<r> and <V(r)> in the Hydrogen Atom.
The discussion revolves around calculating expectation values related to the potential energy and position of an electron in the 1s state of the Hydrogen atom. The specific equations and concepts being explored include the potential energy function V(r) and the radial expectation value , with participants attempting to apply quantum mechanics principles to derive these values.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the appropriate methods for calculating expectation values, including the use of integrals and the potential operator. There is mention of using the virial theorem and the relationship between potential and kinetic energy. Some participants question the need for specific operators related to quantum numbers and express uncertainty about the integration process for the wavefunctions.
The conversation is ongoing, with various methods being proposed and explored. Some participants have provided insights into directly evaluating integrals, while others are still grappling with the underlying concepts and calculations. There is no explicit consensus on the correct approach, but several productive lines of reasoning have emerged.
Participants note the challenges of integrating wavefunctions and the potential for errors in calculations. There is also a recognition of the need for clarity regarding the definitions and relationships between the different quantum mechanical operators and expectation values.
dirtyaldante
Hi. I'm a 3rd year undergraduate studying Applied Physics and I'm having some trouble with a problem concerning the Hydrogen Atom. This is my first post so please forgive the sloppy equations. Not really used to writing this stuff out without an equation editor handy! Anyway, the problem:
1.Determine the expectation value of the potential energy [V(r) = (e^2)/(4.pi.epsilon0.r)] in the 1s (ground state) of the Hydrogen atom.
2.What is the expectation value of r for an electron in the 1s state of the Hydrogen atom?
<V(r)> = INT [PSI*|V(r)^|PSI]
n=1, l=0, ml=0
So the method I used to solve other expectation values (<L^2>,<Lz>,<E> etc...) was to use the appropriate operator upon the square of the wavefunction in question, ie: PSI(n,l,ml).
However I can't find operators for the Potential(V(r)) or r(position I suppose) that are related to the quantum numbers n,l and ml like in the other expectation values I solved. e.g.
L^2^=l(l+1)hbar
E^=13.6/n^2
Lz^=ml.hbar
So then I would square the wavefunctions and their coefficients inside the integral and then use the operators appropriately, in this case on the PSI(1,0,0) for the 1s configuration.
Am I simply missing a fundamental operator here? Or do I have to try arrange the operators myself? Rearranging the Schrödinger equation in terms of V(r)PSI was the only thing I could think of and even then I couldn't navigate through the wavefunctions of the separate parts.
Another idea I had was to use the Laguerre polynomial to redefine the wavefunction, but I'm unsure on how to proceed after that.
Is my method just completely off for these expectation values? I have been scratching my head all day over this and would really appreciate help if anyone can offer it.
Update:
I might have the answer to the second part. If the probability density is P(r) and P(r)=|R(n,l)|^2 times r^2
where:
R(n,l)=Radial wavefunction defined by the laguerre polynomials
r=radius
Then the value of r for this state corresponding to the maximum chance of finding an electron is at dP(r)/dr = 0
So after some work I found that this occurs at r=4a0, where a0 is the bohr radius.
Does this mean that <r> is simply 4a0? If so how could I show this mathmatically?
I think for the 1s state the wavefunction is so simple, that the 2 integrals required for point 1 and 2 can be done directly, without resorting to complicated formulas involving associated Laguerre polynomials, or even confluent hypergeometric functions.
As for the first point, average of the potential operator in the 1s state, you can use the virial theorem in QM. Just google it, if you don't know it already or have it in your textbook.
The potential operator for the H-atom is simply -k/r, where by 'k' I denoted the whole bunch of constants.
So you have a 2 relations between <V> and <T>, one from the virial theorem and the other from the fact that <V>+<T>=<H> for each eigenstate of the Hamiltonian and 1s is one of them. A simple system to for <V>.
Ok, I think I get what you're saying but I don't understand the reasoning behind your method or how it well help me determine the expectation value of V(r).
Can you comment on the method I proposed and how it might relate to yours?
As bigubau suggested, it's easiest to just evaluate the integrals directly. The expectation value of a function f(r) is given by
[tex]\langle f(r) \rangle = \int_0^\infty f(r) p(r) \, dr[/tex]
where p(r) is the probability density. In post 2, you already said what the probability density is, namely p(r)dr = |R(r)|2r2dr, so, for example,
[tex]\langle r \rangle = \int_0^\infty r \lvert R(r) \rvert^2 r^2\,dr[/tex]
You just need to substitute for R(r) now and evaluate the resulting integral.
That's exactly what I need! Matches one of the useful integrals supplied too. Awesomeness. Thanks!
Solutions for anybody who cares:
<V(r)> = (1/8.pi.epsilon0) sqrt(a0)
<r> = (3/2) a0
where a0 is the bohr radius = 5.29177×10^−11
If somebody wants to double check my solutions they are more than welcome to but I think we can agree they look pretty good.
Thanks for the help guys!
Your expectation value for V(r) isn't correct. For one thing, the units don't work out. Also, some constant factors are missing as well.
Aha, you're right of course. I dropped the e^2 by mistake. That fixs the units.
Not quite. The units of <1/r> should be 1/length, so it'll be proportional 1/a0, not sqrt(a0).
Yep, I'm an idiot. Messed up the integration. Pretty sure i got it right THIS time though...
<V(r)>=e^2/(pi.epsilon0.a0)
I got
[tex]\langle V(r) \rangle = -\frac{1}{4\pi\epsilon_0} \frac{e^2}{a_0}[/tex]
Forgot to type the 4 and neglected the minus like I always do. Old habits die hard.
  • · Replies 21 ·
  • · Replies 0 ·
