Drawing a PV Diagram: Solving Homework w/ Work Calculation
In summary, the gas does work to expand and contract isothermally, but the work done is not consistent throughout the entire cycle.
imatreyu
82
One mole of an ideal gas at an inital tempreature of 300K and pressure of 4 atm is carried through the following reversible cycle:
a) It expands isothermally until its volume is doubled.
b) It is compressed to its original volume at constant pressure.
c) It is compressed isothermally to a pressure of 4 atm.
d) It expands at constant pressure to its original volume
Make a plot of this cycle process on a PV diagram and calculate the work done by the gas per cycle.
Okay so step a. means that while Vo goes to 2Vo the pressure doubles as well, yes? And step b means that the pressure is the same but the volume goes to Vo. And so then step C should mean that since P is returning to its initial, the gas returns to Vo too, right? But if that's true, then D doesn't make sense since it has already returned to Vo.
Please help! Once I get the diagram correct, I'm just going to use the area to find the work done.
Take a look at the PV = nRT equation. If T is held constant (isothermal), how must P and V relate to each other?
Again, take a look at PV = nRT. What's the current volume and pressure when step C begins? How do P and V vary when the compression (or expansion) is isothermal?
Oh okay haha. . .P has to be half. . .
Thank you :)
1. What is a PV diagram?
A PV diagram, also known as a pressure-volume diagram, is a graph that shows the relationship between pressure and volume for a gas or fluid. It is often used in thermodynamics to analyze the work done by a gas or fluid in a system.
2. How do you draw a PV diagram?
To draw a PV diagram, you will need to collect data on the pressure and volume of the gas or fluid in your system. Then, plot the data points on a graph with pressure on the y-axis and volume on the x-axis. Finally, connect the data points with a smooth curve to create the PV diagram.
3. What is the purpose of solving homework with work calculation using a PV diagram?
Using a PV diagram to solve homework problems involving work calculation allows you to visually understand the changes in pressure and volume of a gas or fluid in a system. It also helps you accurately calculate the work done by the gas or fluid.
4. What are the key components of a PV diagram?
The key components of a PV diagram include the axes (with pressure on the y-axis and volume on the x-axis), data points, and a curve representing the relationship between pressure and volume. It may also include labels and units for the axes and data points.
5. What are some common mistakes when drawing a PV diagram?
Some common mistakes when drawing a PV diagram include not plotting the data points accurately, not using the correct scale for the axes, and not connecting the data points with a smooth curve. It is also important to check that the units for pressure and volume match and to label the axes and data points correctly.
