Optimizing Projectile Distance from a Plateau: A Challenging Kinematics Problem
  • Context: Undergrad
  • Thread starter Thread starter Machinus
The discussion revolves around determining the optimal launch angle for a projectile fired from a plateau to achieve maximum distance when landing on a lower surface. Participants explore various mathematical approaches and computational tools to solve the kinematics problem, including the effects of height on the optimal angle.
  • One participant describes their attempts to calculate the launch angle using Maple, expressing difficulties with the quadratic solutions encountered.
  • Another participant asserts that the optimal angle for maximum range is typically 45 degrees, referencing a formula for projectile range.
  • A correction is made regarding the scenario of launching from a height, indicating that the optimal angle is affected by this condition.
  • Participants discuss taking derivatives of the range equation to find critical points, noting the complexity of the resulting expressions.
  • One participant shares a derived expression for the maximum distance and the corresponding angle in terms of initial velocity and height.
  • There is mention of multiple solutions for time in the projectile's motion, with emphasis on selecting the positive solution for maximum distance.
  • Concerns are raised about the notation used in the mathematical expressions, particularly regarding the use of 'tan' without arguments.
  • A participant mentions that their professor provided a solution, which aligns with earlier contributions in the thread, confirming the derived angle formula.
  • Another participant acknowledges the equivalence of different derived expressions for the optimal angle.
  • One participant indicates that the optimal angle is dependent on the height of the launch platform and expresses interest in visualizing the results graphically.
Participants do not reach a consensus on a single method for solving the problem, as multiple approaches and interpretations are presented. There is acknowledgment of different derived expressions for the optimal angle, but no definitive agreement on a singular solution method.
Some participants note the complexity of the equations involved and the potential for multiple solutions, highlighting the need for careful selection of the appropriate solution based on physical context.
This discussion may be useful for students and practitioners in physics and engineering who are interested in projectile motion, kinematics, and mathematical modeling of physical systems.
Machinus
challenging kinematics problem
Here is a problem I have been trying in Maple, but to no avail.
I am trying to calculate the theta that will result in maximum distance for a projectile fired from off the edge of plateau onto another, lower surface. The projectile can be considered to be fired from the exact corner of the ledge so there is no minumim distance; a velocity of zero will result in the projectile moving no distance but falling onto the lower surface.
...v[0]
______/
...|______
(ignore the periods. the slash is the vector)
The method I have tried is to try to solve for t using the y-coordinates of motion, and then plug this back into the x-equation, which is linear. However, in trying to solve for t with the y-equations, I get two very nasty solutions (due to the quadratic solution) that I really am not going to do by hand, and Maple has decided not to cooperate. I am using Maple 9.5 and I know my way around, and I don't think there is any more I can do this way. If anyone knows of a better way to solve this, please let me know. Thanks.
The angle for best range is always 45 degrees above the horizontal.
See this page: http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html#tra12
The range of a projectile is
[tex]R = \frac{v_0^2 \sin{2 \theta}}{g}[/tex]
Assuming [itex]v_0[/itex] is a constant, you're just solving for the maximum of [itex]\sin{2 \theta}[/itex]. The maximum value of the sine function is one, when its argument is [itex]\pi / 2[/itex], or when [itex]\theta = \pi / 4 = 45^o[/itex].
- Warren
Ah, actually, it serves me right for not reading carefully enough. You're trying to solve for the case with a launch platform higher than the landing site. (cyrus, you're right, it does indeed affect the best angle). You're trying to sovle the general equation shown here:
http://hyperphysics.phy-astr.gsu.edu/hbase/imgmec/tra9.gif
Sorry about that.
You should be able to just take the derivative of the expression with respect to theta and solve for its zeroes:
[tex]R = v\cos(\theta) \left[ \frac{2 v \sin(\theta) y}{g} \pm \sqrt{ \frac{(v \sin(\theta))^2}{g^2} - \frac{2 y}{g}} \right][/tex]
- Warren
I was really distraught when you posted that! Thanks for the correction.
I did take the derivative and solve for zero. That proved to be quite unwieldy and difficult to simplify. Thank you for the confirmation, however. Is there any other way to solve this?
Machinus,
I'll put it through Mathematica when I get home. I agree in that I'm not about to try to solve that one by hand. :wink:
- Warren
OK, it takes some fooling around, but my ancient version of maple gets it. First we solve for the time as a function of the height h, assumed here to be positve when the projectile drops
[tex] {\frac {{\it vy}+\sqrt {{{\it vy}}^{2}+2\,gh}}{g}}[/tex]
then xmax is given by
[tex] {\frac {v\cos \left( \theta \right) \left( v\sin \left( \theta<br /> \right) +\sqrt {{v}^{2} \left( \sin \left( \theta \right) \right) ^{<br /> 2}+2\,gh} \right) }{g}}[/tex]
then we make the substitutions
sin(theta) = tan/sqrt(1+tan^2), cos(theta)=1/sqrt(1+tan^2)
and tell maple to simplify, we get
[tex] {\frac {v \left( v \left( \tan \right) +\sqrt {{v}^{2}{\tan}^{2}+2\,gh<br /> +2\,gh{\tan}^{2}} \right) }{ \left( 1+{\tan}^{2} \right) g}}[/tex]
solving for the derivative of the above to be zero wrt tan, we get
tan = v/sqrt(v^2+2gh)
which is the value of the tangent of the angle theta.
How did you get such a simple t? Also, aren't there two solutions?
hey warren, that website is incorrect. It should be Vy/g, not 2Vy/g I think they made a mathematical error. I got the same equation as pervect. Yes, two solutions, but you want the one that is positive and largest. This will be the max time. so the distance x=vx *t will have the largest value.
I put
[edit] minus ! [edit]
y := vy*t - .5*g*t^2;
solve(y=-h,t);
into Maple. I also did a foo:=sub(t=<expr>,y);simplify(foo);
But I''d encourage you to double check, just on general principles.
pervect:
Something about your tans without arguments is deeply unsettling to me.
- Warren
hey warren, did u see the error?
chroot said:
pervect:
- Warren
OK, use 'u' or something that's more innocuous if 'tan' without arguments is too unsettling...
I forgot to mention - choose the time solution that's positive.
Well, thanks to all for the help, but my professor from Fermi has solved it for me relatively easily. I haven't seen his work yet but he presented the solution to another student who knew that I was working on the problem. Without further ado:
[tex]\theta_{max}=\arctan(\frac{v_{0}}{\sqrt{v_{0}^2+2gh}})[/tex]
If you will note, an encouraging check to this problem is to substitute zero for the height, and the formula reduces to
[tex]\theta_{max}=\arctan(\frac{v_{0}}{v_{0}})[/tex]
which is of course 45 degrees, the correct value from a projectile on a flat surface.
Thank you professor Davenport!
We also got that anwser machinus, did you read what pervect posted, he solved it with maple
Ah, yes, now I see that they are the same answer. I thought it was kind of unclear, but you are right. Thank you!
Dont thank me thank pervect, and I will thank him too, thanks. I thought that was an interesting problem. What did the angle you were looking for turn out to be?
The angle is dependent on the height. Right now I am working on making a nice-looking graph to display the results.
  • · Replies 36 ·
23K
  • · Replies 35 ·
  • · Replies 17 ·
