What is the trajectory of a cannonball fired from the equator in space?
The trajectory of a cannonball fired from the equator in space, when observed from an inertial frame, is influenced by the frame of reference. If the Earth is considered an inertial frame, the trajectory appears as a straight line. Conversely, if the Earth's rotation is accounted for, the trajectory resembles a spiral. In both scenarios, the absence of Coriolis force in the inertial frame is confirmed. If the cannonball is not fired at escape velocity, it will follow an elliptical orbit, intersecting the Earth's surface at a later point.
  • Understanding of inertial and non-inertial frames of reference
  • Familiarity with gravitational forces and their effects on projectiles
  • Knowledge of the two-body problem in orbital mechanics
  • Basic principles of projectile motion
  • Research the two-body problem in orbital mechanics
  • Study the effects of gravitational forces on projectile trajectories
  • Learn about inertial vs. non-inertial frames of reference
  • Explore the concept of escape velocity and its implications
Physics students, aerospace engineers, and anyone interested in understanding projectile motion and orbital mechanics.
FermatPell
Imagine that you are an observer in space (so you are in an inertial system), when the cannon (located on the equator) fires a cannonball in north direction. What does the trajectory of the cannonball look like from your perspective? Is it a straight line (that would mean that the cannonball is not affected by Earth's rotation) or something like a spiral?
I think that, since the only real force acting on the body is the gravitational force, the trajectory is like a spiral. I also know that no Coriolis force exists in my inertial frame of reference. Am I right?
The question is not so clear for me. This is what I think-
If you consider the Earth to be an inertial frame of reference, then the trajectory of the ball would be a straight line.
If you consider the Earth to be a non-inertial frame of reference (take its rotation in account), then the trajectory of the ball would be similar to a spiral.
In both the above cases, you are in an inertial frame of reference, so there will not be any Coriolis force.
If you don't shoot the cannonball faster than escape velocity, the orbit will be an ellipse. Look up two-body problem. Of course the ellipse will intersect the surface of the Earth again at some point.
  • · Replies 18 ·
