New Reply
Water rocket car
Share Thread Thread Tools
Jan18-11, 02:51 PM   #1
Water rocket car
Hi, i have constructed a rocket car out of a meccano kit and used a 2l water bottle filled with 200ml of water and pressured gas as a means to propel it forwards. The distance that it has to travel is 16.5m
I am having difficulty calculating the energy stored in the device, the energy required to travel this distance and the energy dissipated through the process.
2. Relevant equations
To calculate the energy stored in the device i decided to record the relationship between an increase in pressure and an increase in volume of the bottle. If I can draw the curve and integrate would this give me the energy stored in the bottle?
To calculate the energy dissipated through rolling friction I have come across formulae and am not sure if they are correct, I know that this can be found out experimentally however i'm not sure how to go about this
Calculating the thrust produced by the car can be done using T=2PA where P is the pressure and A is the cross sectional area of the nozzle.
One equation for rolling friction that i encountered was FR = (Mew)R x weight of wheel. I looked online an got a friction coefficient value of 1. As the weight of the wheel was 0.173kg and there are four wheels i got a value of 0.6935kg
Thrust - rolling friction = resultant force
167.190 - 0.6935 = 166.5N
By using F = m a the mass of the car being 0.6935kg
I calculated the acceleration by doing 166.5 / 0.6935 = 240m/s^2
I know that energy stored can be equated to pressure x volume and the acceleration is not constant throughout so therefore i cannot use the kinematic equations.
3. The attempt at a solution
I calculated thrust by doing 2 x 200,000Pa x (Pi X 0.0115^2) which gave me a value of 166.190N
However as the nozzle is at an angle of 30degrees i multiplied this value by cos30degrees and got a thrust of 143.92N
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Thread Tools
Similar Threads for: Water rocket car
Thread Forum Replies
Water Rocket - Rate at which water exits Introductory Physics Homework 2
Water/Air Rocket Engineering, Comp Sci, & Technology Homework 0
Water Rocket Advanced Physics Homework 1
High school project - water bottle rocket General Physics 1
Max Velocity of a Water Rocket Introductory Physics Homework 1
