Experimental Determination of Fundamental EM Constants
The discussion centers around the experimental determination of fundamental constants in electromagnetism, specifically the permittivity and permeability of free space, as well as the definition of the unit of charge (coulomb). Participants seek references and descriptions of how these constants are measured and defined, with some expressing a desire for more traditional experimental methods.
  • Historical
  • Some participants inquire about good references for understanding how fundamental constants like permittivity and permeability are experimentally determined.
  • One participant suggests looking at the CRC Handbook and CODATA standards for accepted values and methods of measurement for constants like "e" and "h".
  • Another participant notes that \(\epsilon_0\) and \(\mu_0\) are now defined constants and not experimentally determined, linking this to the definition of the speed of light and its role in defining the meter.
  • There is a question regarding which of the constants (permittivity, permeability, and c) are used as standards and which can be measured more precisely.
  • A participant expresses a nostalgic view on the importance of traditional experiments in determining these constants, contrasting it with modern definitions based on theoretical constructs.
  • One participant mentions the historical context of how these quantities were defined in the past, suggesting that while ad-hoc measurements can be made, they may not be as accurate as current standards.
Participants express a mix of curiosity about historical methods and current standards, with some agreeing that modern definitions are more accurate, while others lament the loss of traditional experimental approaches. There is no clear consensus on the best methods or the importance of historical versus modern definitions.
Some discussions touch on the limitations of current definitions, such as the lack of experimental determination for certain constants and the challenges of measuring permittivity due to fringing effects. There is also mention of the historical drift associated with physical standards.
Reality_Patrol
Can anyone provide a good reference (preferably on-line), or a decent description, of how the fundamental constants of electromagnetism are experimentally determined?
I'm talking about constants like the permitivity and permeability of free space. I'm also curious how the unit of charge (coulomb) is defined experimentally. Perhaps more how the "standard of measurement" for the coulomb is defined -not how the fundamental charge on an electron was determined (I've got that one!).
(Also, I've seen in other posts use inset math typesets, which I would like to do here but I don't know how! Can anyone provide some guidance for this as well?)
Thanks in advance
Thanks in advance
For permitivity and permeability, you should look at something like CRC Handbook, available at most libraries. For the accepted standards of fundamental constants like "e", "h", etc., you need to look at the CODATA standards. Refer to P.J. Mohr and B.N. Taylor, Rev. Mod. Phys. v.72, p.351 (2000). "e" is defined from a superconductivity measurement while "h" is from a quantum hall effect measurement. The CODATA paper explains the experiment and how these values are obtained.
Zz.
See this thread
Anyone know which of permittivity, permeability, and c are used as standards? Which 2 of the 3 values can be measured more precisely? Is the third standard from a third experiment or from their relation?
Try
http://physics.nist.gov/cgi-bin/cuu/Category?view=html&Universal.x=84&Universal.y=11
when you look under "electric constant" and "magnetic constant", you'll see that [tex]\epsilon_0[/tex] and [tex]\mu_0[/tex] are exact. This means they aren't experimentally determined nowadays, they have defined standard values.
This shouldn't come as a surprise, the speed of light has been used to define the meter for some time now, so c is constant, and the magnetic permeability has also been fixed for some time. For the basic fundamental defintions of the SI base units like distance and time see
http://physics.nist.gov/cuu/Units/current.html
For more on mangetic permability, you can try also
http://scienceworld.wolfram.com/physics/PermeabilityofFreeSpace.html
Well, thanks to all for the many fine answers. The on-line references spell it all out clearly. Still, seeing the values of these fundamental quantities so cleverly defined, mostly through thought experiment, leaves one without a warm fuzzy. Ahh, maybe I'm old fashioned but a good experiment is still worth the effort.
I guess I was being naive in hoping there was still a standard in use for determining their values based on the use of capacitors & inductors.
Again, many thanks for the answers!
Probably what you want is the history of how these quantities used to be defined, back in the old days when the meter was defined by two marks on a bar of metal kept in Paris.
Unfortunately that's a bit harder to find out, though it is certainly possible to easily come up with some ad-hoc measurements for at least some of them.
For instance, one might start off with measuring the capacitance of two parallel plates to estimate the permittivity of free space, of course this measurement would be off because of "fringing" effects.
We really have only gained by moving away from the old meter standard, though - the new standards are much more accurate and repeatable, and don't have the problem of "drift" that physical standards do.
  • · Replies 29 ·
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 28 ·
  • · Replies 0 ·
