What is SPEED OF LIGHT With Respect to an Observer?
The discussion revolves around the concept of the speed of light with respect to an observer, exploring its implications within the framework of special relativity. Participants examine various scenarios involving light travel, observer perception, and the effects of medium on light speed.
  • Some participants question the interpretation of the speed of light as it relates to an observer's perspective, particularly in scenarios involving distances and timing.
  • One participant suggests that if an observer does not know the distance to the light source, their interpretation of the light's arrival time may be flawed.
  • Another participant argues that the speed of light should not appear to decelerate to an observer, raising concerns about how light behaves in a medium with colloidal particles.
  • There is a discussion about the necessity of accounting for light travel time when making observations, with some asserting that this is crucial for accurate interpretation.
  • Participants explore the idea of synchronized observers at various points, suggesting that local measurements could simplify the understanding of light travel times.
  • One participant proposes a scenario where light appears to decelerate due to interactions with colloidal particles, questioning how this aligns with the principle that light travels at a constant speed in a vacuum.
  • Another participant challenges the clarity of the experimental setup described, seeking clarification on the positions of the torch and observers involved.
Participants express differing views on the interpretation of light speed and its perception by observers. There is no consensus on whether light can appear to decelerate or how to reconcile this with established principles of relativity.
Some discussions involve potential misunderstandings regarding distances and the setup of experiments, which may affect the clarity of the arguments presented. The role of medium in light propagation and the implications for observer measurements remain unresolved.
nipiano93
Can anyone please tell me what does SPEED OF LIGHT WITH RESPECT TO AN OBSERVER mean?
Some explain it like this: If there are two poles 10km apart, in front of an observer and he sees a ray of light passing past them, then he would see that the light would cross the poles in time 10/c. Is it correct? Coz I doubt it.
Why do you doubt it?
So, is it the right definition?
Well, then are the concepts of special relativity mastered well by you?
That would be an example of what the speed of light with respect to some frame of reference would predict.
Why don't you just ask your question and find out?
A torch is kept at a point P. Observer is at P. The torch is switched on at Q. As you say, the speed he should detect is 10/c as the light travels from Q to R.
But now, let's investigate it more closely. As the torch is switched on, the wavefront from Q takes 10/c seconds to travel from Q to P. So after the torch has been switched on, then after 10/c seconds he detects that it has been switched on. Then, as light reaches R, the observer at P realizes that it has reached R 100/c seconds after it actually reaches R. So, definitely, he hasn't been able to detect the correct speed and infact, to him it has appeared as if the light has decelerated.
That's the question.
Several problems here:
(1) Where do you get 100 km? Your diagram looks like a right triangle to me, with sides equal to 10 km. So the hypotenuse would be about 14.1 km, not 100 km.
(2) Any observer must take into account the travel time for the light to reach him. Only after taking that into consideration will he be able to intelligently interpret his observations. Once he does he'll agree that the light took 10km/c to reach both P and R.
lol! Sorry, actually I had different sides earlier and then after changing the sides, I forgot to change to hypotenuse and wrote the whole problem accordingly.
Anyways, what do you mean by "taking into consideration". What if the observer doesn't know the distance PQ?
If he doesn't know the distance to the source of the light, then he has no basis for interpreting his observations. All he can say is that the light reaches him at some time.
One way to view things is to imagine that there are observers stationed at all locations (including P, Q, and R) with their own synchronized clocks. Then there's no need to worry about light travel time, since all observations will be local. In other words: Observer Q will report that he sent the light beam at time T1; Observers P and R will report that they received the light at times T2 and T3. (T2 will equal T3, since they are the same distance from Q.)
Well, there is really no problem with that set up of yours.
But what I want to know is that when we say that light travels at a constant speed with respect to every observer, doesn't it mean that the light should not appear to be decelerating to the observer in my case?
For instance, assume that the room in which this experiment is being carried out filled with colloidal particles. Then wouldn't the observer see the light's path as a decelerating beam?
What matters is what you measure, not what 'appears'. You must take into consideration the light travel time when interpreting your raw observations.
It's only the speed of light in a vacuum that is the same for all observers.
Well, sir, in relativity, the thing that matters is 'what appears'. If an observer starts calculating everything, he will overcome effects such as time dilation (which occurs at high speeds).
And I know that the speed of light in VACCUM is same for all observers. But the colloidal particles can be suspended in the vacuum without any problem. Then the observer would see the path of light which would appear to be decelerating. Now this is the real problem. How do we explain the fact that he would see a decelerating beam?
No, just the opposite. Relativistic effects such as time dilation are measured after taking into account light travel times.
This has nothing to do with your earlier example. It's simply due to the light NOT traveling in a vacuum. You'll get the same effect by shining light through a piece of glass. So?
Actually, it has a lot to do with my example. In my earlier example on the line QR, assume there are more equidistant points A, B, C in between Q & R. Then although the light is traveling in vaccum, when the light hits the colloidal particle at A, a wavefront from A reaches P in time T1. When the light hits the particle at B, the wavefront reaches the observer in time T2. Same with T3. As you can see, PA, PB PC are hypotenuses of different triangles. And so T3>T2>T1. That's why I'm saying it appears to be decelerating.
Aside from the error on the distance PR, I cannot understand your experiment. First you say the torch is at P. Then you say the torch is switched on at Q. And then you say the light travels from Q to R. Did you mean that the torch is at Q and not at P? Is the idea that there is a wire going from P to Q and that the observer at P turns on a switch which causes the torch to come on at Q or did you just mean it comes on some time all by itself. Is there just one observer at P. What is at R?
