New Reply
root mean square speed of helium atom
Share Thread Thread Tools
Jan9-11, 09:22 PM   #1
Helium is used to fill a balloon of diameter 44 cm at 22 degrees C and 0.9 atm.
The mass of a helium atom is 4.0026 u, the conversion factor from u to kg is 1.66 x 10^-27 kg/u, the conversion factor from atm to Pa is 1.013 X 10^5 Pa/atm, the universal gas constant is 8.31451 J/K mol, the Boltzmann's constant is 1.38066 x 10^-23 J/K.
What is the average speed (ie, the root mean square speed) of each Helium atom? Answer in units of m/s.
2. Relevant equations
Vrms = sqrt(3RT/M)
3. The attempt at a solution
I think my problem is with finding the mass. I did this:
4.0026 x 1.66 x 10^-27 = 6.644316 x 10^-27
Then:
T = 22C = 295K
R = 8.31451
Sqrt( (3 x 8.31451 x 295)/6.644316 x 10^-27)
I got:
1.0523612 x 10^15
That is wrong. Any help on where I messed up? Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan9-11, 09:31 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
M means the mass of 1 mole of a substance. The mass of 1 mole of He is 4.0026 g. Edit: So M=4.0026 x 10-3 kg/mol.
ehild
Jan9-11, 09:33 PM   #3
Recognitions:
Gold Membership Gold Member
If you use the mass of one atom in the denominator, you have to use the Boltzmann constant k in the numerator, not the universal gas constant R.
Jan9-11, 10:00 PM   #4
So it should be:
Vrms = sqrt( 3KbT/m )
And I got:
3 x 1.38066e-23 x 295 / 4.0026 = 3.052725978e-21
sqrt(3.052725978e-21) = 5.52514794e-11
I haven't tried to see if that's right yet. Does it look right to you guys? Thanks again.
Jan9-11, 11:49 PM   #5
Recognitions:
No, it is wrong again. Accept only one piece of advice :). Either use Kb with the real mass of the He atom (6.644316 x 10^-27 kg)
or the molar mass with R, but not both.
ehild
Jan10-11, 12:03 AM   #6
So I just need to use 4.0026 like I was doing it in the first way correct?
So:
Sqrt( (3 x 8.31451 x 295)/4.0026 )
This one is with the mass of a single molecule.
Or:
Sqrt( (3 x 1.38066e-23 x 295)/6.644316e-27 )
And this one is the mass of the whole atom.
Am I following correctly?
Thanks for the help. I'm pretty much having to teach this to myself. Don't know what I would do without this place. The internet is great.
Jan10-11, 01:08 AM   #7
Recognitions:
4.0026 is not the mass but the ratio of the mass of one He atom to that of 1/12th of the mass of C12 atom.
NA atoms ( the Avogadro number) have the mass of one mole of substance. In case of He, it is 4.0026 g, equal to 4.0026x10-3 kg.
ehild
Jan10-11, 11:07 AM   #8
Ok. I've been looking up on how to do molar mass stuff, and I think I may have it now.
The formula for molar masses is:
Na = m/M or Avogadro's Number = Number of Moles / Molar Mass
So, for the example of helium, the M in grams is: 4.0026 g/mol
Converting this to kg gives: 4.0026e-3 kg/mol
Using the above formula:
Na = m/M
6.02e23 = m / 4.0026e-3 m = 2.4095652e21
So in the original problem:
Vrms = sqrt(3RT/M) M = 4.0026e-3
Vrms = sqrt( 3KbT/m ) m = 2.4095652e21
Where am I going wrong?
When I was working this out earlier I thought this was right, but I am getting two different answers when I plug them into the equations, so I guess I have made another mistake somewhere.
Jan10-11, 11:15 AM   #9
Recognitions:
Quote by dlthompson81 View Post
No, the molar mass is the mass of NA (about 6x 1023 atoms). Just think, how small an atom is. Can it be 1021kg?
ehild
Jan11-11, 05:37 AM   #10
Recognitions:
Na = m/M
This is where you went wrong. Actually, NA=M/m.
For hydrogen, M = 1 gram (to a good approximation); it is no coincidence that the inverse of the proton's mass (in grams) is a number that matches Avogadro's number.
Jan11-11, 06:02 AM   #11
I guess rms & most probable speed are different for group of molicules
rms speed = sqrt (3RT/M)
most probable speed = sqrt (2RT/M)
average speed = sqrt (8RT/πM)
Jan11-11, 11:58 AM   #12
Quote by kuruman View Post
Ok. So I reworked everything out since I had my formula backwards:
NA=M/m
6.02e23 = 4.0026e-3/m
M = 4.0026e-3
m = 6.64883721e-27
Back to the other formulas:
Vrms = sqrt( 3RT / M )
sqrt( (3 x 8.31451 x 295) / 4.0026e-3 ) = 1355.872554
And
Vrms = sqrt( 3KbT / m )
sqrt( (3 x 1.38066e-23 x 295) / 6.64883721e-27 ) = 1355.633077
Maybe I'm closer to right this time? Would those two answers be in m/s if they are right?
Jan11-11, 01:20 PM   #13
Why you tried the two formulas, they are same!!!
3KT/m = 3Rt/mNa = 3RT/M
and for m/s ... it depends on what unites you used in the constants ...
You used all values in SI so speed will be in SI ... i.e. m/s !!!!
Jan11-11, 01:31 PM   #14
Quote by cupid.callin View Post
I used both formulas because I wanted to be sure I had the correct understanding of what m and M were.
Thanks. Was trying to figure out where the m/s came in. I guess I should have been writing my units down in all my calculations in order to see.
Jan11-11, 02:08 PM   #15
well if you really want to see then this will be a very good homework!!! LOL!!!
Jun26-12, 09:29 PM   #16
kg/mol meanig, 4/6.02 x 10^-27 and it might be changed with 6.64*10^-27kg/mol
New Reply
Thread Tools
Similar Threads for: root mean square speed of helium atom
Thread Forum Replies
Helium Gas: Pressure, root-mean-square velocity, and more Advanced Physics Homework 6
root mean square speed and ideal gases Introductory Physics Homework 2
Root Mean Square Speed... HELP!!!! Introductory Physics Homework 2
prove that of sum square root of 2 and square root of 3 is not rational Calculus & Beyond Homework 15
help with root mean square speed Biology, Chemistry & Other Homework 3
