Calculating String Tension in a Simple Situation
  • Context: High School
  • Thread starter Thread starter georgeo
    String Tension
The discussion revolves around calculating string tension in various scenarios involving blocks connected by strings on frictionless surfaces. Participants explore conceptual understanding and mathematical approaches to determine tension in both static and dynamic systems.
  • Homework-related
  • One participant describes a scenario with two blocks connected by a massless string and a force applied to one block, seeking to understand how to calculate tension.
  • Another participant suggests visualizing the situation with a Free Body Diagram and applying Newton's 1st Law to analyze the forces.
  • A different example is presented involving a mass hanging from a string over a pulley, prompting questions about how to calculate tension when the system accelerates.
  • One participant explains that tension is uniform throughout a massless string and proposes writing equations for the forces acting on each block to solve for tension and acceleration simultaneously.
  • Another participant shares a similar problem involving a block on a table and a hanging block, expressing difficulty with the formulas and requesting simpler explanations.
  • A later reply emphasizes that a massless string cannot support net forces along its length and discusses how to apply F=ma to the masses involved while maintaining the same tension throughout the string.
Participants generally agree on the principles of tension in massless strings and the application of Newton's laws, but there are varying levels of understanding and different scenarios presented, leading to multiple approaches without a consensus on a single method for all cases.
Some participants express uncertainty about the application of formulas and the conditions under which they hold, indicating a need for clarification on specific scenarios and assumptions related to tension calculations.
This discussion may be useful for students learning about mechanics, particularly those struggling with concepts of tension in strings and the application of Newton's laws in various physical scenarios.
georgeo
I have a hard time conceptualizing string tension, and hence calculating it.
For a hypothetical situation, there is a massless string connecting two blocks on a flat, frictionless surface. Block A is 5 kg, block B is 3 kg. There is a string attached to the outside of Block A, and a force of 150 N is applied to this string.(so the outside string pulls block A, which pulls the middle string, which pulls Block B)
This is not a homework problem that i know of at all, I just need to conceptualize and calculate tension in a simple situation, and then I should be able to apply to other situations too.
Thank you everyone!
Well imagine a string tied someplace, when you pull it you exert a force to the object where the string is tied, and at the same time the string exerts a force on you.
Yeah, I get that part.
So i guess the question is, how do I calculate the tension?
Draw a Free Body Diagram
I suppose the system is at rest (V = 0)
Use Newton's 1st Law
[tex]\sum_{i=1}^{n} \vec{F}_{i} = 0 \rightarrow \vec{V} = constant[/tex]
Lets say there is a massless string hanging from the ceiling and on the end is a 1kg mass. The tension would be 9.8 N, right?
What if the string goes over a pulley, and on the other side is a 2 kg mass? The system would accelerate. What would the tension of the string be?
The tension in the string will be the same throughout it. So looking at each of the 2 blocks, write down the forces on each block (weight = mg downwards; T upwards). The net force causes an acceleration a, given by Newton's Third Law. Writing this equation for the 2 blocks, you have 2 equations, in 2 unknowns, T and a. Solve simultaneously to find them.
ahhh...
i think that's what i need...
i'll let you know how my test today goes :)
(that was just the way of saying it that made it click in my head)
I got an A on my test. Thank you all!
Excellent! Congragulations! :smile:
I have a similar problem. There is a 60 kg block on a frictionless table. At the corner of the table there is a pulley. A string is attached to the block and runs over the pulley, where it is attached to a 25 kg block that hangs off the table. It looks something like this:
````____
___|_60_|-------------O
###############| _|_
###############||25|
I am supposed to calculate the tension on the string and the acceleration of the 25 kg block, but the formulas I have tried don't work. Can anyone help?
PS Please keep the formulas simple. I'm not good at physics, and this is my first class.
The key point is that a massless string cannot support any net forces along its length-- it would have to have infinite acceleration! So the rule about such a string is that the whole stretched string has the same velocity and acceleration at all times, and whatever force pulling one way on one end equals the force pulling the other way on the other end. Once you've put that into your calculation, you are done with the string, and you need to concentrate on the masses. You apply F=ma to the masses, given those rules about the string. Often, as above, this will mean asserting the force at both ends of the string is the tension "T", but not knowing what T is. That's fine, since you write F=ma for each mass, all you need is that T is the same in both equations, and you can do the problem. You are looking for the same T and the same a involved in the F=ma for both masses, and so you can solve for both of them simultaneously-- only one combination of T and a will satisfy F=ma for both masses (where F is all the forces on the masses-- the T and the gravity and anything else too). In your problem, it helps to concentrate on the F=ma "along the string direction", and ignore what is happening in other directions. Do you know that the T exerted on the masses at both ends of a string must point in toward the middle of the string? (Strings only pull, they don't push.)
  • · Replies 19 ·
16K
  • · Replies 37 ·
