Parametric path of great circle on sphere
The discussion focuses on generating parametric equations for the angles phi and theta in spherical coordinates to model the rotation of a sphere around an arbitrary axis. The user is utilizing a graphics library that requires constant angular speed, specifically in terms of time. The goal is to derive expressions that maintain a constant rate of change in the angles while adhering to spherical coordinate systems. The conversation highlights the need for clarity on whether the rotation is purely about a specified axis or if it involves visualizing great circles.
  • Spherical coordinates and their properties
  • Understanding of parametric equations
  • Basic knowledge of angular velocity and constant speed
  • Familiarity with 2D graphics libraries for rendering
  • Research the mathematical foundations of spherical coordinates
  • Learn about parametric equations in the context of circular motion
  • Explore the implementation of constant angular velocity in graphics programming
  • Investigate the concept of great circles and their parameterization
Mathematicians, physicists, computer graphics developers, and anyone interested in modeling rotational dynamics in spherical coordinates.
zyxstand
hello, I've posted this question on a math forum, but they weren't much help - this really is more appropriate in physics ;)
i'm working on a computer program and I'm using a library that generates a 2D graphics of a circle given a theta and phi. if i want to make the ball rotate around its normal axis, i would call the library's rendering function and pass the same theta every time, but with phi being slightly different. this, of course, is only the case for for rotation around an axis through the poles.
my question
given a starting phi and theta and a velocity phi and theta, what are the parametric expressions for phi and theta in terms of time.
things to keep in mind
1. I'm working purely with spherical coordinates (no cartesian) and i would prefer a solution that solved in such a coordinate system.
2. it needs to be time dependent in such a way that dl/dt is constant (ie: constant angular speed)
what I've tried
i figured i would first need an equation of the path and then parameterize it later. unfortunately i don't know spherical that well :/
any help will be greatly appreciated!
Just to clarify what you are trying to do. Are you wanting to do a pure rotation about some given axis? What I am picturing is a sphere with, for example, several latitude lines painted on it, like a wireframe. Then are you wanting to see what it would look like if rotated about some axis other than the common diameter of the latitude lines? Are you only interested in the images of great circles? Are you just looking for a parameterization of an arbitrary great circle in terms of the spherical angles phi and theta? Please explain in a bit more detail what you want.
