Inclined Plane-Acceleration of Object
  • Thread starter Thread starter darkmasterz8
    Inclined
The discussion focuses on calculating the acceleration of an object moving on an inclined plane, specifically from point A to B. The user correctly identifies the formula for acceleration as Ax = g * sin(theta), where g is the acceleration due to gravity (9.8 m/s²) and theta is the angle of inclination (20 degrees), resulting in an acceleration of 3.35 m/s². However, there is confusion regarding the inclusion of normal force in the calculations, which is deemed unnecessary unless friction is present. The importance of clearly defining the x-axis direction in physics problems is also emphasized.
  • Understanding of Newton's laws of motion
  • Familiarity with inclined plane physics
  • Knowledge of trigonometric functions, particularly sine
  • Ability to interpret free body diagrams
  • Study the effects of friction on inclined planes in physics
  • Learn how to construct and analyze free body diagrams
  • Explore the concept of normal force and its applications in various scenarios
  • Review problems involving multiple forces acting on an object
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators looking for examples of common misconceptions in force analysis.
darkmasterz8
[PLAIN]http://img375.imageshack.us/img375/7161/physics.png
I have to find the acceleration of A to B.
My problem is that I'm not sure to add normal force with the force of gravity x component.
Fnetx=Fgx
m*Ax=m*g*sin(theta)
Ax=g*sin(theta)
Ax=9.8*sin(20)
=3.35 m/s^2
Should I have added normal force to the Fgx since Fnet is the sum of all forces? I thought you would only include this if friction was given.
Normal force is "canceled out" with the component of gravity perpendicular to the ramp (mgcos(theta)). That is why the object doesn't go through the plank and doesn't get propelled out of it either.
Correct, normal force would be included with friction.
The problem with your solution is that you haven't defined what the direction of x-axis is.
It could be up down, left, right, down the ramp, up the ramp...
Are you sure that's what the question is ? It's better to take a look at the question taken from the textbook.
  • · Replies 18 ·
