How is a single photon fired in the double slit experiment?
  • Context: Graduate
  • Thread starter Thread starter AJ_2010
    Duality Particle Wave
The double slit experiment demonstrates the wave-particle duality of photons, where a single photon can create an interference pattern on a screen, indicating wave-like behavior. Key questions arise regarding the emission of single photons and their trajectory towards the slits. It is essential to understand that the experiment ensures only one photon is fired at a time, and the concept of superposition plays a crucial role in explaining the behavior of photons in this context. Misinterpretations often stem from classical physics perspectives, which do not adequately describe quantum phenomena.
  • Understanding of quantum mechanics principles, particularly wave-particle duality.
  • Familiarity with the concept of superposition in quantum physics.
  • Knowledge of photon emission techniques and single-photon sources.
  • Basic grasp of experimental physics and measurement techniques.
  • Research the principles of quantum superposition and its implications in quantum mechanics.
  • Study the methods of single-photon emission and detection technologies.
  • Explore the mathematical framework of wave functions and interference patterns.
  • Investigate the historical context and evolution of the double slit experiment in quantum physics.
Students and researchers in physics, particularly those focused on quantum mechanics, experimental physicists, and educators seeking to deepen their understanding of wave-particle duality and the double slit experiment.
AJ_2010
The basis of the well known experiment is to fire one photon at a double slit 'wall' and measure the wave pattern produced on a screen behind it.
Now as is evident, one particle is seen to act like a wave, which is a fundamental contradiction.
I have couple of fundamental questions regarding the experimental procedure.
(1) How can it be assured that only one photon is being 'fired' at the slits?
(2) If indeed one photon is being fired, then surely this photon has a given velocity aimed at one slit or the other. So if I were to draw a line from the emitter to the slit it is pointing at then this should be the slit that this single photon passes through. Is this how the experiment is set up?
The only way I can work it out in my head is if the supposed one photon emission is in fact numerous, and these are emitted at various angles that encompass the two slits.
Or am I blatantly just repeating the paradox by asking these questions?
You might want to start by first read one of the entry in the FAQ thread in the General Physics forum.
Secondly, you might want to do a search on the principle of "superposition". I think you are approaching this from a purely a classical understanding, evidenced by your notion that you actually know where your photon is being aimed at. This already forced your situation into a particular scenario.
And yes, this question has been asked numerous times on here.
Zz.
Thanks.
Read the FAQ and realize that my questions are basically non-questions.
I watched a BBC program last night about 'REALITY'.
They went on to explain about the particle/wave nature of light and the classical physics experiment about the dual slits.
The way they were explaining it was confusing. (To me at least).
In that their proof of the wave-like nature was solely down to one 'particle'/'photon' of light being able to go through both slits at the same time. But not explaining how a single photon was emitted nor explaining which slit the emitter was pointing at.
  • · Replies 36 ·
10K
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 17 ·
