Damped Harmonic Motion with a Sinusoidal Driving Force
The discussion revolves around a damped harmonic oscillator characterized by mass, stiffness, and mechanical resistance, driven by a sinusoidal force. Participants are tasked with analyzing the speed amplitude and phase angle as functions of the driving frequency, specifically identifying frequencies where the phase angle is 45°.
  • Participants discuss the role of the driving frequency as the independent variable and question the correct form of the differential equation. There is confusion regarding how to derive the equation of motion for plotting purposes.
Some participants have confirmed the correctness of the differential equation and clarified the meaning of speed amplitude. However, there remains uncertainty about the plotting requirements and the formulation of the phase angle.
Participants are navigating potential typographical errors in equations and clarifying variable definitions, such as the representation of the spring constant. There is an emphasis on ensuring the correct interpretation of the problem's requirements.
roldy
1. An oscillator with mass 0.5 kg, stiffness 100 N/m, and mechanical resistance 1.4 kg/s is driven by a sinusoidal force of amplitude 2 N. Plot the speed amplitude and the phase angle between the force and speed as a function of the driving frequency and find the frequencies for which the phase angle is 45°.
2. m[tex]\ddot{x}[/tex] +Rm[tex]\dot{x}[/tex]+kx=Fosin[tex]\omega[/tex]t
see attachment for rest of equations
3. m= 0.5 kg, s=100N/m, Rm=1.4 kg/s, Fo=2N
So my first question is this, is omega the independent variable in this case? Meaning, I solve everything that I am able to and leave omega alone. Also, is the differential equation in #2 the right form?
I am confused at how I obtain the equation of motion so that I can plot this.
Yes, ω is the driving frequency, so it's the independent variable for what's being asked in the problem. I'm not sure what you mean by "leaving ω alone." You want to express the speed amplitude and the phase angle as a function of ω and the constant parameters of the system.
Yes, your differential equation is correct. It is the equation of motion for the system. Note that k is the spring constant, which you called also called s in the other equations.
I think you have a typo in your equation for the phase angle. Also, what does c represent in that formula?
The equation for the phase angle is wrong it should be tan[tex]^{-1}[/tex](H)
where H=[tex]\frac{\omega*m-k/\omega}{R_{m}}[/tex].
I'm still a little confused about what they are asking for in regards to plotting.
By "speed amplitude," I assume the problem is asking for the amplitude of v(t). It will depend on ω.
