Heat loss through an insulated pipe
by yoghurt54
Tags: cylinder, cylindrical, heat equation, thermal conductivity
yoghurt54
yoghurt54 is offline
#1
Jan11-11, 11:58 AM
P: 19
A pipe of radius R is maintained at temperature T. It is covered in insulation and the insulated pipe has radius r. Assume all surfaces lose heat through Newton's law of cooling
[tex] \vec{J} = \vec{h} \Delta T[/tex], where the magnitude h is assumed to be constant.
Show that the heat loss per length of pipe is inversely proportional to
[tex] \frac{1}{hr} + \frac{1}{k} ln(\frac{r}{R}) [/tex]
2. Relevant equations
I guess that
[tex]\vec{J} = -\kappa \nabla T[/tex]
is useful, as is the thermal diffusion equation:
[tex] \nabla^{2} T = - \frac{C}{\kappa} \frac{\partial T}{\partial t} [/tex]
3. The attempt at a solution
I'm guessing that this is the steady state, and that because there's no azimuthal or translational variance in temperature, then we can find T(r') to be:
[tex]T'(r') = T - constant \times ln(\frac{r'}{R})[/tex]
If we define the length of the pipe to be L and the rate of heat loss to be
[tex]\stackrel{.}{Q} = 2\pi r L J [/tex]
but I have no idea where to proceed from here.
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
Register to reply
Related Discussions
Heat loss through PEX pipe Classical Physics 7
Help needed with heat loss calculation from a steam pipe...please! Classical Physics 0
Heat loss of a steel steam pipe Classical Physics 4
Heat loss from an insulated water tank ----- Thermodynamics Classical Physics 4
Heat Loss in a Hot Water Pipe System Engineering Systems & Design 35
