Calculating Angular Momentum of Disc with Mass Falling 6cm from Center
The discussion focuses on calculating the angular momentum of a solid disc with a diameter of 30 cm and a mass of 700 grams, initially rotating at 45 rpm, after a 350-gram mass falls 6 cm from its center. The conservation of angular momentum principle is applied, leading to the calculation of the initial angular momentum as L=0.0376 kgm²/s and the final angular momentum as L=0.0381 kgm²/s. The final angular velocity of the disc after the mass falls is determined to be 1.01 rad/s, equivalent to 9.64 rpm.
  • Understanding of angular momentum and its conservation
  • Knowledge of moment of inertia calculations
  • Familiarity with angular velocity and linear velocity concepts
  • Basic proficiency in physics equations involving rotational motion
  • Study the conservation of angular momentum in closed systems
  • Learn about moment of inertia for various shapes, including discs
  • Explore the relationship between linear and angular velocity
  • Investigate the effects of external torques on rotational motion
Physics students, mechanical engineers, and anyone interested in understanding rotational dynamics and angular momentum calculations.
In a "moment"um
If I have a solid disc with a diameter of 30 cm and a mass of 700 grams with a speed of 45 rpm, and a mass of 350 grams falls 6 cm from center what is the speed of the disc. There are also no external torques.
I have no problem solving the angular momentum of the disc before the mass falls on it.
L=Iబ which is L=1/2(.7 *.15^2)*4.9
L=3.85*10^-2
From there I do not know how to incorporate the 350 grams or the 6 cm into the problem.
Never mind I found out what I was doing wrong.
Instead of: L initial = L final I used the: I initial + I gum=I final
I then did: బ initial * I initial + బ gum*I gum=బ final*I final
Since బ gum had no angular speed I ended up with:
బ initial * I initial =బ final * I final
and since I figured up I final I was able to divide it out and get బ final by itself.
బ initial * I initial/I final=బ final
and arrived at the answer. :smile:
To incorporate the 350 grams and 6 cm into the problem, we can use the conservation of angular momentum principle. This principle states that the total angular momentum of a system remains constant, unless acted upon by an external torque. Since there are no external torques acting on the disc, the total angular momentum before and after the mass falls will be the same.
Before the mass falls, the angular momentum of the disc is given by L=1/2(Iω), where I is the moment of inertia and ω is the angular velocity. Using the given values, we can calculate the initial angular momentum as L=1/2(0.7*0.15^2)*(45/60*2π)= 0.0376 kgm^2/s.
After the mass falls, the angular momentum of the disc and the mass combined can be calculated as L=1/2(Iω)+(mvr), where m is the mass of the falling object, v is its linear velocity, and r is the distance from the center of the disc. We can assume that the disc and the mass are rotating at the same angular velocity, ω, after the mass falls. We can also assume that the linear velocity of the mass, v, is equal to the linear velocity of the disc at the point of contact, since there are no external forces acting on the system.
Substituting the values given in the problem, we get L=1/2(0.7*0.15^2)*(45/60*2π)+ (0.35*0.06*45/60)= 0.0381 kgm^2/s.
Finally, we can equate the initial and final angular momenta and solve for ω, which will give us the angular velocity of the disc after the mass falls:
0.0376= 0.0381
ω= 0.0381/0.0376= 1.01 rad/s.
Therefore, the speed of the disc after the mass falls is 1.01 rad/s or 9.64 rpm, assuming the disc was initially rotating at 45 rpm.
  • · Replies 17 ·
18K
  • · Replies 25 ·
