Register to reply
Calcluated density value different from literature
Share this thread:
ana111790
#1
Jan22-11, 11:30 PM
P: 43
A blood pressure cuff is used to measure the gage pressure associated with blood flow in the body. “Normal”, systolic blood pressure is commonly reported as 120 mm of mercury. This value represents the vertical displacement of mercury (h) resulting from the gage pressure within the device. (The density of mercury is ρ = 1.38 x 10^4 x kg/m^3 )
a. Calculate the gage pressure within the device (in Pa) that corresponds to a vertical displacement of 120 mmHg.
b. The fluid in the device is replaced with a glycerin solution and the gage pressure from part b is applied. The displacement in the column corresponding to this gage pressure is 166 mm of glycerin. What is the density of this glycerin solution?
2. Relevant equations
Pgage= ρ*g*h
3. The attempt at a solution
a) Pgage= ρ*g*h = (1.38 x 10^4 kg/m^3)*(9.8 m/s^2)*(120mm)* (1m/1000mm)
Pgage=16200 kPa
b) ρglycerin=Pgage= 16200Pa/[(9.8 m/s^2)*(166mm)*(1m/1000mm)
ρglycerin=9960 kg/m^3 which is different from the density of glycerin in literature (1250 kg/m^3)
So I am wondering these calculations are right or if I am missing something.
Thanks!
Phys.Org News Partner Science news on Phys.org
Apple to unveil 'iWatch' on September 9
NASA deep-space rocket, SLS, to launch in 2018
Study examines 13,000-year-old nanodiamonds from multiple locations across three continents
SammyS
#2
Jan23-11, 01:11 AM
Emeritus
Sci Advisor
HW Helper
PF Gold
P: 7,808
Quote Quote by ana111790 View Post
Pgage= ρ*g*h
Pgage=16200 kPa
Thanks!
The height of the column is inversely proportional to the density of the fluid, so your answer appears to be consistent with the data given. I agree with you that the glycerin solution is unrealistically dense.
Register to reply
Related Discussions
Russian Literature History & Humanities 9
Quantum physics-related literature Quantum Physics 1
Literature help Mechanical Engineering 0
Need help on literature Classical Physics 1
Literature Forums General Discussion 0
