Nonlinear first order differential equation
The discussion revolves around solving a nonlinear first-order differential equation of the form dx/dt + Rx^2 + G = 0, where G and R are constants. The original poster provides initial conditions and expresses challenges in applying certain methods to find a solution.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply Bernoulli's equation and Laplace transformations but encounters difficulties due to the structure of the equation and the presence of constants. Some participants suggest that the equation is separable and propose rewriting it for integration.
Participants are exploring different methods to approach the problem, with some suggesting a separable form for integration. The original poster acknowledges the suggestions but expresses a sense of frustration regarding their initial attempts.
The original poster mentions specific constants and initial conditions, which may influence the approach taken. There is also an indication of uncertainty regarding the application of certain mathematical techniques.
dreamwere
Solve the diferential equation: dx/dt + Rx^2 + G = 0
G constant = 10^18
R constant = 10^-10
Initial conditions x(0) = 10^8
what approach to take?
First I try to apply bernoulli, but since in this equation I do not have a term x and since also the constat G is different to cero, it was not possible.
Secondly I try to solve in the frequency domain, and using laplace transformation I obtain:
Xs = 2R/s^2 + sx(0) + G
But then, things get complicate trying to convert to time domain for the second and first term becouse the first one implies a delta function in t = 0 and the second one implies a derivations of the inverse transfor of x(0), that is again an impulse sus the derivative of the impulse.
Thank you in advance for taking your time to help me.
That equation is separable.
As vela said, the equation separable:
Write it as
[tex]\frac{dx}{Rx^2+ G}= dt[/tex]
and integrate both sides.
It might help to factor the "G" out leaving
[tex]\frac{1}{G}\frac{dx}{\frac{R}{G}x^2+ 1}= dt[/tex]
and recognize the integral as an "arctangent".
Thank you done.
Sory for wasting your time, I should try harder before asking.
  • · Replies 27 ·
