Does Time Dilation Apply to Objects Moving at Sub-Light Speeds?
The discussion centers on the concept of time dilation, particularly in the context of objects moving at sub-light speeds. Participants explore the mechanics of time dilation through various thought experiments, including the use of light clocks and hypothetical "rubber ball clocks." The conversation delves into the implications of special relativity (SR) and the relativistic velocity addition formula.
  • One participant describes a light clock as a useful tool for visualizing time dilation, noting that light's constant speed allows for straightforward analysis.
  • Another participant questions whether a "rubber ball clock" could serve a similar purpose, suggesting it would complicate the analysis due to the need for the relativistic velocity addition formula.
  • Some participants propose that time dilation can be understood as one observer seeing an object (like a ball) moving a greater distance than another observer, leading to differing perceptions of time.
  • There is mention of the Lorentz transformations and how they account for time dilation and velocity addition, emphasizing that light behaves differently than massive objects.
  • One participant expresses a preference for visualizing time dilation using a ball rather than a light clock, indicating a struggle with the abstract nature of light's constant speed.
  • Another participant discusses the implications of light's constancy on the perception of events in moving frames, using an example of lighting in a room to illustrate potential paradoxes if light speed were not constant.
Participants do not reach a consensus on the effectiveness of using a rubber ball to illustrate time dilation compared to a light clock. There are differing views on how to conceptualize time dilation and the role of the relativistic velocity addition formula, indicating ongoing debate and exploration of the topic.
Participants acknowledge the complexity of analyzing time dilation with massive objects and the necessity of using light for simpler derivations. The discussion reflects various assumptions about the nature of time and space as described by relativity, without resolving these assumptions.
Jake
I'm trying to understand the mechanics of time dilation. Mabye some of the SR/GR Gurus can help me with this one :-p
So an often used example that helps to visualize time dilation is a light click. A person moving in a vehicle WITH the light click just sees the light moving up and down, wheares someone in a rest frame relative to the vehicle sees the light moving up and down, AND forward, in a zigzag. Since light moves at a constant speed regardless of speed, the longer distance == more time thus time dilation.
But would that same example work for massive objects moving at less than C? Example, someone onboard the vehicle bounces a ball up and down, to him it just bonced up 3 feet, but to someone on land it moved 3 ft + the 10 feet the vehicle moved in that period of time. Thus, since in a given area of road, the ball moved different amounts to different frames of refrence, time was slow for the frame of refrence moving?
I'm not sure, let me know what you think :)
The reason that "light clocks" are used is that the behavior of light is easy to describe in SR: its speed is the same for all observers. So, just using the basic postulates of SR, the light clock allows you to derive the time dilation effect.
Would a "rubber ball clock" work? Sure, but it would be harder to analyze. You'd have to use the relativistic velocity addition formula to find the speed of the ball as seen from the moving frame. So the ball clock is not a useful "thought experiment" for deriving SR effects.
The bottom line: time dilation is exhibited by any moving clock, but some clocks are easier to analyze than others. :smile:
The key difference in the light and the ball is from your own quote :
"Since light moves at a constant speed regardless of speed, the longer distance == more time thus time dilation."
The first part is the 2nd postulate. The ball, however, does not move at the same constant speed for both observers. So to derive the relativity relations the first time, you practically must use light. Using the relativistic velocity addition formula would work, but it would be a rather bizarre postulate. I believe it was known in Einstein's time, but rather empirically. The constancy of c, however is noticeable from Maxwell's equations, and thus makes a better postulate, allowing simple continuity from 1 theory to another.
Thanks guys for the explanation.
So am I correct in saying that time dilation is in essence the fact that one person sees the ball moving more distance than the other person?
Also what about the 'relativistic velocity addition formula' that you both spoke of. How does it factor into time dilation?
I just find visuallizing a ball much easier, because everytime I think of the light clock example, I get sidetracked into wondering about the nature of why C is the same for everyone...Heh, if you know the answer let me know :wink:
Thanks again guys!
Either you think of the light clock or you think of both the ball and the rel. addition formula. But not the ball alone.
Get used to the fact that light is the same for everyone. If it wasn't, then even more bizarre things would happen.
Such as a room being gradually lit from one side of the room to another when you turn on a single light bulb in the middle of the room on a moving earth. And the direction of the flow would depend on whether it is day or night... and summer or winter, or ... then again the sun itself is moving around the galaxy... and the galaxy itself moves... so ...in effect, you'd get some freaky gradual lighting that would depend on what time of day it is. Of course, nothing of this happens, a room lit by a single bulb in the middle is indeed lit symetrically, irrespective of the room's velocity .
Aye, "one person sees the ball moving more distance than the other person", yet over the same time elapsed. So for any normal object, such as a ball, that simply means that the object's journey was made at greater velocity. But it was found that light is special and its speed would be perceived as c regardless, so the clocks and rulers had to be adjusted instead, the result being the Lorentz group of transformations. Time dilation is just one of several distortions implied. The "Addition of Velocities" formula is just another ramification from the same Lorentz transform. You are hovering motionless in deep space with two other sister crafts. One sister takes off at .75c, and the other sister does likewise but in the opposite direction. Are your two fellow crafts moving faster than light with respect to one another, such that they won't be able to SEE each other? No, because velocity .75c plus .75c equals velocity .96c according to that same Lorentz transformation formulae.
As for WHY c is constant, it works well into the scheme of things, in Nature. For example, some distant galaxies are moving away from us at relativistic speeds. What of the hypotheitical aliens that might populate all those places? Their VISIONS of their SURROUNDINGS would be all awry if light instead moved at fixed speed relative to some cosmic background space/grid, a grid with respect to which Earth would then need to be assessed as stock still (based on how we observe light behaving here).
Satisfied?
  • · Replies 47 ·
  • · Replies 65 ·
14K
  • · Replies 32 ·
  • · Replies 63 ·
  • · Replies 21 ·
  • · Replies 51 ·
  • · Replies 35 ·
