Electron Force and Electric Field
The problem involves three conducting spheres arranged in an equilateral triangle, each with specific initial charges. The task is to analyze the electrostatic forces between the spheres before and after they are connected and grounded in various configurations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the charge transfer process when the spheres are connected and grounded, questioning how the charges redistribute among the spheres. They explore the calculations for the electrostatic forces based on these new charge distributions.
Some participants have provided insights into the charge redistribution process and have attempted calculations for the forces between the spheres. There is an ongoing exploration of the results, but no explicit consensus has been reached regarding the correctness of the final answers.
The discussion includes assumptions about charge conservation and the effects of grounding on the charges of the spheres. There is also a mention of specific homework rules regarding the presentation of solutions.
Paul2011
A) Three conducting spheres, a, B , and c, form
an equilateral triangle of side length "l" and have
initial charges of -2q, -4q, and 8q, respectively.
Show that the magnitude of the electrostatic force
between spheres a and c is given by
F_ac= (4q^2)/(π€_o l^2 )
B) The following steps are then taken: a and b are
connected by a thin wire and then disconnected;
b is grounded by the wire and the wire is then
removed; b and c are connected by the wire and
then disconnected. Show that the magnitudes of
the electrostatic forces between spheres a and c
and between spheres b and c, respectively, are
given by
F_ac=(3q^2)/(π€_o l^2 )
F_bc=(4q^2)/(π€_o l^2 )
I think I got part A right, but part B i seem to be stuck unfortunately.
Any help would be appreciated, thanks.
A)
F_ac=(-2q)(8q)/(4π€_o l^2)
F_ac=(4q^2)/(π€_o l^2)
So, in part B, what I'm assuming is happening is that as the spheres are being connected and disconnected, charge is being transferred so that the charge of both of the spheres that are connected are the same. So as A and B are connected, their charges both become -3q. As B is grounded, it loses all its charge, but then is connected to C, which evens out so that B and C have a charge of 4q. The end result is that the charge on A is -3q, the charge on B is 4q and the charge on C is 4q.
Now do what you did last problem for the force and you'll have your answers!
Ok, so this is what I've done based on your insight (thanks btw).
(a+b)/2 = (-2q-4q)/2 = -3q
a=-3q , b=-3q, c=8q
a=-3q, b=0q, c=8q
(c+b)/2 = (8q+0q)/2 = 4q
a=-3q , b=4q, c=4q
F_ac = (-3q)(4q)/4π€_o l^2
F_ac = 3q^2/π€_o l^2
F_bc = (4q)(4q)/4π€_o l^2
F_bc = 4q^2/π€_o l^2
looks right to me, thanks again. I hope its right at least..
Yep, you got it. No problem.
