How to Compute r in Stereographic Projection from R^4 to R^3?
The discussion revolves around computing the parameter r in the context of stereographic projection from R^4 to R^3. Participants explore the mathematical formulation and visualization challenges associated with this projection, comparing it to similar concepts in R^3.
  • One participant proposes a set of equations for stereographic projection in R^4 but expresses uncertainty about computing r and visualizing it.
  • Another participant questions whether the equations represent stereographic projection or spherical coordinates.
  • A different participant recalls a previous example in R^3 where r was computed geometrically and wonders if a similar formula exists in R^4.
  • One participant asserts that stereographic projection is consistent across dimensions and suggests a method involving drawing lines from the north pole to points on the sphere to find intersections with a hyperplane.
Participants do not reach a consensus on the correct formulation of the projection or the method for computing r. Multiple competing views and interpretations of the projection exist.
The discussion highlights potential limitations in visualizing higher-dimensional projections and the reliance on geometric intuition from lower dimensions. There are unresolved questions regarding the applicability of previous methods from R^3 to R^4.
whattttt
I am computing a stereographic projection in R^4 and i think i am correct in setting
x=rcos(x)sin(y)
y=rsin(x)sin(y)
z=rcos(y)
but can't see how to compute r as I do not know to visualise it graphically as was possible in R^3, any help would be greatly appreciated
That doesn't look like stereographic projection to me...do you mean spherical?
No. In a previous example it was in R^3 and polar coordinates were used with x=rcosx and y=rsinx and r was computed from the diagram and equaled something like 2tan(pi-theta) which could be computed from the diagram by projection onto the x-axis but I'm not sure if such a formula exists in R^4
x=rcos(x)sin(y)
y=rsin(x)sin(y)
z=rcos(y)
but can't see how to compute r as I do not know to visualize it graphically as was possible in R^3, any help would be greatly appreciated
Stereographic projection is the same in all dimensions. Draw straight lines from the north pole through the points of the sphere and calculate the intersection of these lines with the hyperplane that is perpendicular to the direction of the north pole. You do not need polar coordinates for this.
  • · Replies 39 ·
