Electron Force and Electric Field
The problem involves a thin rod along the x-axis with a specified linear charge density. The objective is to determine the electric field at the origin due to this charge distribution.
  • Participants discuss visualizing the rod as a series of thin disks and consider how to calculate the electric field produced by these disks. There are questions about the application of relevant equations and how to incorporate the given charge density into the calculations.
Some participants have offered guidance on breaking down the problem into smaller steps, such as calculating the charge in a differential section of the rod and finding the electric field contribution from that section. There is an acknowledgment of confusion regarding the integration process and the application of the point charge formula.
Participants express uncertainty about the role of the charge density equation and how to effectively apply it within the context of the problem. There is a mention of a mental block affecting the original poster's ability to start the problem.
Paul2011
A thin rod runs along the x-axis from the origin to
x = l. Its linear charge density (C/m) is given by
λ = λ_0(x/l)^2 sin (x/lπ), where λ_0 is a constant.
Show that at the origin,
E(0)=〖-λ〗_0/(2π²€_0l)
Sorry I couldn't provide any start to this problem, kind of hit a mental block. A jump start would be much appreciated.
What law applies?
Think of the rod as a series of thin disks of thickness dx. Calculate the electric field of that disk as a function of x along the entire length of the rod.
AM
are you familiar with calculus physics?
Ok, after reading what you have had to say I am a little embarrassed to say that I am not grasping the whole thing. I under stand that the rod can be visualized as a bunch of discs which would run from the origin to x=l, which I wrote on my coordinate plane as (l,0). the end points are from (0,0) to (l,0). So I know my bounds would run from 0 to l. And also, the thickness of the disc is dx. What I'm trying to understand is where does the given equation,λ = λ_0(x/l)^2 sin (x/lπ) come into the picture. https://www.physicsforums.com/library.php?do=view_item&itemid=2" if I use the first equation I'm not quite sure what I would replace all the variables with.
λ is the density
suppose you are considering any dics of negligible thickness dx at distance x from origin.
how will you find the charge in that disc?
and a little hint: as rod is thin, you may take the discs to be acting like small point charges and instead of using Electric field formula of disc, use formula of point charge
If I use the point charge formula F= (kq_1q_2)/r^2 then my r would be from origin to l so total distance of l. And I would have to add them up from the origin to x=l. I am sure I'm over complicating this problem. I definitely understand the concept but somethings not clicking.
you are not over complicating it.
lets go step wise:
1. assume a section dx at distance x from origin
2. find charge in it.
3. find the electric field dE at origin due to that charge
4. Integrate it from x=0 to x=l
