Calculating Kinetic Energy of a Diver Using Conservation of Mechanical Energy
The discussion focuses on calculating the kinetic energy of a 66.0 kg diver falling from a height of 4.90 m, using the principle of conservation of mechanical energy. The diver's initial speed is 8.20 m/s, and air friction is neglected. The final kinetic energy is calculated using the formula KE_final = PE_initial + KE_initial, resulting in a value of 5388.2 Joules. The calculations confirm the accuracy of the conservation of energy approach in determining the diver's kinetic energy upon impact with the water.
  • Understanding of kinetic energy (KE) and potential energy (PE) formulas
  • Familiarity with the concept of conservation of mechanical energy
  • Basic knowledge of physics, specifically mechanics
  • Ability to perform calculations involving mass, height, and velocity
  • Study the derivation and application of the conservation of mechanical energy principle
  • Learn about the effects of air resistance on falling objects
  • Explore advanced topics in energy transformations in physics
  • Investigate real-world applications of kinetic energy calculations in sports and engineering
This discussion is beneficial for physics students, educators, and anyone interested in understanding energy conservation principles in mechanics, particularly in scenarios involving falling objects.
songokou77
Kinetic Energy, Help!
A 66.0 kg diver is 4.90 m above the water, falling at speed of 8.20 m/s. Calculate her kinetic energy as she hits the water. (Neglect air friction)
Then the problem hints:Use conservation of mechanical energy.
So I'm thinking that conservation is K_f+U_f=K_i+U_i but there must something wrong with my calculations>
K=1/2(m*v^2) and U=mgh right?
ok let's say that delta (the triangle) is represented by d in my calcultions
dK + dU = 0 conservation of energy
KE (final) - KE (Initial) + PE (Initial) - PE (final) = 0
sinceu want a value for KE final
PE (final) = m g (0) = 0 because as diver hits water height is zero
KE final = PE (initial) + KE (initial)
now sub in and see what you get
From KE_final=PE(initial)+KE(initial) i get:
(66.0)(9.8)(4.90)+1/2(66.0)(8.20^2)= 5388.2 and it was right thanxs a lot
