Help with a dam problem and pressure
  • Thread starter Thread starter rishid
    Pressure
The discussion revolves around a problem related to the forces acting on a dam, specifically focusing on the pressure exerted by water and the factors of safety against sliding and rotation. The subject area includes fluid mechanics and statics.
  • Participants explore how to calculate the horizontal force on the dam due to water pressure, noting that pressure varies with depth. There are questions about the role of air pressure and its interaction with water pressure.
The discussion is ongoing, with participants sharing insights about the relationship between water pressure and atmospheric pressure. Some guidance has been provided regarding the calculation of pressure and its implications for the forces acting on the dam.
There is mention of the need to consider the varying pressure with depth and the influence of atmospheric pressure on the calculations. The problem context includes specific parameters such as the density of the dam material and the coefficient of friction, which may not be fully detailed in the discussion.
rishid
Figure 15-34 shows a dam and part of the freshwater reservoir backed up behind it. The dam is made of concrete of density 3.38 g/cm3 and has the dimensions shown on the figure.
http://www.webassign.net/hrw/15_34.gif
(a) The force exerted by the water pushes horizontally on the dam face, and this is resisted by the force of static friction between the dam and the bedrock foundation on which it rests. The coefficient of friction is 0.42. Calculate the factor of safety against sliding, that is, the ratio of the maximum possible friction force to the force exerted by the water.
(b) The water also tries to rotate the dam about a line running along the base of the dam through point A; see Problem 23. The torque resulting from the weight of the dam acts in the opposite sense. Calculate the factor of safety against rotation, that is, the ratio of the torque owing to the weight of the dam to the torque exerted by the water.
Anyone have any idea how to do that? Do you think pressure of air
The horizontal force acting on the dam is the integral of the water pressure over the area of the dam in contact with the water. Be sure to account for the fact that the pressure varies with the depth of the water.
Think I would need to use air pressure of the water?
I'm not sure what that means. If you calculate the pressure of the water properly then you know that the water pressure at the water's surface will match that of the atmosphere. Also, air pressure opposes the pressure of the water on the opposite side of the dam.
water pressure varies linearly with depth
pressure head of water at a given depth = (water density) x (gravity) x (height of water column)
As Tide said, atmospheric pressure on the water is canceled out by the atmospheric pressure around the dam.
16K
  • · Replies 18 ·
25K
  • · Replies 29 ·
14K
  • · Replies 17 ·
