? I was specifically pointing out that I never claimed "you apply the Minkowski metric only to the stationary frame and none other", this is a strawman that is the exact opposite of what I have been saying. What part of "it's true this Minkowski equation holds in the moving frame" and "it holds in all inertial frames" didn't you understand? It was you who seemed to claim that the moving frame is Minkowski but that the stationary frame is not Minkowski, while I am saying that all frames are on equal footing as far as all equations are concerned, and "stationary" vs. "moving" has no significance except as an arbitrary verbal label.
Jan3-11, 12:30 AM   #85
If you take the unprimed frame as at rest with respect to the primed frame, then t' = t.
If you take the primed frame as at rest with respect to the unprimed frame, then t' = t.
The v in the gamma factor is the velocity of the two frames relative to each other. If the two frames are at rest with respect to each other then v=0 and gamma=1 and t'=t.
Under SR, a moving clock is supposed to beat slower. What about the WIKI article?
From the equation:
[tex]t' = t \gamma [/tex]
the elapsed time t' is greater than t for any none zero v. Agree?
t is the time measured by a single clock (A) at rest in frame S. Let us say t= 10 seconds. In frame S' clock A appears to be moving at 0.8c which is the velocity of frame S' relative to S. Let us say we have two clocks (B' and C') that are at rest in frame S' and that clock A is initially adjacent to clock B' and ends up adjacent to clock C'. The time measured by the synchronised clocks (B' and C') at rest in S' is 16.666 seconds. So the time measured in frame S' by the moving clock (A) is less than the time measured by clocks B' and C' that at rest in frame S'. This is in agreement with what you say should happen. Note that the time that elapses on clock A is the same (10 seconds) according to observers in frame S AND frame S'. The time interval of 16.666 seconds measured in S' is measured by two spatially separated clocks and is NOT the time measured by clock A according to any observer. Clock A is only running slow in a relative sense compared to the coordinate time difference measured by separate clocks.
Thread Closed
Thread Tools
Similar Threads for: WIKI and Time Dilation
Thread Forum Replies
Gravitational time dilation vs velocity time dilation Special & General Relativity 22
Relating SR time dilation and GR time-passage variation Special & General Relativity 0
Black Hole Time Machine (time dilation) Special & General Relativity 13
Calculating Gravitational Time Dilation in black hole/Future Time Travel Special & General Relativity 5