I really don't see your point. All observers will measure the time it takes for light to travel (in vacuum) from one point to another to be D/c, where D is the distance between the points. The fact that things may 'appear' to decelerate when you ignore light travel time is irrelevant.
I think that's what he meant.
A little more detail on "speed with respect to an observer".
Suppose you are standing on the side of a road and a person throws a ball to you at, say 30 mph. It's speed "with respect" to you (or "relative to you") would be 30 mph.
Now, suppose another person, driving down the road toward the thrower, at 20 mph, were to reach out an catch the ball. The speed of the ball "with respect to" this person (and how hard it would hit his hand) would be (by classical mechanics) 30+ 20= 50 mph.
Finally, suppose that instead of throwing a ball the first person shines a light toward you. Its speed "with respect to you" is "c" mph. Classical mechanics would say that the speed of that light, "with respect to a person driving toward it at 20 mph" would be c+ 20 mph. But experimental evidence shows that that is not true. The speed of light coming toward a person, no matter how fast he was moving relative to you would still be exactly "c". That is why "relativity" was needed to replace classical mechanics for objects moving at very high relative speeds.
(Relativity would say that the ball thrown at 30 mph would hit the car, coming toward it at 20 mph, at slightly less than 50 mph but at those low speeds the difference would be too small to be measurable.)
Here's an example. Let's say I take a laser pointer and shine it toward a stationary observer, observer A, 10 KM distant. Observer A measures how long it takes a small portion of the photons to travel through a 1 meter tube. He will find that they travel at c.
Now, let's say that we have another observer, observer B, traveling at 50% c directly away from observer A and myself so that my laser will pass by him at a distance of say one foot. That observer measures the speed of some of those photons in my laser as it passes by him as well. Observer B measures the speed as ALSO being c. So observer A and observer B both measure the laser as moving at the same speed even though they are both moving at completely different velocities in relation to the laser. The difference here is that Observer B measures the FREQUENCY of those photons as being LESS than observer A. The light from my laser with be shifted toward the red side of the spectrum. The light will be redder to him than it was to observer A.
Sorry. Actually, this all error was because of editing the original diagram.
I'm now explaining to you , the whole experiment from scratch.
There is a room with suspended colloidal particles. There is no air. There are three points P, Q, R. They form a right triangle right angled at Q. The torch is at Q. The observer is at P.
Now, the torch at Q is switched on by the observer at P through a remote. The torch gets switched on and the light starts traveling towards R. As expected, it will hit the colloidal particles in its way and enlighten its path. Let us take three points on QR - A, B & C such that QA=AB=BC=CR. As the light hits the particle at A, a wavefront will be generated at A which will travel to P in time T1. The observer at P will begin to see the path just as the wavefront from A reaches him. Now, as the main beam of light travels from A to B , it will strike B and a similar wavefront would be generated that will reach P in time T2. Same with C.
As it can be clearly seen (by geometry). T1<T2<T3. So, as the light travels farther and farther, the new path enlightened by the beam will be visible after more and more time and thus the beam would appear to be decelerating.
Note that the observer at P doesn't know the distance PQ. So, he is unable to do any calculations to explain the situation.
What the observer at P sees is a series of reflections from the particles at A, B, and C. The time between his receipt of each reflection increases. This is exactly what one would expect to see at P if a light beam travel from Q to R, hitting equally spaced particles along the way.
Why not? He's perfectly capable of using exactly the reasoning you used above. He'll conclude that his observations are consistent with a light beam reflecting off of equally spaced particles. He can even use his observations to figure out where A, B, and C are.
The point is that 'raw' observations of light must be interpreted by taking account of the time it takes for the light to reach the observer. (Just as you did in your analysis above.) No one would ever conclude that he observed a beam of light 'slowing down' based on the observations discussed here.
Based on your original post and your corrected example, are you suggesting that Special Relativity is claiming that any observer will measure the speed of light as a constant even when they don't know the distances involved? Don't you think that is expecting a bit much?
It turns out that every legitimate experiment that has ever been performed to measure the speed of light gets the same value, so much so, that scientists have assigned an exact value to the speed of light which is called "c" and has a value of 299792458 meters per second. This, of course, has nothing to do with Special Relativity, it's just a statement about what we have observed about nature in the past and what we assume we will always observe about nature in the future.
But I suspect that this answer is not really what you are asking about but you will need to rephrase your question if that is the case.
Just to elaborate on what a legitimate experiment would be in your case, you need to set up a round-trip path for the light to take over previously measured distances and using a single timer located at the same position as the light source to start the timer when the flash occurs and then to stop the timer when the final reflection gets back to the source. So you really should modify your example and put the light source back at P with the observer and then put a mirror at Q so that it reflects the light at a right angle in the direction of R which needs to be another mirror to deflect the light back to P. The other three points between Q and R need also to be three mirrors angled to deflect the light back to P.
Then when you do your experiment, you would either need to repeat it four times so that you could measure the time for each round trip path individually, or you could have four separate timers, each one stopping on a returned reflection from a different mirror, or you could use a timer that can record the time for four separate events.
After you collect all your data and calculate the speed of light for each of the four separate paths, taking into account the total distance for each one, you will get four identical measurements for the speed of light.
Does that make sense to you?
  • · Replies 24 ·
  • · Replies 33 ·
  • · Replies 93 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 34 ·
  • · Replies 25 ·
