Angular acceleration question with spring and damper
The discussion revolves around calculating the angular acceleration of a sunglass bin in a car, which is influenced by a torsional spring, gravity, and a rotary damper. Participants explore the dynamics of the system, including the application of torque and the effects of various forces on the motion of the bin.
  • Homework-related
  • One participant outlines the need to calculate angular acceleration considering the torques from the spring, damper, and mass.
  • Another participant suggests that the problem can be approached by summing the torques and dividing by the moment of inertia.
  • Concerns are raised about the correctness of the equations for torque, particularly regarding the damper's torque being constant.
  • There is a discussion about whether conservation of energy can be applied, with one participant noting complications due to friction.
  • Participants discuss the challenges of generating equations of motion and the potential need for differential equations to model the system accurately.
  • One participant expresses uncertainty about the relationship between torque and time, questioning the use of conservation of energy in this context.
  • Another participant corrects a previous statement about the relationship between torque and angular position, indicating it should involve the second derivative.
Participants do not reach a consensus on the correct approach to solving the problem. There are multiple competing views on the application of torque equations, the use of conservation of energy, and the modeling of the system with differential equations.
Participants express uncertainty regarding the assumptions made in their equations and the potential effects of friction on energy conservation. The discussion reflects a variety of approaches and interpretations of the problem without resolving these complexities.
ddd61
Hello everyone!
I need to solve the angular acceleration on a sunglass bin on an over head console of a car.
The sunglass bin rotates open.
It has a torsional spring and gravity that forces it to open and a small rotary damper that slows it down. There is a gear on the sunglass bin and on the over head bin there is rotary damper which is a gear (with a Torque of .18 N*cm at 25 RPM) and reduces the speed of the sunglass bin as it opens.
I would greatly appreciate if anyone could assist me in solving this problem.
Thank you!
This seems like a rather straightforward problem. You should just be able to add up the torques, and divide by the moment of inertia.
Thanks for the quick reply.
Torque for torsional spring = k*(change in angular position)
Torque for torsional damper = b*(change in angular velocity)
Torque for mass = Weight*radius
Does this look right?
How would you solve for the angular velocity?
Also, doesn't the angular acceleration change with time? So wouldn't the net torque / moment of inertia equation not work?
Correct me if I'm wrong.
Thank you for your assistance!
Well, now you're changing your mind about what you want to know. I don't think you have all of the equations just right, but I don't have the same problem in front of me.
The instantaneous net torque should still follow the described equation.
Which equations do not look right to you?
Thanks for your continuous help!
The torque for the damper should probably be constant.
Once again, thank you for your continuous help!
One more thing, what if you want to solve for time.
Would you use Conservation of energy? And add in the damper and spring forces?
Thanks again!
Conservation of energy gets tricky if friction is involved. Unless you want to account for heat, conservation of energy isn't going to work well for you. If you really want to use conservation of energy, you could account for the work done by the damper separately.
What do you suggest to use to solve for time?
Thanks for your contiuous help.
Generating equations of motion for things like this can be quite tricky. You could certainly try using energy, but you'll end up with the same position dependence -> time dependence problem that involves differential equations.
Perhaps there is some larger context for this?
Not really.
I was given a project in physics to model a sunglass bin opening.
I took Differential equations so I should be able to do this...I think.
How would you suggest to model this with ODE?
Thanks!
Well, it should be easy to calculate the net torque as a function of position, and go from there.
i.e.
[tex]\frac{dp}{dt}=\frac{\tau_{net}(p)}{I}[/tex]
i.e.
Shouldn't that be the second derivative?
Yeah. My bad. I need to get more sleep, or more cafeine.
Well, thank you for your contiuous help!
  • · Replies 95 ·
  • · Replies 121 ·
12K
