Electron Density of Silver: Calculate With Formula
The discussion focuses on calculating the electron density of silver using its density of 10.5 g/cm³ and atomic weight of 108 g/mol, with the assumption of one electron per atom. The formula for the density of states in momentum space, 2V/h³, is mentioned but deemed inappropriate for this calculation. The key to solving the problem lies in converting the mass density into electron density by utilizing the atomic weight and the number of electrons per atom.
  • Understanding of atomic weight and its implications in calculations.
  • Knowledge of density as mass per unit volume.
  • Familiarity with the concept of electron density in materials.
  • Basic skills in unit conversion and dimensional analysis.
  • Learn how to convert mass density to electron density using atomic weight.
  • Study the relationship between atomic structure and electron configuration.
  • Explore the concept of density of states in solid-state physics.
  • Investigate the properties of silver in its metallic state and its implications for electron behavior.
Students and professionals in materials science, physicists, and chemists interested in the electronic properties of metals, particularly silver.
magnifik
Given: density of silver = 10.5 g/cm3, atomic weight = 108, assume 1 electron per atom.
Question: Find the electron density in the metallic state of silver.
i have the formula 2V/h3 for the density of states in momentum space. I'm not sure if this is the correct formula to use and if so, how to find V from the given information.
Not at all. This is essentially just a conversion problem.
You know the density of silver (mass per unit volume) and you need to find the electron density (number of electrons per unit volume), thus you need to convert between mass and number of electrons indirectly.
They also tell you the atomic weight (what information does that give you?) and the number of electrons per atom.
Any ideas on how to start?
