Argument Of Transfer Function - What does arg(T(w)) mean in real life
The discussion revolves around the interpretation of the argument of a transfer function, specifically in the context of a low pass filter. Participants explore the mathematical expressions for the transfer function, its magnitude, and phase, as well as the implications of phase lag in sinusoidal inputs.
  • One participant presents the transfer function T(w) = V2/V1 for a low pass filter and seeks to determine |T(w)| and arg(T(w)), expressing confusion about the phase relationship when V2 lags V1 by 45°.
  • Another participant confirms the expression for arg(T(w)) as tan(x) = -RwC and discusses the relationship between the phases of complex quantities V1(jω), V2(jω), and T(jω).
  • A further contribution suggests that the transfer function can be expressed in terms of polar form, raising questions about the addition of phases and the use of complex notation.
  • One participant clarifies that the transfer function is typically expressed in the s-domain and discusses the implications of amplitude and phase changes in linear systems.
  • There is a suggestion to find the frequency at which the phase of the transfer function is -45 degrees and the corresponding gain, indicating a focus on practical application.
Participants exhibit some agreement on the mathematical expressions for the transfer function and its components, but there remains confusion and uncertainty regarding the interpretation of phase relationships and the implications of lag in the context of the filter.
Participants express uncertainty about the conventions used in their coursework, particularly regarding the representation of complex quantities and the relationship between time and frequency domains.
This discussion may be useful for students and practitioners in electrical engineering, particularly those studying circuit analysis and transfer functions in the context of signal processing.
thomas49th
Hi, I have a question something along the lines of
Here is a low pass filter, when the resistor = R and the capacitor = C. There is a sinusoidal voltage input source (V1) and a voltage across the capacitor (V2). The transfer function is T(w) = V2/V1.
Determine the |T(w)| and arg(T(w)) where T(w) is the transfer function. Calculate the magnitude of T(w) when V2 lags V1 by 45°
OKAY! So w = 2*pi*f.
T(w) = [tex]\frac{1-jRwC} {-(RWC)^2 - 1}[/tex]
|T(w)| = [tex]\frac{\sqrt{1+(RwC)^2}}{(RWC)^2 - 1}[/tex]
so am I right in thinking arg(T(w)) is tan(x) = -RwC?
BUT how on Earth do I determine the magnitude when V2 lags V1 by 45°. I thought the capacitor only lags current. I'm confused
Thanks
Yes, that's right.
BUT how on Earth do I determine the magnitude when V2 lags V1 by 45°. I thought the capacitor only lags current. I'm confused.
V1(jω), V2(jω), and T(jω) are all complex quantities, so you can write each in polar form, i.e., re. How are the phases of these three complex quantities related?
[tex] r = \sqrt{1+(RwC)^2}[/tex]
ϕ = arctan(-RwC)
V2/V1 = T is that what you were suggesting? so can you say that something like T(jw) = V1(jw)/V2(j(w-pi/2))?
P.S How did you get to use super and sub script without LaTex?
EDIT: Is any of this useful
V1 = cos(w) + jsin(w)
V1 = e^(jϕ)
V2 = V1/(100jwC + 1)
or am I just spouting obvious facts?
Is there like some magical property such that the phases add up to 90°?
I thought about adding phasers together but If you wanted me to do that you wouldn't of suggested converting into polar notation as that is useful for multiplication and division?
Why have you written j's in front of the w's? Are you talking about the complex part only?
Thanks
Thomas
To get subscripts and superscript, go into advanced mode when posting, and you'll see options above the input area.
I'm not sure how far along you're into this network analysis stuff, but the transfer function is usually written as a function of s, that is, H(s) = Vo(s)/Vi(s). You talk about the s domain and the time domain, blah blah blah. When you're looking at a pure sine wave of frequency ω, that corresponds to the case when s=jω, so you often see quantities written as function of jω. It's just a convention. Maybe your class does it differently. (I'm going to use s instead of jω because it's easier to type. Just replace s with jω or simply ω everywhere you see it.)
What linear systems do is: 1) change the amplitude of a signal, and 2) change the phase of a signal. The factor by which the amplitude changes is called the gain. It corresponds to the magnitude of the transfer function. The shift in phase of the signal, as you can probably guess, is equal to the phase of the transfer function. Hopefully you can see this from the relationship Vo(s) = H(s) Vi(s), but I'll leave it to you to convince yourself that the statements are true.
So what the problem is asking you to find is the frequency at which the phase of the transfer function is -45 degrees and then to find the corresponding gain.
  • · Replies 16 ·
